Dasaita Android Headunit Installed
Discussion in '5th Gen 4Runners (2010-2024)' started by SummitBound, May 25, 2021.
  1. Sep 28, 2021 at 1:19 PM
    #91
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    Extra settings
  2. Oct 18, 2021 at 8:27 PM
    #92
    jmperez64
    jmperez64 New Member
    2019 SR5 Premium
    I have had my Dasaita for over a year and have not had any issues with it. Got it mainly for CarPlay, but as I have learned the Android OS, have mostly stopped using CarPlay and run the headunit in the native (Android) OS. Love the speed and customization it provides. In your original post, you made this comment: "love the ability to pull the rear camera up anytime as I had the anytime camera button in my Tacoma and loved it"
    I'm assuming that you can turn on the rear camera anytime based on this comment. If so, how did you activate this feature? I've looked and haven't found a way to do this. TIA
    DrewMan likes this.
  3. Oct 19, 2021 at 3:12 PM
    #93
    SummitBound
    SummitBound [OP] New Member
    Greenville, SC
    2019 T4R OR
    There’s an app that came installed on it called “F-Cam” (pictured). When you pull that up, it defaults to your front camera if you have one installed. Just click that little camera thing on the left side and it’ll flip to rear
    MeefZah and DrewMan like this.
  4. Oct 20, 2021 at 4:15 PM
    #94
    Crossfit4Runner
    Saint Louis
    To many to list
    Mine doesn’t have that app.
  5. Oct 20, 2021 at 6:15 PM
    #95
    jmperez64
    2019 SR5 Premium
    AWESOME!!!! The button originally wasn't there, but I activated the front camera through the settings and the button appeared and now it works!!!! I don't know how many times I have wished I could activate the rear camera while driving because the cargo area is full and I can't see out the rear view mirror. Thanks so much for the help!!!!
    DrewMan and SummitBound[OP] like this.
  6. Oct 20, 2021 at 6:18 PM
    #96
    jmperez64
    2019 SR5 Premium
    Mine didn't either, but then I went into the factory settings and enabled the front camera and the button appeared after I restarted the unit.
    Go into settings, select Car, then Factory Settings, Code 126, select the last menu option at the top of screen which is "Other", then scroll down till you see the front camera option and activate it from the drop down menu. Worked for me.
  7. Oct 20, 2021 at 6:20 PM
    #97
    jmperez64
    2019 SR5 Premium
    I have not made any system or MCU updates since I bought it, as everything has worked fine. Have you? If so, where can I find the latest updates? I've tried contacting Dasaita but they have not replied.
    SummitBound[OP] likes this.
  8. Oct 21, 2021 at 10:14 AM
    #98
    SummitBound
    Greenville, SC
    2019 T4R OR
    I haven’t - I honestly haven’t checked but I will soon
  9. Oct 21, 2021 at 12:32 PM
    #99
    Bobafett
    Bobafett New Member
    Philly area
    2021 Army Green Trail Edition 4x4
    They’re posted on the website. Open the menu and select Forum. Down the bottom under after sales support is firmware download.
  10. Oct 22, 2021 at 5:46 AM
    #100
    jmperez64
    2019 SR5 Premium
    Well, went to the forum mentioned above, and I used the links that are listed in the Dasaita forum. They worked, but on the 1st try, it locked up my unit and I had to do a factory reset. Luckily, this worked. I then tried the update again and it took. Everything seems to be working. All I need to do is re-install all my apps. Unfortunately, I did lose some data for a mileage app that I use when delivering. Good part, I can now split screen!!!
  11. Oct 22, 2021 at 9:16 AM
    #101
    Crossfit4Runner
    Saint Louis
    To many to list
    What got updated? When I emailed them about it they didn’t recommend it. I finally got mine working the way I like it. The radio reception still sucks but everything else works.
  12. Oct 22, 2021 at 9:53 AM
    #102
    SummitBound
    Greenville, SC
    2019 T4R OR
    Do you have that little antenna connected on the back of the unit? I use Spotify so don’t use the radio, but I did test when I installed and it came through fine. Mine very well may be spotty too haha and I just haven’t used it enough to know!
  13. Oct 22, 2021 at 10:01 AM
    #103
    Crossfit4Runner
    Saint Louis
    To many to list
    Yes I have everything connected. The little antenna is the WiFi antenna. I believe it’s the way they convert the oem connection to connect to theirs. Sometimes it comes if great others it’s spotty. I’ve gone to using the XM app or Spotify. The one local station I like has a app so I use that too.
  14. Oct 22, 2021 at 12:07 PM
    #104
    DVS1
    DVS1 New Member
    Ray
    Oahu, HI. to Tampa, FL.
    18 TRD Off Road Premium w/KDSS
    Fuzzy dice
    Nice write up SummitBound
    With new head unit, do you still retain compass direction? Located in instrument cluster next to millage and temperature display.
