Daytonaviolet’s Blizzard Pearl Build
Discussion in '5th Gen Builds (2010-2024)' started by Daytonaviolet, Nov 29, 2019.
  1. Apr 21, 2020 at 9:51 PM
    #61
    Hwnrunner
    Hwnrunner New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    They say it's just a little extra that makes the difference between ordinary and extraordinary!
    Looks great, how close r u to the BM up front? No rubbing?
  2. Apr 21, 2020 at 10:05 PM
    #62
    Daytonaviolet
    Daytonaviolet [OP] TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    bm ? Bumper ? Ohh I had to trim like 1/2” and push the liner 1/2”. This is the second time I had to cut and push. I did like 1/4” when I first got lifted and the 285’s.
  3. Apr 21, 2020 at 10:12 PM
    #63
    Hwnrunner
    Hawaii
    Sorry, the body mount right beside/behind the front mudflaps. Looks like u still have the mudflaps on from the pics.
  4. Apr 21, 2020 at 11:17 PM
    #64
    Daytonaviolet
    Bay Area, CA
    I didn’t feel any thing rubbing near the bm. I’ll take a closer look tomorrow. Yes mudflaps are still on. Passenger side has a small flap rub, might have to dremel that area.
  5. Apr 22, 2020 at 11:59 AM
    #65
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I just bought a set of these but haven't installed yet. Is this a common issue? Seems like it would be easier to resolve now before install. Thoughts?
  6. Apr 22, 2020 at 12:27 PM
    #66
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    Looks awesome! Great job.:taco:
    Daytonaviolet[OP] likes this.
  7. Apr 22, 2020 at 1:36 PM
    #67
    Daytonaviolet
    Bay Area, CA
    I read about it on another forum. Many have complained for leaking boots and the 2nd washer addresses the issue. Until there’s a boot redesign, all we can do is request another washer from JBA. I held off my install because I waited for the 2nd washer set.
  8. Apr 29, 2020 at 8:54 AM
    #68
    Daytonaviolet
    Bay Area, CA
    BantamEddy and ForRun like this.
  9. May 4, 2020 at 10:57 PM
    #69
    Daytonaviolet
    Bay Area, CA
    Added my new truck emblems :)
    yentup, Harringbr99 and newtotoyota like this.
  10. May 4, 2020 at 11:00 PM
    #70
    Hwnrunner
    Hawaii
    :censored:
    Harringbr99 likes this.
  11. May 4, 2020 at 11:09 PM
    #71
    Daytonaviolet
    Bay Area, CA
    Lol
  12. May 5, 2020 at 8:48 AM
    #72
    daddioman
    daddioman 2020 Nightshade
    Sean
    Park City UT
    2020 4Runner Nightshade
    Tail as Turn Interior LED Ceramic Window Tint
    Nicely done @Daytonaviolet. I just purchased a limited as well for some of the same reasons. Now i need to fix the exterior look. The full front bumper is something I will need to start looking for.
  13. May 7, 2020 at 8:10 PM
    #73
    Daytonaviolet
    Bay Area, CA
    Let me know if you want to see the parts spreadsheet
  14. May 7, 2020 at 8:16 PM
    #74
    Daytonaviolet
    Bay Area, CA
    Installed the JBA UCA today. The red UCA matches well with the TRD springs. Ignore the initial value as the tech aligned it twice and lost the real initial value.
    DrewMan and 4Runner fun like this.
  15. May 9, 2020 at 11:02 AM
    #75
    Daytonaviolet
    Bay Area, CA
    4Runner fun likes this.
  16. May 31, 2020 at 5:49 PM
    #76
    Daytonaviolet
    Bay Area, CA
    I felt like the hatch area lighting was not bright enough. So I added these Amazon LED’s. After some minor trimming, I was able to add two led boards per side.
    Before with small led bulb
    Adding the led boards.
    After trimming the boards
    Splice and solder connector
    Done
    Jaeth likes this.
  17. May 31, 2020 at 5:57 PM
    #77
    Daytonaviolet
    Bay Area, CA
    Before with small leds
    After with two led boards per side
  18. Jun 7, 2020 at 10:11 PM
    #78
    Daytonaviolet
    Bay Area, CA
    Added some logos
    Ricphoto likes this.
  19. Jun 7, 2020 at 10:13 PM
    #79
    Daytonaviolet
    Bay Area, CA
  20. Jun 7, 2020 at 10:13 PM
    #80
    Daytonaviolet
    Bay Area, CA
  21. Jul 1, 2020 at 8:09 PM
    #81
    TWashburn1212
    TWashburn1212 New Member
    2017 White 4Runner TRD Pro
    What size tires were you running when you were running the Cornfed set-up?
  22. Jul 1, 2020 at 8:11 PM
    #82
    Daytonaviolet
    Bay Area, CA
    I’m still running the Cornfed. Tires are 285/70/17.
  23. Jul 1, 2020 at 8:14 PM
    #83
    TWashburn1212
    Any rubbing or issues before the spacers? I have the TRD Pro stock suspension on my '17 and I am looking at adding the Cornfed or similar spacers. Thinking 275 70R17's with no wheel spacers.
    I ran 285 70R17 on my 2014 Tacoma and I was pretty against the idea of spacers at that point, but I just can't get away from how well the Pro rides stock and I want to be a little more mild than my lift on the Tacoma.
  24. Jul 1, 2020 at 8:34 PM
    #84
    Daytonaviolet
    Bay Area, CA
    i actually never ran the 285’s until after I swapped to the trd pro suspension and Cornfed spacers. They all went on same day.
    but I didn’t drive my friends pro without the Cornfed. To me, it rides the same with or without the Cornfed.
    I think with 275 or 285 it will fit without lifting. You’ll just need a lot of of caster and trimming of the bottom part of the bumper and then push the liners forward.
    whatsinaname likes this.
  25. Jul 1, 2020 at 8:41 PM
    #85
    TWashburn1212
    I'm thinking I want to go with a very minimal lift/level and 275 70R17's. I'd really like to avoid cutting, trimming, or substantial alignment adjustments.
  26. Jul 1, 2020 at 8:45 PM
    #86
    Daytonaviolet
    Bay Area, CA
    I think you’ll be fine with the 275’s and stock pro height. It depending on your caster, you may get a slight rub on your front flaps. You can either increase the caster (has no effect ok tire wear), flatten the flaps with a heat gun or just remove the front flaps.
  27. Jul 1, 2020 at 8:51 PM
    #87
    TWashburn1212
    I really do like your stance. Love the idea of taking the Limited to Pro status. Ton of work, well done.
    I'm going to do some research into leveling kits/suspension spacers. I'm sure there are other options other than Cornfed.
  28. Jul 1, 2020 at 9:03 PM
    #88
    Daytonaviolet
    Bay Area, CA
    Thanks for the kind words. If I were to do it again, I would look into Westscott Design. They make a spacer lift which utilizes the bottom perch. It doesn’t even look like a spacer. Unfortunately, they were not around last year when I was finding all my parts.
    TWashburn1212[QUOTED] likes this.
  29. Aug 8, 2020 at 9:17 PM
    #89
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Wow! Awesome project! This is such a great resource for Limited owners -- thanks!
  30. Aug 8, 2020 at 10:40 PM
    #90
    Daytonaviolet
    Bay Area, CA
    I have a Limited to TRD parts list when your ready :)
