Changing oil every 2,000 miles
Discussion in '5th Gen 4Runners (2010-2024)' started by gowithtoyota, Dec 28, 2022.
  1. Jun 26, 2023 at 3:15 AM
    #91
    broken-giver
    broken-giver BFD
    Lol. if you ask me 2K is kinda risking it :p
  2. Jun 26, 2023 at 9:40 AM
    #92
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    LOL !! I too am old enough to remember those days. Those old VW air-cooled engines used straight 30 motor oil. Yes, 2.5 quarts in the engine. The left over half-quart was used in the oil bath air cleaner. Actually, the Factory recommended oil change interval was every 1500 miles (not a mis-print). With every 3,000 miles changing the oil and oil screen. Also at 3,000 miles a complete tune-up: Plugs, plug boots, points, condenser, rotor, distributor cap, and checking/setting all the valves (they were solid lifters). We use to set the distributor dwell/timing using a 12V light bulb with a pigtail. LOL These engines were late 1940's technology and were real maintenance hogs.
  3. Jun 26, 2023 at 10:18 AM
    #93
    backpacker
    backpacker New Member
    2023 TRD ORP
    When my wife was given a '68 Beetle in the mid-80s, she had no idea what a PITA it would be. The 1500 mi oil change with the six nuts and the metal screen were the easiest part. I had to rebuild the entire brake system and suspension on a gravel driveway in a sub-zero Iowa winter. It had an aftermarket starter button in the engine compartment because it constantly got vapor lock when stopped in hot weather and it had the dreaded weak cylinder (the one that doesn't get air flow). Still, I learned a lot from doing all that.
    glwood54 and rickystl[QUOTED] like this.
  4. Jun 26, 2023 at 10:31 AM
    #94
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    One could..argue if using conventional oil and driving it in severe/extreme conditions, every 2k.
  5. Jun 26, 2023 at 10:53 AM
    #95
    Arguing is what we do best here. The Maintenance Guide says that the normal oil change interval is 10k miles, and 5k is the interval for extreme conditions. 2k is for the super badasses who regularly defy death by hazarding their trucks in ultra-extreme conditions. Like towing a 10,000 lb trailer to the summit of Mt. Everest. Or driving over lava fields. ;-)
  6. Jun 26, 2023 at 10:55 AM
    #96
    Rocko9999
    2011 Limited
    Yes. I know no one who uses conventional oil, but 3k for conv. was/is the norm. So if they floor it at every green light, drive to work uphill both ways, do power slides into the parking spots like Ace Ventura, I'll vouch for the 2k changes.
  7. Jun 26, 2023 at 11:00 AM
    #97
    broken-giver
    broken-giver BFD
    I mean toyota *did say* 4Runner is an off roader :cool:
  8. Jun 26, 2023 at 11:07 AM
    #98
    When 3k was the norm, so was straight 30 weight. :rolleyes:
  9. Jun 26, 2023 at 11:08 AM
    #99
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Oh, the memories. My first car was a 67 type III so you can add balancing airflow with 2 carbs to that list.
    I added a toilet paper roll oil filter mounted under the backseat opposite the battery.
    It was very maintenance intensive and the brake system was a weak point. I replaced three master cylinders during my 20 years with that car.
    I did love that old car though, all 44 HP worth.
  10. Jun 26, 2023 at 11:55 AM
    #100
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Yes, that was cylinder #3. It received the least amount of cooling. #3 exhaust valve would be the first thing to let go and blow the engine. That's why I would set that one valve just a tad loose from spec. It made the engine run a little louder, but helped that cylinder run a little cooler and last longer. My brother and I got to the point we could pull the engine out in about an hour.
    For sure, the cars did not like very hot or very cold weather. (Although with snow tires they ran through snow very well).
    In really cold weather, first start of the day, I would use a 1/2" ratchet with a 17mm (I think) socket and turn the crankshaft over a half dozen times. That way it would start the oil moving through the engine first. Made it easier to start. LOL
  11. Jun 26, 2023 at 12:06 PM
    #101
    Modern conventional isn't like 70s conventional. You could easily go 5K miles with it.
    Captain Spalding likes this.
  12. Jun 26, 2023 at 3:56 PM
    #102
    UncleShorty
    UncleShorty New Member
    My brother was in auto mechanic school at WACC. He brought me home 4 VW basket case engines, freebees. The parts were all mixed up but everything was there. So every time a valve would let go in # 3 and rattle around in the bottom end I'd grab a bunch of parts and make a replacement engine. I never worried if the parts were for the 1300 CC or the 1500. I'd just throw parts together on a Saturday morning. I'd sit the "remanufactured" motor on the end of an 8 ft 2 x 6 laid on a cement block, give the neighbor kid $1 to stand on the other end of the board which lifted the engine into perfect position to slide in and bolt up.