  15. Oct 22, 2021 at 1:11 PM
    #105
    SummitBound
    Greenville, SC
    2019 T4R OR
    Let me look next time I’m in it. I put this in within a week or two of picking up my 2019 (used) a few months back so I probably never noticed a compass!
  16. Oct 22, 2021 at 2:57 PM
    #106
    jmperez64
    2019 SR5 Premium
    Not quite sure. I do get to split the screen now, which wasn't available before. Of course, the app has to support split screen. Really haven't had a chance to mess with it so far, other than driving to work. My radio reception is fine, but I've never had an issue with it. CarPlay, wifi, bluetooth all connected without any issues, but I've never had an issue with that either. Only thing I really wanted was the split screen option so I could have my delivery app open along with my navigation as I was making deliveries. Hope it works.
  17. Oct 22, 2021 at 2:59 PM
    #107
    jmperez64
    2019 SR5 Premium
    Does anyone have the Android version of Apple Music? If so, is the screen cut off? I was hoping the update would fix this issue, but it didn't. :-(
  18. Oct 22, 2021 at 3:04 PM
    #108
    jmperez64
    2019 SR5 Premium
    Try at your own risk. I had to factory reset mine after this install. Re-installed and it's working so far. I'm an Apple person, but techie enough to try new stuff out. So if it doesn't work for you, I probably won't be able to help.
    These are the links Quick Yuan sent from Dasaita for the updates after I inquired:
    link for MCU 3.78 3.78:https://www.dropbox.com/s/3hd3ci3rp07ddnt/dmcu.img?dl=0
    link for firmware
    HA3_rk3399_10.0_ota(20211015)
    https://www.dropbox.com/s/35ymf7k1bwddcpo/HA3_rk3399_10.0_ota(20211015)升级包.zip?dl=0
  19. Oct 23, 2021 at 4:55 AM
    #109
    SummitBound
    Greenville, SC
    2019 T4R OR
    I do not see any compass details on mine. I forgot to snag a picture but I will next time I’m in
    DVS1[QUOTED] likes this.
  20. Oct 23, 2021 at 3:02 PM
    #110
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    For those that have purchased this head unit to replace the factory OEM (Panasonic) … How do you feel about not having the CD/DVD Player anymore? … I’m just curious? … think that’s the only thing holding me back on replacing mine.
  21. Oct 23, 2021 at 3:05 PM
    #111
    Crossfit4Runner
    Saint Louis
    To many to list
    I rarely used mine to be honest so I don’t miss it. The biggest inconvenience for me is I can’t channel surf anymore. I’ve been using CarPlay almost exclusively and like it.
    DrewMan[QUOTED] likes this.
  22. Oct 23, 2021 at 3:09 PM
    #112
    Crossfit4Runner
    Saint Louis
    To many to list
    Mines running so well I hate to jinx myself by trying to update.
    jmperez64[QUOTED] and DrewMan like this.
  23. Oct 25, 2021 at 7:12 AM
    #113
    Bobafett
    Bobafett New Member
    Philly area
    Has anyone figured out how to make it NOT cut off the radio volume when reversing?
    I drove into the settings and found two things that I thought might be related. One is prohibit reversing and your choices are enable or disable. If you disable it, it just doesn’t allow the camera to come on at all.
    There was another setting, I forget what it’s called because I’m not in the car right now. It was like annunciation -9 or -10 volume when reversing or something like that. I’ve tried all of those to no avail. Any help would be greatly appreciated.
  24. Oct 25, 2021 at 7:36 AM
    #114
    Crossfit4Runner
    Saint Louis
    To many to list
    Yes
    Under settings/car / extra settings reverse volume on
  25. Oct 25, 2021 at 8:43 AM
    #115
    Bobafett
    Bobafett New Member
    Philly area
    I don’t have reverse volume on. I have sound attenuation -10, -9 or off. All three settings seem to have the same effect which is volume off
  26. Oct 25, 2021 at 8:54 AM
    #116
    Crossfit4Runner
    Saint Louis
    To many to list
    You need to turn it on
  27. Oct 25, 2021 at 10:22 AM
    #117
    Bobafett
    Bobafett New Member
    Philly area
    I tried all three settings. -9, -10 and off. No change in behavior. There is no “on”.
  28. Oct 25, 2021 at 11:06 AM
    #118
    Bobafett
    Bobafett New Member
    Philly area
    Maybe this is canbus related? Would someone mind sharing their canbus selection…
    Here’s my current selection as a came from Dasaita. Everything else seems to be working.
  29. Oct 25, 2021 at 11:31 AM
    #119
    jmperez64
    2019 SR5 Premium
    Your images are not showing, but yes, the reverse volume needs to be on. Will need to check the canbus selection when I'm in the car.
  30. Oct 25, 2021 at 2:10 PM
    #120
    Crossfit4Runner
    Saint Louis
    To many to list
    Mine is just sent to on and it works fine I’ll did Into it later.
