Dim clock and climate control lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Honz, Aug 8, 2022.
  1. Feb 12, 2023 at 10:46 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    No. This will not be plug and play in your SR5P. See the table above.
    To reiterate, 2019 and previous year SR5 Premiums are reported to not have the necessary wiring connected to the BCM to operate the dimming feature.
    There are some involved work arounds to add the wiring from sensor to BCM, in another thread.
    Sensor part numbers:
    For 2016-2019 models:
    6-pin double row connector (only 3 pins populated).
    Light sensor P/N 89121-50020.
    2020+ models:
    With a 4-pin single row connector.
    Light sensor P/N 89121-0E060.
    Also the Lexus part 89121-30020 is reported to work.
    LuLu, Too Stroked and shumif1[QUOTED] like this.
  2. Feb 12, 2023 at 12:18 PM
    knoxnil
    knoxnil New Member
    19 SR5 Premium
    Did a double check on the sensor in my dash, It's a dummy, just a blank plastic with nothing inside but was plugged into a wiring harness that had three wires running down into the dash. I had tried the replacement sensor off Amazon with no affect, when I tried to pry it back out to check it, the top popped off then the insides separated and let loose of the wired plug which disappeared down into the dash, of well, at least I still had the dummy sensor to plug up the hole in the dash, so much for that.
  3. Feb 12, 2023 at 12:46 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Ow, that’s a bummer. You may be able to fish it out with a thin wire if you want.
    The SR5 Premiums can have the three wires in the plug at the sensor end but they do not terminate at the BCM. You’d need to complete the circuits to get it to work.
    One more thing. Before you install any sensor into place make sure you test it first before snapping it into the dash. The two little plastic tabs on the live sensor are oriented in a way that prohibits easy removal. As you found out.
  4. Feb 12, 2023 at 4:21 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    @ElectroBoy
    do you know if there’s a way to get the clock/climate control lights to NOT dim when switching the stalk to the parking light setting
  5. Feb 13, 2023 at 12:27 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I’m not very familiar with the 2020+ models. Some electrical systems are different than the 2019s and below. You could try experimenting with settings in the entune menus.
    Or click the interior dimmer wheel to maximum brightness.
    semprenissart[QUOTED] likes this.
  6. Feb 13, 2023 at 3:21 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    LuLu[QUOTED] likes this.
  7. Feb 13, 2023 at 7:18 PM
    semprenissart
    semprenissart Mèfi
    I've tried both of these to no avail.
    I'm guessing the way Toyota wired it makes it not possible.
    From what I understand, the older years of the 5th gen that had the clock with the Accessory Meter Display it is possible to change the brightness of the clock via the mode button but as far as I know, now the clock brightness cannot be changed. It automatically dims when the headlights/parking light are on and stays bright when DRL or all lights off without any possibility to adjust the intensity
  8. Feb 14, 2023 at 2:06 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Thanks @ElectroBoy. Appreciate the efforts.
    What i was trying to explain is that the 2022/2023 doesn't seems to need the dash light sensor.
    The functionality is already built into my TRD Sports.
    Once i turn the low/High beams on, the dashboard light dims. No glaring at night. Just exactly what i need.
    On DRL, Dash light remains bright during the day.
    According to Toyota Parts representative, the model year matches the part number, but my VIN says that part is not designed for my truck. so thankfully, my order was cancelled. so i went back to test the functionality.
  9. Feb 14, 2023 at 1:42 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    My 18 ORP with the AMD behaves the same way. It dims with the headlights switched on.
  10. Feb 14, 2023 at 4:10 PM
    semprenissart
    semprenissart Mèfi
    with the AMD buttons I think you can change the brightness settings of the AMD though
  11. Feb 14, 2023 at 11:54 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Yes. You can adjust the three brightness settings. But it still dims the clock/AMD significantly when you turn the headlights on. Even at max brightness you can barely see the display in daylight. I would have thought Toyota would have fixed this in 2020+ models.
  12. Feb 23, 2023 at 12:45 PM
    shumif1
    shumif1 New Member
    Tommy
    New Jersey
    2018 4Runner Premium
    I don't have an AUTO switch on my headilght control, i was wondering if anyone knows if i can change the headlight control , steering column/ harness etc.control parts to make it work ?
  13. Feb 25, 2023 at 4:02 PM
    Deadmeat99
    Deadmeat99 New Member
    Northern Nevada
    2021 Venture
    I installed the absurdly expensive P/N 89121-0E060 sensor on my '21 Venture today and can confirm that it works great. Finally able to turn on headlights and have the screen stay in daylight mode. Thanks for all who posted the information. I do not understand why Toyota wouldn't include this simple part/function on EVERY 4Runner but Toyota I guess.
