Dealer oil change would be laughable...
Discussion in '5th Gen 4Runners (2010-2024)' started by qcTRDct, Nov 20, 2023.
  1. Jan 18, 2024 at 10:44 AM
    #151
    When you build that new house, be sure to put one of these in:
    JakeTheSnak3 likes this.
  2. Jan 18, 2024 at 10:56 AM
    #152
    JakeTheSnak3
    JakeTheSnak3 New Member
    Jacob
    Concord, CA
    2023 4runner Trd Pro
    Look up RCI or CBI Offroad names.
    I have got CBI installed. I installed them myself. A lot of work but the oil change is easy. Just remove the access panels for both the filter and oil plug and there u go. I do oil changes myself. Fumoto oil plug makes it even easier. Look up videos on YT.
    ecoterragaia[QUOTED] likes this.
  3. Jan 18, 2024 at 12:08 PM
    #153
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Raise you, will be living in a jiffy lube converted private residence
    rickystl likes this.
  4. Jan 18, 2024 at 12:11 PM
    #154
    Does that mean you have to overtighten your oil filter housing or strip the skid plate bolts if you change the oil :p...?
  5. Jan 18, 2024 at 12:34 PM
    #155
    Impact everything
    JS222STL and LCJ77 like this.
  6. Jan 18, 2024 at 12:44 PM
    #156
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    & not the smaller Milwaukee but the Lug Stud Snap off one!!!
  7. Jan 18, 2024 at 1:45 PM
    #157
    I've seen my local tire shop have the tech walk around with a big ass impact putting tires back on then use a torque wrench.
    I made um loosen all my lugs and do everything by hand in the parking lot before I left. If I could change my own tires I'd do that too.
    LCJ77 likes this.
  8. Jan 18, 2024 at 1:50 PM
    #158
    3JOH22A Toyota Gigolo
    He'll also have the urge to do a transmission flush and fuel system cleaning.
    glwood54[QUOTED] likes this.
  9. Jan 18, 2024 at 1:59 PM
    #159
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    When he used the TQ wrench did he get any + movement? If so then it was good to go, if not over TQ'd basic install procedure.
  10. Jan 18, 2024 at 2:01 PM
    #160
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I was gonna ask this same question. I use my 1/2 impact to install my wheels. Shits a beast and you have to have the feel for it.
    I go back through with the torque wrench and as long as I get some movement I know I didn't overtorque them.
    LCJ77[QUOTED] likes this.
  11. Jan 18, 2024 at 2:04 PM
    #161
    Nope that shit clicked immediately.
    1SilverRunner likes this.
  12. Jan 18, 2024 at 2:28 PM
    #162
    backpacker
    backpacker New Member
    2023 TRD ORP
    My dilemma is that I'm planning a month-long spring road trip that will probably cover 7-8k miles. Dare I let someone else change my oil on the road?
  13. Jan 18, 2024 at 2:37 PM
    #163
    HuskyMike
    HuskyMike New Member
    I'd change it before and after. I'd imagine most new toyota owners are only doing changes at 10,000 miles when they get the free service from the dealer.
    icebear and 1SilverRunner like this.
  14. Jan 18, 2024 at 2:38 PM
    #164
    1SilverRunner
    Tejas
    TBH I'd just send that shit and change it when I got back. Toyota says the oil is good for 10K so you're probably good for 7-8 without much worry.
  15. Jan 18, 2024 at 2:48 PM
    #165
    When was your last oil change?
  16. Jan 18, 2024 at 2:50 PM
    #166
    Stop by a Walmart during the trip, pick up oil, filter, and cheap drain pan. Change it in the parking lot.
    People do rear diff swaps in the parking lot and change out rod bearings on the side of the road. I'm sure you can manage an oil change.
    rickystl and icebear like this.
  17. Jan 18, 2024 at 2:55 PM
    #167
    backpacker
    2023 TRD ORP
    I'm trying to time it to right before I leave.
