Coolant Low on a 2018 4runner
Discussion in '5th Gen 4Runners (2010-2024)' started by samipaigekelly, Nov 8, 2020.
  1. Sep 4, 2023 at 3:12 PM
    Lost-Again
    Lost-Again New Member
    2018 TRD Pro
    None yet.
  2. Dec 16, 2023 at 5:56 PM
    Don1
    Don1 New Member
    Any update?
    I bought my 2019 4runner with 56k miles. After couple months of using the car (multiple long trips above 4 hours), realized that the coolant level in reservoir was below “L” line, just like yours. The engine never overheated, even in hot weather. I did a test to check the head gasket, turned out fine. I did a flush & fill with new coolant, topped reservoir at “F” line.
    After couple hundred miles has started to drop a little.
  3. Dec 17, 2023 at 7:59 AM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    Every Toyota I've ever owned has very slowly used coolant. I think maybe evaporation.
    Technologic80 and Don1 like this.
  4. Dec 18, 2023 at 9:43 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    How exactly did you do a flush and fill?
    Don1[QUOTED] likes this.
  5. Dec 18, 2023 at 10:23 AM
    Startrek
    Startrek New Member
    you don't flush, proven no benefits to it. drain radiator from drain valve, once it stopped, close valve (have to say that) and fill it roughly same amount (using special funnel from AutoZone). 1Gal from Dealership.
    Mully410 and Don1 like this.
  6. Dec 18, 2023 at 10:30 AM
    Don1
    Don1 New Member
    My bad. I meant to say I drained the coolant and filled it with the same amount, burped the air out.
  7. Dec 18, 2023 at 10:36 AM
    Rocko9999
    2011 Limited
    When I did my drain and fill and new thermostat, even after I burped it, it took about 500 miles before all the air got out and the level stopped dropping.
    raimieb likes this.
  8. Dec 18, 2023 at 10:52 AM
    Don1
    Don1 New Member
    Interesting. I guess I’m going to observe it for a while.
  9. Dec 18, 2023 at 10:55 AM
    Rocko9999
    2011 Limited
    Yeah, even took it to a reputable shop and they burped it after 200 miles of my drain/fill. They got some bubbles. I put blue masking tape to measure cold level. Stop moving like I said around 500ish miles. I of course verified there was no leaks, etc.
    JS222STL and Don1[QUOTED] like this.
