Cool air intake
Discussion in '5th Gen 4Runners (2010-2024)' started by WhoDoiFollow, Jun 15, 2019.
  1. Jul 2, 2019 at 5:47 PM
    Well, an example, one of my plastic chambers on the underside of the intake always contains water. Is it for cooling or maybe added moisture. Or is it just a vapor catch? They didn’t install them for no reason. Others prob add as a reserve for quicker acceleration.
  2. Jul 2, 2019 at 6:08 PM
    They have something to do with atmospheric pressures inside the intake tube. If you blow air you create moisture. Suck air and none is created...
  3. Jul 2, 2019 at 6:14 PM
    For instance. My Honda CR 80, a fast as hell 2-stroke dirtbike with a kick-ass powerband I had growing up. I installed a power adder, all it was was a hose and a hollow canister you mount before the power reeds/ carb on the intake tube.
  4. Jul 2, 2019 at 6:34 PM
    Charlievee
    Charlievee Not new member.
    I don't follow, not a pro on blowing or sucking. A combustion engine suck air...now a super charger blows. Not sure where the moisture issue comes in, unless it's sucked in from the fender. Once drove in a blizzard, that fine Champaign powder blowing around that one couldn't see past the windshield. After awhile the snow filled the airbox and the motor stopped breathing. Cleaned it out and it was good to go. Granted that was a good old Ford 351w. Who knows how these TuRDs run.
    WallyT4R likes this.
  5. Jul 2, 2019 at 7:40 PM
    WallyT4R
    WallyT4R New Member
    After some research, found this...
    The resonator itself couldn't be simpler in design; it's basically just an expansion chamber or wide spot in the otherwise-smooth intake pipe. It may or may not contain some kind of baffle or plate, depending upon the design and the intent of the designers. Resonators come in two types: In-line resonators are open chambers that sit in the intake tube, while side-branch resonators are chambers that sit next to the tube and are connected to it via a small duct or channel (ours).
    The Common Misconception
    Most hot-rodders and car enthusiasts think of intake resonators as simple mufflers in the intake tube, devices designed to siphon all the awesomeness out of a car's sound track to appease soccer moms and senior citizens. That makes it a prime candidate for the "chuck-it" school of auto modification. After all, it's basically just a plastic tumor growing off of a tube that should by definition be as smooth and blemish free as possible. While sound control is indeed part of the resonator's job, the sound control itself is really more of a side effect of its primary purpose.
    Pressure Wave Harmonics
    Air flowing into your cylinder head's intake port doesn't move in a straight line while the valve is open, then politely stop in its tracks to await another valve opening. When the valve closes, the moving column of air slams into it, then compresses and bounces back like a spring. This pressure wave travels backward at the speed of sound until the intake runner opens up or it hits something, and then it bounces back toward the cylinder. This is the "first harmonic." The pressure wave actually bounces back and forth two or three more times before the intake valve opens again.
    Intake Tube Pulses
    The resonator in your intake is technically known as a Helmholz resonator, an acoustic device used to control pressure wave harmonics. Air bouncing back out of your engine and into the intake tube doesn't do it in a single pulse the way it would in a single intake runner; the multiple pistons put out pressure waves at their own intervals, and some of those are going to try to bounce back in while others are going out. The result is a "clog" or high pressure area in your intake tube that ultimately limits airflow through almost the entire rpm spectrum.
    The Resonator
    Adding an expansion chamber to the intake tube forces air coming back out of the engine to slow down to fill the cavity, thus expending a great deal of its energy and slowing the pressure wave reversion. This slowdown allows fresh air to flow toward the engine without fighting pressure reversion waves the entire way, thus aiding in cylinder filling. Since these pressure waves are essentially sound, giving them a place to expend their energy before exiting the air filter box ends up dampening the intake noise and quieting the engine. Thus, the resonator helps to make the engine paradoxically quieter and more powerful.
    nimby and Firefly21 like this.
  6. Jul 2, 2019 at 8:06 PM
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
    [QUOTE="WallyT4R[/QUOTE]
    I've found that article too. I would argue that all AF intakes defy that explanation as they are just basically a straight pipe and a giant air filter.
  7. Jul 2, 2019 at 9:36 PM
    Pressure waves and tube pulses are the same for exhaust. But one point is if you look at the intake runner in the head. You would think it’s as smooth as glass, but it’s not, it’s rough. That’s because the air has to be disturbed for a correct air/fuel mixture and better combustion...