  18. Jan 18, 2024 at 3:11 PM
    #168
    Yobruhitsme
    Denver
    Ineos Grenadier
    lol that’s hardcore
  19. Jan 18, 2024 at 3:15 PM
    #169
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
  20. Jan 18, 2024 at 3:23 PM
    #170
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I have both TQ 3/8's impact's Milwaukee's M18 cause I bought too impulsive.:rolleyes: The less TQ is good for lower Tq items :yes:BUT not for breaking lug nuts so I have both & use accordingly:yes: Wife still doesn't understand having "Too Many Tools" UNTIL she needs something serviced/repaired/fixed":cheers: And she really has NO CLUE!!:bowdown::bowdown:
  21. Jan 18, 2024 at 3:37 PM
    #171
    Mtnmonkey
    Mtnmonkey New Member
    NC
    2024 4Runner TRD Pro, White
    3JOH22A[QUOTED] likes this.
  22. Jan 18, 2024 at 4:14 PM
    #172
    I think it means he just has to *say* he changed the oil. :laughing:
  23. Jan 18, 2024 at 7:21 PM
    #173
    qcTRDct
    qcTRDct [OP] New Member
    2022 ORP KDSS
  24. Jan 19, 2024 at 10:00 AM
    #174
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    OK, so I'm looking for a house and a garage just became a must have. My gf tells me something is hanging under the front of my 4runner. It was the skid plate access panel, one bolt (loose) the other bolt dropped in from the top (so the "tech" wouldn't lose it). made it 6 days and probably 300 miles. Luckily I have some of my tools in my office (no room in my apartment) so it is fixed now).
    qcTRDct[OP] likes this.
  25. Jan 24, 2024 at 8:32 AM
    #175
    DIPA
    DIPA New Member
    Shawn
    Rhode Island
    2023 Lunar Rock Off Road Premium
    Hi everyone - I've scanned the oil change threads and maybe I missed it but I am unclear on the process/steps to remove then reinstall the oil filter housing and the metal plug on the bottom of the housing.
    Is this right?
    Removing: first remove the metal plug from housing. Then remove housing from truck.
    Reinstalling: definitely unclear here, is it just reverse order (attach housing to truck, then attach plug to housing)? The reason I am unsure on this step is I didn't know if putting on the plug after the housing is attached and tightened would also (incorrectly) overtighten the housing.
    Any tips most appreciated and I apologize if this has already been covered. Thanks.
  26. Jan 24, 2024 at 8:36 AM
    #176
    icebear Recovered Kia Owner
    Housing goes on, then metal plug goes on I believe. I also believe the metal one is torqued to a lower number than the housing itself.
    DIPA[QUOTED] likes this.
  27. Jan 24, 2024 at 9:41 AM
    #177
    1. Remove metal drain plug from housing. Insert plastic drain spigot included with oil filter to drain housing.
    2. Remove spigot. Install metal drain plug with new small O-ring. Tighten metal plug.
    3. Remove housing, replace filter, replace big O-ring on housing.
    4. Install housing and tighten.
    You can skip steps 1 and 2. Faster but potentially more oil spillage.
  28. Jan 24, 2024 at 9:43 AM
    #178
    Yobruhitsme
    Denver
    Ineos Grenadier
    Car care nut on YouTube indicates to not even worrry about the drain plug.. just unscrew the canister and treat it like a single unit
  29. Jan 24, 2024 at 10:50 AM
    #179
    1SilverRunner
    Tejas
    I might try that. Shit's messy regardless lol. I do miss the old single piece filters.
    Although I do have an aluminum housing I'll be upgrading to next oil change. Cheap stamped steel filter wrench cracked my old filter housing's ears off.
  30. Jan 24, 2024 at 10:56 AM
    #180
    Yobruhitsme
    Denver
    Ineos Grenadier
    I hate that forceful insertion and the immediate out pour of oil. I was like what is the f-ing point of this anyways?
