Cracked Appearance On Front Of New Engine
Discussion in '5th Gen 4Runners (2010-2024)' started by Newrnr, Mar 5, 2024.
  1. Dec 29, 2024 at 9:29 PM
    I'm guessing you didn't read any of the other posts in this thread...
    java, 2016SR5P and icebear like this.
  2. Dec 29, 2024 at 9:45 PM
    Gigi
    Gigi New Member
    2024 White 4runner TRD ORP
    I did read the thread lol. I was just wondering if anyone actually were advised from the dealer on this? Any additional info on this topic would be great Thanks!
  3. Dec 29, 2024 at 11:04 PM
    icebear Recovered Kia Owner
    There’s nothing to be gained from going to the dealer, if any work is done it’ll be unnecessary and then you’re depending on the tech doing the work properly.
    Or it’s deemed normal and you get on with your day.
    You’ll see it’s extra metal on top of the surface and not into it so hey, you got some extra aluminum for your dollar!
  4. Dec 29, 2024 at 11:05 PM
    7th District
    7th District New Member
    Northern Michigan
    ‘22 SR5 Premium
    Agreed.
    After +40,000 miles the cover on my 2022 SR-5P looked as smooth as the one above.
    These 2 photos below are of my 2024 ORP the day I took delivery of it, with 40 miles on the clock.
    It sort of bugs me, but I’m not losing sleep over it, or enjoying my 4Runner any less.
    I would be curious if I could take it off and have it powder coated or painted. I think a black crinkle finish would be sharp. Albeit no one would see it.
  5. Dec 30, 2024 at 12:23 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Holy cow. Curiosity killed the cat. So, I popped the the hood on my T4R and took a look at the front of my engine, including the areas that Newrnr (OP) and other members photographed in their pictures above. Scrutinized mine good.
    Some of you say this is normal???? Man, I wonder.
    I don’t see cracked appearances in the metal like that anywhere in those areas on my engine. (2022 SR5 Premium 4WD)
    We have a neighbor with a 2021 T4R. I’ll take a look at his with him some day soon and report back here on what those areas of his 4.0 engine looks like.
  6. Dec 30, 2024 at 3:32 AM
    Startrek
    Startrek New Member
    "I would be curious if I could take it off and have it powder coated or painted. I think a black crinkle finish would be sharp. Albeit no one would see it." - go ahead
    7th District. don't forget to shoot 4 hours video for tube
  7. Dec 30, 2024 at 4:40 AM
    Oakboro, N.C
    Few passes with some 220 will smooth it up a fairly good bit.
  8. Dec 30, 2024 at 6:18 AM
    Lucky9924
    Lucky9924 New Member
    1999 and 2024 TRD ORP
    My 24 ORP has those cracks. I posted about it here.
    My 1999 doesn’t but it’s also very dirty and didn’t clean it too much to inspect very close.
  9. Dec 30, 2024 at 6:25 AM
    I would imagine they should be referred to as visible lines, as they aren't really cracks.
  10. Dec 30, 2024 at 6:49 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Yeah, they're strength lines, lol.
    As others have said, since they're raised, it's actually the mold (at Toyota / supplier) that has small cracks / grooves. Someone pointed out that this is a low-stress application as the timing chain cover, so Toyota probably uses a relatively cheap aluminum casting process for this part.
  11. Dec 30, 2024 at 6:52 AM
    Schlappesepple
    2020 ORP
    Since this cover is known to leak oil when improperly installed, and very labor intensive to replace, that would be insanity.
    Also, I don't know if you've actually painted uneven surfaces like this before, but even a rough coat (like bedliner-type finish) can make the lines even more visible.
  12. Dec 31, 2024 at 8:49 AM
    UncleShorty
    UncleShorty New Member
    Those are not cracks. Cracks go INTO metal, they don't come out of it.
    Those marks are from cracks in the die and are normal.
    Gigi and icebear like this.
  13. Dec 31, 2024 at 4:12 PM
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Now I am going to have to take a close look at my 2024 4Runner tomorrow!
    Hope I don't drink too much tonight!
    Happy New Year.
    2025-Strap in, Sit down, and Shut Up!
  14. Dec 31, 2024 at 4:23 PM
    Is that where my Diet Coke Cans go?
  15. Dec 31, 2024 at 4:48 PM
    ^Negative. Diet Coke cans go to casting Pro wheels.
    McSpazatron and whippersnapper02 like this.
  16. Jan 2, 2025 at 3:51 PM
    A junked cover like this would make for some nice wall art!
  17. Jan 2, 2025 at 6:34 PM
    ^Frame the water pump gasket and hang it on your wall, see what people say :D
  18. Jan 2, 2025 at 6:40 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I mean, modern art with phallusophical twist?
    Philosophical… I meant philosophical.
    McSpazatron likes this.
  19. Jan 3, 2025 at 5:49 AM
    #49
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Wish we could create an auto-reply of this comment for all future posts containing “engine cracks” in the title.
    Because you know that even ten years from now, someone will buy a used ‘23 SR5 with 275k miles on it, and still ask about the “cracks” he discovered on the engine after he got it home…
  20. Jan 3, 2025 at 9:20 AM
    #50
    That's when we tell him to T24-swap it for the turbo noises
    https://www.instagram.com/reel/Cz9aQazPLTB/
  21. Jan 5, 2025 at 10:11 PM
    #51
    ZOOMA-LOOM
    ZOOMA-LOOM New Member
    Right out of sight of Scottsdale
    2024 0RP
    In the casting industry the raised lines or "veins" are called "SPRUE" or casting veins. The veins protrude above the surface & cause zero concern, Perfectly normal & only cosmetic. If the Veins were inward into the surface that would still be OK as long as it passes the tolerances of depth Toyota accepts. Look for signs of oil seepage. The timing chain covers are inspected after casting & prior to the final machining of the cover. Any questionable casting are culled during first inspection coming out of the casting phase. Again, nothing to be concerned with, purely cosmetic, now get back to the concern about the oil change intervals & what oil is best;)
    McSpazatron and icebear like this.
