Covering Maxtrax on the roof?
Discussion in '5th Gen 4Runners (2010-2024)' started by Gamma Ray, Jan 30, 2023.
  1. Mar 31, 2023 at 4:16 PM
    auspilot
    auspilot Old Member
    2020 TRD OR
    Dobs IMS, lots of small stuff
    I bought a set back in November and have been happy with them. There's plenty of space between the front fairing bar and the roof, over 1/4-inch. No noticeable wind noise up to 80mph, and the bars are rock solid.
    donnermel likes this.
  2. Mar 31, 2023 at 5:01 PM
    Gamma Ray
    Gamma Ray [OP] Be excellent to each other
    2020 SR5 Barcelona Red
    Click on the pic for a higher resolution version so you can see better the details. Unlike the pics above, mine came with weather stripping that you slid onto the integrated wind fairing crossbar. I had to cut it down to size, but it wasn't bad. I don't know if they just began including the weather stripping. I got mine in February.
  3. Mar 31, 2023 at 6:11 PM
    auspilot
    auspilot Old Member
    2020 TRD OR
    Yeah, I got the weather stripping with mine too. I chose not to use it because others have reported having grit lodged between the weather stripping and the roof that abraded the paint.
  4. Mar 31, 2023 at 6:13 PM
    Gamma Ray
    Considering I had 10 years of "WHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOSH!!!!!!!!" with my previous Jeep, I'll live with a little paint imperfection if it means the sound is reduced.
  5. Apr 1, 2023 at 6:49 AM
    I recently test drove a Wrangler out of curiosity, and the wind noise was... impressive.
  6. Apr 1, 2023 at 8:00 AM
    Thanks for the pics. Looks like plenty of room under there.
    Thank you. Crossbars look good. So you opted for the front windfairing bar and one wide bar for the rear, no center?
  7. Apr 1, 2023 at 8:44 AM
    Gamma Ray
    Yes. I later put on a Rotopax on the double wide.
    I might eventually get a Rago stock rail awning mount and a basic awning. I don't care about having much more up there.
  8. Apr 1, 2023 at 1:06 PM
    Agoge Clash
    Agoge Clash New Member
    2022 Off-Road Premium - White
    I like that set-up there. Where did you get the cross-bars allowing you what looks like easy ability to add stuff securely?
    Thanks
  9. Apr 1, 2023 at 1:15 PM
  10. Apr 1, 2023 at 1:18 PM
    Gamma Ray
    I can't tell exactly what those crossbars are since they're low res pics, but this is what I use. It's a similar setup, especially when it comes to the Maxtrax mounts.
    Integrated wind fairing in the front front: I got the stainless steel version: https://lfdoffroad.com/collections/...ng-ruggedized-crossbar?variant=32547169730596
    The crossbar I use in the rear. I got the stainless steel and wide version in order to mount the Rotopax mount. https://lfdoffroad.com/collections/...dized-crossbar-5th-gen?variant=39984512499748
    Maxtrax MKII and mounting pins. I have the orange color and the 40mm mounting pins, though you could get away with the 17mm mounting pins. There is plenty of clearance for the 40mm ones, but it makes it harder to get the pins on the crossbars. You'll need some deep sockets. On the other hand, you could potentially use the extra thread protruding downward for fashioning your own mount of sorts to carry something under the Maxtrax. Check out the combo deal: https://maxtraxus.com/collections/maxtrax-mkii-recovery-boards
    After you get the Maxtrax and the pins, go to Home Depot or whatever and get some small locks and a hefty pair of needle nose pliers. They'll keep your Maxrax safe and secure when you have the knobs on the pins turned into the securing position, and the pliers will help you turn the knobs because they can be hard to turn. You could potentially loosen a screw on the top of the pins, but I wouldn't recommend it.
  11. Apr 1, 2023 at 1:21 PM
    Agoge Clash
  12. Apr 4, 2023 at 12:11 AM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    How easy is it to mount the roto to the wide bar?
  13. Apr 4, 2023 at 3:33 AM
    Gamma Ray
    Decently easy, even while the bar's attached to the 4Runner. It still involves some turning your hands upside down to get the nuts onto the threads of the bolts, but it's not bad. It's a lot easier when you simply get the nuts and bolts started when the bolts aren't put all the way through the Rotopax mount. Get them started and then you can get a socket wrench in there and finish it up.
    donnermel[QUOTED] likes this.
