Dealership Decal Residue :(
Discussion in '5th Gen 4Runners (2010-2024)' started by M-Bear41, Dec 28, 2024.
  1. Dec 29, 2024 at 9:03 AM
    M-Bear41
    M-Bear41 [OP] New Member
    Mojo
    Thanks everyone for the help! I'll keep you updated. Its a 2023 that I've had for about 6months now so it's still pretty new; just hit 13k and I bought it with 9k miles, so I'm figuring they had it on for a while
  2. Dec 29, 2024 at 9:19 AM
    UncleShorty
    UncleShorty New Member
  3. Dec 29, 2024 at 9:20 AM
    Considering that it’s hasn’t been on longer than a bit over a year, I’d guess it should come off. I personally like the idea of using a very fine polishing compound. I’d agree with the other posts that suggest that it’s the rest of the glass that needs to be polished/cleaned to match the glass surface that was protected by the sticker. It doesn’t look like sticker residue. It’s more of a weathering shadow.
    Depending on where it was driven and parked, the glass could have been subjected to pollen, tree sap, acidic road grime etc. The worst stuff is water that has filtered through concrete, like you might get in a parking structure. Those are the contaminants that a polishing compound will remove. Go easy with it, do it by hand, don’t do more than you need to.
  4. Dec 29, 2024 at 1:32 PM
    I was going to recommend pressure washing and/or sand blasting. That should do it.
  5. Dec 29, 2024 at 1:46 PM
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    WD-40 works pretty well. It is mild enough to not eat up anything else. It's cheap and you can use it for a million other things.
    LCJ77, SOSHeloPilot and Noodles like this.
  6. Dec 29, 2024 at 3:11 PM
    like2lean
    like2lean New Member
    WD-40 first, then Goo gone but be careful it can eat paint.
    SOSHeloPilot likes this.
  7. Dec 29, 2024 at 3:45 PM
    4runningMan
    4runningMan New Member
    New Mexico
    This might be worth a shot. I use it for water spots on glass. Works very well.
    Amazon. $13
    Cleans Stains from Glass. Removes Soap Scum from Shower Doors. Use On Auto Glass for Water Spots. "Sparkle" Cleaner does those glass cleaning jobs too tough for spray-on cleaners. It removes light water spots and stains in glass caused by weather, sea air or pollution; also removes soap scum from shower doors and ceramic tile. Use it on auto glass to remove water spots from automatic windshield washers. Wipe on with a damp cloth or paper towel, rub stained areas, and then wipe off. Contents of Container: 8 fl oz (237 ml) Important Note: Check can label and Material Safety Data Sheet for any additional limitations and warnings.
    McSpazatron likes this.
  8. Dec 30, 2024 at 7:09 AM
    Ive been in this situation, I told the dealership they can pay me $25/day to advertise for them or they can take it off. They took it off. Such BS that they put huge lettering.
    Imdav2u likes this.
  9. Dec 30, 2024 at 8:16 AM
    Id take it to a detail shop, it cant cost that much for them to do it with the right chemicals/polishes. I sure as hell wouldnt do brake cleaner, the risk of other damage is too high.
    Saker likes this.
  10. Dec 30, 2024 at 8:58 AM
    wingo
    wingo *****
    2020 Venture
    They had added the label when the 4runner was brand new. What you are seeing is the brand new glass behind the label. You would have to buff the entire glass to match where the label was. Do a section to match then do the entire glass. It is no different than a label being on the car, it would be the same process to match. If you don't want to do the work, take it to a professional detailer.
    M-Bear41[QUOTED][OP] likes this.
  11. Dec 30, 2024 at 11:03 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    As others have mentioned, I would take it back to the dealer and have them remove the residue. I would imagine their "detailing" person could get rid of it. This is why I actually removed my liftgate mounted dealer badging as soon as I got home with mine, before I even went in the house. Good luck with the removal, sucks they did that.
    M-Bear41[OP] and Imdav2u like this.
  12. Dec 30, 2024 at 12:09 PM
    Talking it to a dealer will probably somehow end up with them buying a new rear hatch, and color matching respray on the back half of the car. And the
    sticker shadow will probably still show, until they accidentally break the glass when somebody drops a tool on it. The new glass will look great though. ;):D
    M-Bear41[OP] likes this.
  13. Dec 30, 2024 at 12:12 PM
    ghbucky
    ghbucky New Member
    Northern Kentucky
    2024 SR5 part time 4 wheel drive
    I have to wonder if this is worth all the pain to remove that is being mentioned?
    It doesn't seem noticeable, since OP said that they can only see it in certain conditions?
  14. Dec 30, 2024 at 12:16 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    The unfortunate thing is even after you use brake cleaner (or whatever solvent/ solution you like to remove the residue) the tint inside might still be sun-stained and may still be a little visible.
    This is one unfortunate thing about stickers on tinted glass. Depending on how long the sticker was there and the sun exposure it went through.
  15. Dec 30, 2024 at 9:32 PM
    I would try the goo gone again with a glass scraper tool with razor blade. That will scrape any possible residue off.
  16. Dec 31, 2024 at 12:09 AM
    Is this true for film tint or factory dipped glass?
  17. Dec 31, 2024 at 11:46 AM
    Jorgem2
    Jorgem2 New Member
    2024 4runner TRD PRO
    I have always removed everything from glass with lots of soapy water and a brand new very wet single edge razor blade gently scraping at a 15 degree angle.
    If it doesn’t come off with that it’s etched in
    Turd Ferguson likes this.
  18. Dec 31, 2024 at 1:12 PM
    WD40
    LCJ77 likes this.
  19. Dec 31, 2024 at 3:20 PM
    #49
    4runningMan
    New Mexico
    I think our work here is about done?
  20. Dec 31, 2024 at 6:18 PM
    #50
    1SilverRunner
    Tejas
    Film tint.
  21. Jan 10, 2025 at 11:30 AM
    #51
    M-Bear41
    Mojo
    Thanks y'all for the help. I'm going to try to get it off in the spring when it warms back up. I've had no luck with any of the suggested chemicals and I'm too nervous to go too crazy. I think I'll go with a professional and if they still can't get it, idk lol. Thanks for all the assistance! I really appreciate it!
    Powerstroke likes this.
  22. Jan 10, 2025 at 1:08 PM
    #52
    mac1usa
    mac1usa New Member
    Personally I would not wait until spring, I fear the longer it is on the more difficult or unlikely to come off. I would find a quality detailer
  23. Jan 10, 2025 at 3:48 PM
    #53
    I agree with Mac, a quality detail shop can inform you about getting it removed.
    Maybe one can come to you. Take care of it sooner than later.
  24. Jan 12, 2025 at 5:54 AM
    #54
    Terraizer
    Terraizer New Member
    Trdpro2024
    Lights
    Start with rubbing compound follow up with polish. Then if you want the window to repel water and make it easy to clean wax your windows. If your not into a little work for best results wd-40.
    glwood54 likes this.
  25. Jan 12, 2025 at 12:15 PM
    #55
    BoiseG
    BoiseG New Member
    2024 Off-Road Premium
    This would likely work, but it'll ruin your clear-coat if you get it on the paint.
    Saker likes this.
  26. Jan 28, 2025 at 5:19 AM
    #56
    Greg D
    Greg D New Member
    Greg
    2013 4runner
  27. Jan 28, 2025 at 5:20 AM
    #57
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Removes double sticky tape adhesive pretty good. Soak it.