    Got to where I could do one from start to finish in about 3 hours. Oh, and I never threw the oil away. I'd run that 30 wt through a rag and put it right back in.
    That beetle ran like a raped ape... for a while...
    redneck pilot, Rocko9999 and rickystl like this.
  13. Jun 27, 2023 at 8:22 AM
    #103
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    Shorty: That is a hilarious story LOL !!! But sounds so typical with the old Beetles. I was lucky that one day while scrounging through a auto savage yard, I found an old, scissors type automatic transmission jack. With the car jacked-up on all 4's, and a couple short 2 X 6's on top of the jack, it worked perfect for raising and lowering the engine. I could do it all myself. LOL
  14. Jul 4, 2023 at 1:59 AM
    #104
    Dirty Dog
    Dirty Dog New Member
    Bruce
    2015 Magnetic Grey 4Runner Limited
    I do mine every 3500 or 6 months in every car I have ever owned. It has always done well.
  15. Jul 4, 2023 at 4:30 AM
    #105
    2016Pro
    Lol hilarious
    mrmike7189 likes this.
  16. Jul 4, 2023 at 4:33 AM
    #106
    jvinhj240
    jvinhj240 New Member
    Ben
    always oil thread hahaha. I will beat the ops and will change every 1990 miles with a brand new Toyota filter. ahhaha
    mrmike7189 and nimby like this.
  17. Jul 4, 2023 at 10:56 AM
    #107
    Chrispchicken9
    Chrispchicken9 New Member
    I change my oil every 2k miles.
    I’m also 6’3” with only $3k in credit card debt and I have a Costco executive membership.
    I don’t care what anyone says.
  18. Jul 6, 2023 at 7:00 AM
    #108
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Going in the other direction here:
    My Hybrid Rav4 asks for oil changes every 10,000 miles (same as the standard Rav4, and every other Toyota now, I think). However, being a hybrid, the gas engine only runs about half the time, and rarely idles at a stop.
    Does this mean I can go 20,000 miles between oil changes? At 10,000 on the car, maybe the engine only has 5,000? ;)
    broken-giver likes this.
  19. Jul 6, 2023 at 10:03 AM
    #109
    Rocko9999
    2011 Limited
    That mileages has the math baked into it. And if you want your rings to not get mucked up, earlier the better.
  20. Jul 6, 2023 at 10:39 AM
    #110
    Schlappesepple
    2020 ORP
    Don't worry, I'll change it on time, just thinking out loud. 10,000 is plenty of time for me between changes.
    It's due today, so I pulled the dipstick and it's like a medium color vs. my 4R at 10,000, which is why I started thinking about it.
    I'm guessing there's also some extra wear from the constant start/stop it does, so it is probably a wash like you say.
  21. Jul 6, 2023 at 10:46 AM
    #111
    broken-giver
    broken-giver BFD
    I claim that since hybrid crowd tends to sway more city dwelling, its more stressful on engine than highway driving.
    Those who do it every 2000 miles for regular ICE, should do it every 1000 miles oil change for a hybrid.:D
    Clearly everyone who is waiting till 10K for a change is pushing it :)
  22. Jul 6, 2023 at 12:15 PM
    #112
    2016Pro
    Every 100 miles for me :thumbsup:
    Han4Run, nimby and broken-giver like this.
  23. Jul 6, 2023 at 12:23 PM
    #113
    broken-giver
    broken-giver BFD
    You sir are a baller!
    Yotaholic and 2016Pro[QUOTED] like this.
  24. Jul 6, 2023 at 12:44 PM
    #114
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    We have the rav prime, most days the engine doesn’t come on, but at 10k yota wanted that oil change. What I also don’t like the fact that EV miles are not recorded separate from the ICE miles.
  25. Jul 6, 2023 at 3:00 PM
    #115
    Foothills
    Foothills New Member
    For drivers running slow trails, inner city traffic or daily idling managing oil changes by engine hours or gasoline used makes more sense.
  26. Jul 6, 2023 at 5:57 PM
    #116
    rhexis
    rhexis New Member
    i just change my oil at 1000 miles today probably didnt need it but i have been doing this with every new car ive had and not going to stop now. 6 months or 5 thousand miles i will change it again.
    Nubes, redneck pilot and ecoterragaia like this.
  27. Jul 6, 2023 at 6:52 PM
    #117
    ARB1977
    ARB1977 It’s a beaut Clark
    Anthony
    My 15 Tacoma has the same engine. 6000-7000 oci on M1 EP or Amsoil XL. A few runs on Amsoil SS 0W30 for 10K. 126K.
  28. Jul 6, 2023 at 8:34 PM
    #118
    2016Pro
    Brand doesn't matter.... repeat after me
  29. Nov 14, 2023 at 11:47 AM
    #119
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    That's what I was thinking. The skid plate bolts will be worn out
  30. Nov 14, 2023 at 11:48 AM
    #120
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Twice on the weekend?
    Han4Run likes this.