  14. Apr 4, 2023 at 7:01 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Victory 4x4. They are universal cross bars and you can add as many as needed to the stock rack. In my case i just needed 2 and the universal mounts were perfect since i like to fabricate things. Very low profile, adds no height.
    https://www.victory4x4.com/product/V4RRK-CS.html
  15. Apr 10, 2023 at 7:34 AM
    Ripper238
    2019 TRD OR
    I personally prefer the East Coast. Just got to go out and find it:
  16. Apr 10, 2023 at 7:56 AM
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    Maxtrax may not be affected by UV, but Rotopax sure will. We used rotopax for decades on our SAR vehicles, and every single one of them eventually bulged to the point of being almost impossible to mount, became pink and see-through, and began leaking like nobody's business. And we were in a forested area for the most part, and when the ATV's are stored outside, they are under huge solar panels. I'll never buy Rotopax for personal use. For me it's Wavian Jerry cans and Scepter water cans.
  17. Apr 10, 2023 at 2:23 PM
    Gamma Ray
    I'm starting out with the Rotopax water containers and seeing how it goes. Realistically, I'm not going to see much use for much of this stuff. By the time I get a Rigd or whatever else spare tire swingout thing (this shows how much I'm going to be using this stuff, being able to take it off would be a big plus for me) I'll have a better idea for what I'm going to do. I have considered getting the jerry can attachment for fuel.
    If the Rotopax water containers fail, I'll just have a good spot to put more Maxtrax :cookiemonster:
    R1200Jedi[QUOTED] likes this.
  18. Apr 11, 2023 at 8:44 PM
    Aceofnone82
    Aceofnone82 New Member
    Love the pics. Is that the South Portland lighthouse and the white mountains by any chance?
  19. Apr 11, 2023 at 9:18 PM
    #49
    R1200Jedi
    2022 4Runner ORP
    you quoted my post by accident. ;) Sorry, I couldn’t tell you which lighthouse. :D
  20. Apr 11, 2023 at 9:19 PM
    #50
    Aceofnone82
    Oops
  21. Apr 11, 2023 at 9:19 PM
    #51
    Aceofnone82
    Ripper238[QUOTED] likes this.
  22. Apr 14, 2023 at 7:31 AM
    #52
    Ripper238
    2019 TRD OR
    Yes it is, the most photographed light house in the world I believe.
    I did a long trip hitting Baxter state park, white and green mountains all along the AT - NY, VA, WV, NC, SC, to TN and smokie mountains during Covid.
    BTW that fist photo of the "New river" in WV is 260-325 million years old.
  23. Mar 29, 2025 at 10:55 AM
    #53
    AntonioCm1983
    AntonioCm1983 New Member
    Antonio
    AZ
    97 LTD 4runner, 99 LTD 4Runner, 00 Sr5 4Runner, 00 LTD 4Runner, 02 Sport 4Runner, 07 Sport 4runner V8, 05 Excursion V10,
    Headlights taillights led conversions cold air intake engine mods bigger pistons cams lift kits big tires tones more leds inside and out
    I haven't shuffled my boards at all I have had them on my rig 2 and a half years now and no issues with fade I have the olive drab color and I have 4 boards on my rig I have mine on the Front across my sherpa Princeton rack. No fade issues there very stable on uv
  24. Mar 29, 2025 at 11:33 AM
    #54
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Do you notice much wind drag interstate speeds mounted in front? What are poles in rear? Don't think I have seen a setup like tgis.
  25. Mar 30, 2025 at 11:20 AM
    #55
    UncleShorty
    UncleShorty New Member
    MANY years ago I went to Australia to look at putting a transmission line into a site the company wanted to build on.
    Me, in US Engineer "uniform", tie, dockers and loafers, met the Aussie Engs in their "uniform", tee shirts, shorts and nikes...
    The proposed right of way ran through a mangrove swamp. We went to look at routing. I asked the Aussie Eng if I could "walk down in there."
    He said, "Sure. But I wouldn't." "Why", I asked. He grinned and said, "In Australia if it looks like they might be a crocodile down there, there is."
    Worked with lots of Aussies during my career as a Professional Engineer. They were all, what we call in Texas, Good Old Boys.
    I could live in Australia, they've got guns, 4Runners and beer... lots of beer...
  26. Mar 30, 2025 at 11:29 AM
    #56
    Ripper238
    2019 TRD OR
    I thought they took all the guns in the late 90's?
  27. Mar 30, 2025 at 11:54 AM
    #57
    According to Google Lens, they are LED whips, good for desert runs and "takeovers":
    https://www.instagram.com/reel/DHPKEIQuOkG/