  8. Jul 3, 2019 at 6:16 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    I'm with the "hot air intake" guy. Probably loose power with every day driving/use.
  9. Jul 3, 2019 at 7:24 AM
    PaulB-2006 T4R
    PaulB-2006 T4R New Member
    Paul
    Twin Cities, MN
    2016 Trail MGM
    Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. All LED interior. Mud flaps deleted. TRD Air Filter. TRD Oil Cap. Heated Front Seats. FJC Shifter. Subaru Kicker tweeters.
    Stock Gen4 & 5 4Runners, the outside (cold) air comes through the fender into the air filter then on into the engine. The TRD Cold Air Intake , S&B Performance intake kit and aFe Magnum Force Cold Air Intake all pull the cold air from the fender thus SR5 Limited's comment about factor CAI. What this thread is about is removing the baffles to reduce air turbulence and get more direct to the intake.
    Compromised 4Runner likes this.
  10. Jul 3, 2019 at 2:15 PM
    PaulB-2006 T4R
    Paul
    Twin Cities, MN
    2016 Trail MGM
    What did you do with the crank case vent?
    ManBeast likes this.
  11. Jul 3, 2019 at 7:37 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Yea, doesnt that plug into one of them?
  12. Jul 4, 2019 at 10:10 AM
    Charlievee
    TRD cold air kit?
  13. Jul 4, 2019 at 10:12 AM
    Charlievee
    Threaded brass fitting with an 1/8" hose barb. Tapped into one of the plugs.
  14. Jul 5, 2019 at 1:01 AM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Got a pic?
  15. Jul 5, 2019 at 7:32 AM
    Charlievee
    1/8" barb x 1/mip used a 1/2" drill bit and forced it in with a ratchet, bit by bit. Would be better to use a tap i guess. Clean the debris from the inside add some rtv or teflon tape. Little bit of work for no gains.
    PaulB-2006 T4R likes this.
  16. Jul 5, 2019 at 7:57 AM
    PaulB-2006 T4R
    Paul
    Twin Cities, MN
    2016 Trail MGM
  17. Jul 5, 2019 at 8:23 AM
    san diego native
    san diego native New Member
    Kore
    Bonsall Ca 92003
    5th Gen White 4Runner
    Magnaflow Exhaust, Pedal Commander, TRD CAI, Baja Designs Squadron R Pro, N-FAB Runners 3" main tube
    I parted out the TRD CAI from camelbacktoyota. Spent 329 for parts and shipping.
    https://parts.camelbacktoyota.com/parts
    Part numbers needed:
    PTR03-35090-AA
    PTR03-35090-AC
    PTR03-35090-AF
    PTR03-89100-AA
    PTR03-89100-AB
    PTR03-34071
    PTR43-00083 (TRD Oiled Air Filter)
    Google a few videos on how to piece it all together and your good. Here is one of the videos i used theres a few more that go with it https://www.youtube.com/watch?v=WNR_ASVXbSo
  18. Jul 5, 2019 at 11:45 AM
    Compromised 4Runner
    2018 4Runner SR5
    Funny how buying it this way saves you $80-120.
    ManBeast and Charlievee like this.
  19. Jul 5, 2019 at 12:21 PM
    #49
    Compromised 4Runner
    2018 4Runner SR5
    The what now?
  20. Jul 5, 2019 at 12:43 PM
    #50
    Charlievee
    I take it he is questioning the vacuum line.
  21. Jul 5, 2019 at 1:37 PM
    #51
    Compromised 4Runner
    2018 4Runner SR5
    Looks like another trip to the depot for me! Was gearing up to do this tomorrow.
  22. Jul 5, 2019 at 4:21 PM
    #52
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Ill probably give it a try. Whats that vacuum line do?
  23. Sep 19, 2019 at 9:59 AM
    #53
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    I finally got around to doing this. Nice little sound for 4 bucks
  24. Sep 19, 2019 at 10:01 AM
    #54
    Compromised 4Runner
    2018 4Runner SR5
    Pix or it didn't happen. I bought it all. Then realized it is hot AF out and returned them.
  25. Sep 19, 2019 at 10:42 AM
    #55
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    Lmao. I havent plumbed in the vacuum line yet
  26. Sep 19, 2019 at 12:51 PM
    #56
    Compromised 4Runner
    2018 4Runner SR5
    Yeah, my wife complains about that too!