    5thGin and 2Toys like this.
  14. Jun 9, 2023 at 2:25 PM
    5thGin
    5thGin New Member
    5th Gen
    Glad to hear yours works well. Im going to order one soon.
  15. Oct 23, 2023 at 6:29 AM
    trail_runner_93
    trail_runner_93 New Member
    South Central PA
    Does anyone have a 2023 SR5 Premium that has tried this and with any success? Trying to understand what the prerequisites are for this functionality. I have the standard stalk for lights - no auto on/off and have foglights.
    New here - TIA for any input!
  16. Oct 23, 2023 at 3:10 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    I added the sensor to my 2021 SR5 Premium and it works perfectly. I used the OEM Toyota part since I work at a dealership.
  17. Oct 23, 2023 at 3:14 PM
    TJBinOPCA
    TJBinOPCA New Member
    Tom
    2023 TRD Off-Road
    The problem, for me anyway, is that the sensor does not brighten the clock during the day.
  18. Oct 23, 2023 at 4:03 PM
    trail_runner_93
    South Central PA
    thanks for the info! I will give it a go!
  19. Oct 23, 2023 at 4:46 PM
    #49
    Too Stroked
    Tom
    2021 SR5 Premium
    True, but you also have a time display (clock) in the infotainment screen - and that is controlled by the sensor if you add it.
    trail_runner_93 likes this.
  20. Oct 26, 2023 at 10:10 AM
    #50
    trail_runner_93
    South Central PA
    I just received mine and installed it in my 2023 SR5 Premium that had the dummy plug in the dash with the wire inserted. I now have auto dimming when my taillights or headlights are selected on my light selector. I do not have the auto lights option. It does not seem to work when I just have DRL on? I think that sounds right?
    I ordered this: https://a.co/d/5EIzPkI.
    Having read about the risk of the wire dropping out and behind the dash - I had a pair of Kelly clamps ready and as soon as the dummy came out I clamped the wire so it would not fall back in while connecting and testing.
  21. Oct 26, 2023 at 11:04 AM
    #51
    backpacker
    backpacker New Member
    2023 TRD ORP
    What happens when you have the DRL on? Is the display always bright? Always dark?
  22. Oct 26, 2023 at 11:21 AM
    #52
    trail_runner_93
    South Central PA
    Always bright - based on quick testing in during my lunch break.
  23. Oct 26, 2023 at 12:39 PM
    #53
    backpacker
    2023 TRD ORP
    What does it do in "off"?
  24. Oct 26, 2023 at 1:23 PM
    #54
    Isn't the purpose of the new sensor to keep the dash display bright, instead of dimming, when you turn your headlights on during the day? That's how mine works.
    2Toys likes this.
  25. Oct 26, 2023 at 2:51 PM
    #55
    Too Stroked
    Tom
    2021 SR5 Premium
    That's exactly why I installed the sensor on mine. In New York State, by law, you have to run your headlights any time you're running your wipers. During the day, I literally couldn't see anything on my infotainment screen when I did that. Install sensor - problem solved.
    As for the DRL's, I have mine disabled through the Setup menu for a different reason.
    jake1530 and 2Toys like this.
  26. Oct 27, 2023 at 3:37 AM
    #56
    trail_runner_93
    South Central PA
    nothing as far as I can tell.
  27. Sep 22, 2024 at 4:54 PM
    #57
    vthoky New Member
    I just dropped an 89121-30020 into my 2024 ORP this afternoon. I don't think it's the right thing... the head unit went dark as soon as I turned on the lights, despite the afternoon sun. I'll try it again tomorrow to be sure.
    Based on this quick test, I'm thinking I should have bought -0E060 instead. Grr.
  28. Sep 22, 2024 at 6:31 PM
    #58
    icebear Recovered Kia Owner
    Odd, my 2021 SR5 is working with the -30020 - please don’t let it be another complication! If you haven’t snapped it in yet, maybe it could be a bad part?
  29. Sep 22, 2024 at 6:36 PM
    #59
    vthoky New Member
    Idunno, man. I did go ahead and snap it into place. I'll try it again in tomorrow's daylight and we'll see what happens.
    To be fair, testing this afternoon was done inside the garage, though backed in with the truck facing west into the afternoon sun.
    I've found a -0E060 relatively inexpensively (probably a knockoff, though my -30020 is Toyota OE). It should be here in a week or so, in case this -30020 truly doesn't work right.
  30. Sep 22, 2024 at 7:00 PM
    #60
    That shade might've been enough since it can trigger under overpasses. Fingers crossed it works since I read you can't (or not easily) remove the actual sensor the way it went in due to the clip design. My -30020 was an $18 knockoff.
