Dealer oil change would be laughable...
Discussion in '5th Gen 4Runners (2010-2024)' started by qcTRDct, Nov 20, 2023.
  1. Jan 17, 2024 at 4:16 PM
    #121
    3JOH22A Toyota Gigolo
    ^Why do you need a jack or jack stands for an oil change? To rotate tires, sure, but a jack isn't necessary for oil. There's enough ground clearance.
  2. Jan 17, 2024 at 4:17 PM
    #122
    HuskyMike
    HuskyMike New Member
    Ah yes... I was rotating the tires at the same time. (Not to mention it was an excuse to buy all that stuff. :) )
    backpacker, Nubes and 3JOH22A[QUOTED] like this.
  3. Jan 17, 2024 at 4:22 PM
    #123
    Which terrorist country are you supporting with $90 oil? :stirthepot:
    Here's a 5L jug of 0W20 full-synthetic for $19. Buy two jugs for $38: https://www.walmart.com/ip/Super-Te...38905?fulfillmentIntent=In-store&athbdg=L1102
  4. Jan 17, 2024 at 4:35 PM
    #124
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Good to know . Just removed that one & added the OEM. It doesn't look like it comes W/Drain plug, I guess you use the one from the plastic original bowl?
    Thank you!!!
  5. Jan 17, 2024 at 4:39 PM
    #125
    I'm not big only 5' 5" and 150 and I'm going to say there is not enough room to change oil comfortably.
    Unless you are lifted.
    I don't even change the filter drain O ring. The drain doesn't even work great and just adds time. I just remove the whole housing and call it a day.
  6. Jan 17, 2024 at 4:42 PM
    #126
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I'm 6'2" W/a belly (not that big but still not like a few yrs ago either:() 236lbs I fit under mine W/out jack at least I did on my 2018 not sure why I wouldn't W/this one either.
  7. Jan 17, 2024 at 4:45 PM
    #127
    I'm 6'0" and change the oil without jacking up the vehicle. I have stock suspension still. :notsure:
    You don't need to get your belly under the oil pan. Just need to get close enough to get eyes on the drain plug to verify it isn't leaking after the job. Likewise you don't want to be directly under the filter cap when you remove it.
    TN_FunRunner and LCJ77 like this.
  8. Jan 17, 2024 at 4:54 PM
    #128
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Nah my plastic got cracked by a lube shop. I eventually put an oem yota aluminum one on. This was all with my old Sienna..
    Now to deal with this fucking canister filter all over again with this 4R
  9. Jan 17, 2024 at 4:58 PM
    #129
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    The metal one on Amazon looks like the drain plug isn't included & re-use the OEM drain plug.
  10. Jan 17, 2024 at 5:00 PM
    #130
    Yobruhitsme
    Denver
    Ineos Grenadier
    Ahh yes.. I used the Dorman drain plug with oem alum canister
  11. Jan 17, 2024 at 5:05 PM
    #131
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Isn't the OEM plug in the plastic one metal. I just checked my old plastic OEM from the my 2018 & it is metal that I can use W/Toyota one I'll order. Thanks again for heads up on leaking. The OEM 1 is actually less expensive but I'm sure I'll have swap the stand pipe.
  12. Jan 17, 2024 at 5:09 PM
    #132
    Yobruhitsme
    Denver
    Ineos Grenadier
    I went from Dorman to oem alu
    plastic was cracked prior to Dorman
    LCJ77[QUOTED] likes this.
  13. Jan 17, 2024 at 5:25 PM
    #133
    Please read again.
    COMFORTABLY
    Every able bodied person should own a jack and stands. If not don't forget your murse when you go out.
    I also sometimes I use the disposable box to catch the oil since I always forget to take my oil container. The box doesnt fit with the flaps up without it jacked up.
  14. Jan 17, 2024 at 5:28 PM
    #134
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    I do own floor Jack & Jack stands. I only use them when I rotate the tires.
  15. Jan 17, 2024 at 5:29 PM
    #135
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I have a great local shop that charges $30 for an oil change. I bring my oil and filter.
    Takes 30 mins, and while we wait for oil to drain completely we have a conversation. He does not speak a word of English and my Spanish is questionable. We both weirdly nod our heads.
  16. Jan 17, 2024 at 5:30 PM
    #136
    You don't rotate every oil change? I do so I jack it up do both at once problem solved.
  17. Jan 17, 2024 at 5:31 PM
    #137
    So he only charges $60/hr? Damn hes ripping himself off.
  18. Jan 17, 2024 at 5:33 PM
    #138
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    That is my price. I think for regular folks it's 75 or something.
  19. Jan 17, 2024 at 5:34 PM
    #139
    Still on the low end but its his business and lucky you.
  20. Jan 17, 2024 at 5:40 PM
    #140
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    75-90 is the going rate for any local shop that changes oil around here.
  21. Jan 17, 2024 at 6:38 PM
    #141
    Talking about able-bodied when you can't get any work done without jacking up a 4Runner? :rolleyes: I got a 3.5-ton hydraulic jack, 3-ton uni-jack, two 6-ton jack stands, and four 3-ton jack stands, but why use them when you don't have to? Jacking up the vehicle doubles the time it takes to do an oil change. Hell, I changed the fluids in both diffs, transfer case, and transmission with tires on the ground. Turn wrenches long enough and you learn to be efficient with your time.
    Nope. Once a year is good enough. If your tires are wearing abnormally, get the root cause addressed rather than trying to "even out the wear" by tire rotation.
    LCJ77 likes this.
  22. Jan 17, 2024 at 8:01 PM
    #142
    Ramps are much less trouble than a jack and jack stands. Drive up, change oil, drive off. Makes moving around under there so much easier.
    gomiami, alittleoff, icebear and 2 others like this.
  23. Jan 18, 2024 at 1:37 AM
    #143
    ReRunner
    ReRunner Fred Berry Enthusiast
    2022 MGM ORP
    It takes more time for the oil to drain than to slide a piece of cardboard along with my fat ass under the truck to remove the skid and plug plate. Why waste time jacking shit up? Thats just way more work and time for nothing.
    LCJ77 likes this.
  24. Jan 18, 2024 at 4:17 AM
    #144
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    The only problem W/ramps is storing them.
    glwood54[QUOTED] likes this.
  25. Jan 18, 2024 at 9:34 AM
    #145
    Got a shelf for that.
  26. Jan 18, 2024 at 9:50 AM
    #146
    I only change oil once a year.
  27. Jan 18, 2024 at 9:51 AM
    #147
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    I see your ramps and jack stands and raise you my storm shelter. It's great having an oil change pit in the garage.
    rickystl, 2Toys, Dillusion and 2 others like this.
  28. Jan 18, 2024 at 9:55 AM
    #148
    Well if you put it that way you win.
  29. Jan 18, 2024 at 10:38 AM
    #149
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Yeah, I'll live in a state where we don't NEED one those!:eek: :cheers:
  30. Jan 18, 2024 at 10:43 AM
    #150
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Yeah between 4Runner/BMW/Harley/ATV/Work Bench/Roll-Away/ATV/Cycle lift/Floor jack/6' step/24' Ext Ladders (hung on ea. side of garage/various smaller wire vinyl coated shelves no room. :confused:.
    That does it:yes: gotta build a new house & the 32x24 garage like I wanted when we built this one vs existing 24x24 one.:bananadance:
