Changing Differential and Transfer Oil on 5th Generation
Discussion in '5th Gen 4Runners (2010-2024)' started by cthomas31, Mar 16, 2019.
  1. Aug 8, 2019 at 9:13 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I did purchase toyota washers for plugs. I did not replace the washers and because the washer looked good I reused it... no leaks. 3 years old now.. if the washer is corroded or damaged then replace it so have some ready for use. I do not install the covers when I do the oil changes. leave them off a few days to check for any leaks...
    very odd that my 2000 silverado has the same washer on the oil drain plug. 175K miles ..no problems.
  2. Aug 8, 2019 at 9:19 AM
    Toyota recommends engine oil be replaced every 10,000 miles under normal driving conditions. Diffs, transfer case, and trans oils are essentially "lifetime" oils unless used under extreme conditions. They do not recommend changing them at short intervals under normal wear and tear.
  3. Aug 8, 2019 at 10:12 AM
    4x Old Guy
    4x Old Guy New Member
    Riverside, CA
    Big-O Bigfoot A/T tires
    Yea, it’s probably my old school paradigm. My previous Toyota (which I’m still driving after 250,000 miles), is a 2003 Tacoma 4x with manual trans. I guess oil and engine technology as changed a bit over the years.
    I just wonder, the guys selling oil changes say 3000 miles, and the guys selling cars say 10000+ miles. Truth is, foreign particles still get in the oil through wear, combustion byproducts, or moisture (every gear case has a vent of some kind). I’d just as soon keep as much of that junk out of there for as long as possible. Changing fluids is cheap insurance.
    WallyT4R likes this.
  4. Aug 8, 2019 at 11:12 AM
    I struggle with the thought of it being a lifetime oil as well. Part of me want to change it out at say 100,000 miles and the other part says fvck it......let's see how far this bitch will go.
    I mean how many people do you know that have had problems with their 4Runner motors, diffs, transmissions, and transfer cases? Definitely not a systemic problem among these vehicles. And Toyota does extensive, long-life testing on them to make sure their oil change interval recommendations are appropriate.
    Of course you will get the naysayers that insist Toyota tells us this because they want to sell you more vehicles, but that is contrary to the Toyota philosophy of providing the customer with the most reliable vehicle they can. Because if they do that, many will be customers for life. And Toyota has proven this time and time again with reliable, long lasting vehicles.
  5. Aug 8, 2019 at 11:34 AM
    Ya I’m using my neighbor’s lift. I’m too fat to get under it. From being on this dam site all the time.....
  6. Aug 8, 2019 at 11:43 AM
    j cat
    j cat New Member
    massachusetts
    the long time owners of these vehicles do not keep the drive train lube in for ever.
    rear gear oil diff has break in first 800 miles oil over heats turns dark/black.. if off road use 4wd often gonna have to do the front diff also. transfer case lube many recommend 30-40K miles. transmission fluid requires replacing 100k-130K miles. many did not do the tranny fluid changes at the 130K .. at 170-200K miles they had torque converter shift problems had to do the tranny flush method .. then it was fixed..
    these owners keep these for 20yrs .. pass them on to family members.. that is why these have a very high resale value... GM low resale value .
    older runners it was rust belt frame issue.. runner still runs but the frame is gone.
  7. Aug 8, 2019 at 12:13 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I never did either, til I started riding motorcycles and got in the habit of changing them. Aluminum cases made for the possibility of case cracking if the washer had any imperfections.
    Probably not needed but they’re cheap enough
    WallyT4R and KSJ08 like this.
  8. Aug 8, 2019 at 12:30 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    What fluid do you guys recommend for front, rear and transfer? Plan on doing mine in a couple months
  9. Aug 8, 2019 at 12:57 PM
    4x Old Guy
    Riverside, CA
    Most vehicles have (or should have) magnetic drain plugs. The first time you pull that plug and see that spike hair-do of iron filings on the plug, you’ll be glad you changed the oil. Fine filings (like what you’d get running a magnet through sand) is normal (especially for the first time). However, little tiny pieces, that might be a different story.
  10. Aug 8, 2019 at 1:02 PM
    j cat
    j cat New Member
    massachusetts
    I used mobil synthetic 75-90wt gear oil.. reason I used this is because the gear oil is highly recommended and the owners have used this in the frt/rear gear boxes for 300K miles..
    now the transfer case requires toyota transfer case oil .. this is a special oil that has the additives in it to reduce wear ..
    toyota transfer case fluid
    scottalot and Jynarik[QUOTED] like this.
  11. Aug 8, 2019 at 1:14 PM
    4x Old Guy
    Riverside, CA
    I agree with the Toyota testing and reliability reputation (this is the 4th Toyota I’ve owned). They can run them through the wringer for many thousands of miles, but they can only do it in a relatively short period of time (vehicle has to go onto production sometime). What I wonder about is real world, long clock time, testing (a thousand short trips, low miles per year, parked in unfriendly weather, slogging through fun off-road junk, sitting some more, repeated powertrain temperature cycles with air inside the cases expanding and contracting and sucking in humid air, internal condensation when they cool back down again, etc.). Those are the conditions that are hard on the lubricants.
  12. Aug 8, 2019 at 1:46 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Thanks!
  13. Aug 9, 2019 at 12:16 PM
    KSJ08 likes this.
  14. Aug 9, 2019 at 12:20 PM
    thirdyota
    Brian
    Cincinnati, OH
    2017 T4R TRD Off Road Premium
    I use Redline 75w85
  15. Aug 9, 2019 at 12:26 PM
    Sometimes cheaper is better. I tried using expensive Motul oil in the GSXR and it was having shifting problems. switched back to a basic synthetic and it shifts perfect...
    j cat likes this.
  16. Aug 9, 2019 at 4:31 PM
    j cat
    j cat New Member
    massachusetts
    my dealership uses mobil syn 75-90wt in 50 gallon drums bulk ..for the diff's ..
  17. Aug 9, 2019 at 4:56 PM
    I think I used that, the last diff change. No metal shavings at all. O’well my rear end will prob start crunching now.
  18. Aug 9, 2019 at 6:04 PM
    WallyT4R
    WallyT4R New Member
    Royal Purple Synchromax is also recommended for the transfer case and it is a lot cheaper and way more readily available than the Toyota stuff. I have Synchromax in my transfer case
    Living the dream likes this.
  19. Aug 9, 2019 at 6:07 PM
    #49
    WallyT4R
    WallyT4R New Member
    I pretty much stick to the severe duty maintenance schedule in the owners manual but with my use I definitely fall into the severe duty parameters. Towing, frequent stop/starts, off road, dust, etc.
    Firefly21 likes this.
  20. Jan 23, 2020 at 10:39 AM
    #50
    Sertao
    Sertao New Member
    I found this interesting because when I changed diffs and transfer case fluids, I went to the Toyota dealer for the transfer case fluid recommended. But they don't stock it or use it. When I asked the service manager what they would use if they got a transfer case fluid change request, he stated regular 75W-90 gear oil. He said Mobil 1 would be fine. sigh...
  21. Jan 23, 2020 at 9:16 PM
    #51
    WallyT4R
    WallyT4R New Member
    Just use the Royal Purple Synchromax. It's compatible
  22. Jan 24, 2020 at 6:35 AM
    #52
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    I worked for Toyota, trust me 50% of the managers get their position because of who they know not what they know, and they do not keep themselves updated on vehicle requirements. Gear oil might be okay to use, but if your going to be keeping your 4runner for a long time, why risk potentially damaging a important component in the transfer case just to save a few bucks.
    krravi, ruiz4251, j cat and 1 other person like this.
  23. Jan 25, 2020 at 11:07 AM
    #53
    j cat
    j cat New Member
    massachusetts
    why would a dealership use the wrong transfer case fluid ? because they will want you to buy another new runner when the warranty ends on the drive train failure .
    krravi likes this.
  24. Jan 25, 2020 at 11:13 AM
    #54
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    dumbest shit I heard today.
    wmdtech and nimby like this.
  25. Jan 25, 2020 at 1:57 PM
    #55
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    Good call, mine (rear diff)was replaced at 18K under warranty.
  26. Jan 26, 2020 at 10:45 AM
    #56
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    Transfer case is as easy to do as the rear
    My front diff done at 20,000 was worst than my rear. Its a bit of a pain but if you do it during an oil change while the skids are off... its not bad
  27. Aug 6, 2020 at 4:14 PM
    #57
    DougEFresh2
    DougEFresh2 New Member
    Doug
    5th Gen 4Runner
    I think we all have slightly different opinions on when we should change our fluids and what kinds of stuff are okay to use. Well, with that said, here's mine:
    4EverRunner66 and nimby like this.
  28. Aug 6, 2020 at 7:52 PM
    #58
    Good stuff Doug!
    A lot of work went into that.
  29. May 2, 2021 at 12:04 PM
    #59
    Kassam
    Kassam New Member
    This really is one of the most helpful articles I've found in a while. Thank you so much for taking the time and effort to create such a masterpiece. I'm sure many people other than those who responded in this thread have taken your advice and are completely satisfied with the result. What a pity that such information is now very difficult to find, but I hope that you will continue to delight us with excellent topics, full of quality content. By the way, I'd like to add a little about oil - to make oil selection easier you can use http://cararac.com/, I often use it when my friends don't know what's best to choose for their cars. I think it might be useful to someone on this forum as well :)
    7385 likes this.
  30. May 5, 2021 at 6:03 AM
    #60
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    I did my rear differential gear oil change on my 2005 (105,000 miles) with 3 quarts of Valvoline 75-90 (conventional). Just drain and fill. No drips.
    Took 15 minutes in the driveway.
    I will do it again after another 70,000 miles.
    Parts store didn't have synthetic. Personally don't think synthetic gear is any better.
    My 4runner doesn't see highway driving with higher temps. I'm in Nassau Bahamas.
    3 mile trips are long for us. Bet I get to 500,000 miles.
    Color of the old gear lube was jet black and it lost its viscosity.
    Now at 155,000 miles.
