Cali raised SS cat shields
Discussion in '5th Gen 4Runners (2010-2024)' started by 08TXRunner, Apr 1, 2023.
  1. Sep 9, 2023 at 6:04 PM
    #241
    Tino
    Tino New Member
    New York City
    Just accessories
    The shields looked like they were never installed and the hardware was new including the washers. It might have been packed inproperly or it was a fedex special where they just probably threw the box around or somebody from there might have opened it. The box was taped with the brown paper type tape and the box clearly says cat shields. THey should have just put the name of the company on the box or even packed it in an unmarked box. I will see what happens on Monday.
  2. Sep 9, 2023 at 6:27 PM
    #242
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I received mine. Now just need my Pro to come in.
  3. Sep 16, 2023 at 10:33 AM
    #243
    Tino
    Tino New Member
    New York City
    Just accessories
    I am going to ask a dumb question here. When you guys installed your cat shields did you raise the vehicle in order to get the nuts for the crossmember bolts out. I had to use an impact wrench for the brace bolts and I can't loosen the nut on the crossmember bolts. I am doing this on my driveway which has an incline.
  4. Sep 16, 2023 at 10:40 AM
    #244
    RusPro17
    Don
    Pa.
    I would watch the install video. They show you how easily these are to install. The reason I say I have my new ones I received just waiting for my new 4runner. I watched the you tube video.
  5. Sep 16, 2023 at 11:25 AM
    #245
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    @Tino I used a bottle jack to push up on the crossmember to get those bolts out. I suspect others did something similar. Also only remove one bolt at a time!
    Spydr5 and RusPro17 like this.
  6. Sep 16, 2023 at 12:51 PM
    #246
    Tino
    Tino New Member
    New York City
    Just accessories
    Well I got them out. They painted the bolts to the frame. I had to use a 1/2 inch 20 volt impact wrench. The milwaukee 3/8 M18 fuel was not strong enough to loosen the bolts. The funny thing is that I was able to remove the bolts without using the screwdriver. The only time that I experience tension on the crossmember is when I installed the new bolts. I tried to reposition the one at the end and had to use the screwdriver. I just did the passenger side today tomorrow I will do the drivers side. One thing I notice is that the security bolts thread in by hand on the side where it goes through the shield, but on the crossmember side you have to work them in with the impact slowly. I don't know if the originals were crossthreaded or what.
  7. Oct 4, 2023 at 7:42 AM
    #247
    RusPro17
    Don
    Pa.
    Tino, Now that you have them on have you heard any kind of noises or rattles? Just curious.
  8. Oct 4, 2023 at 9:32 AM
    #248
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    So what issues are there still with these? Rattling? I don't want to have to mod anything and no one should to make it work correctly.
  9. Oct 4, 2023 at 9:35 AM
    #249
    RusPro17
    Don
    Pa.
    What I read up on the problem was fixed. I have not added mine yet. I figured I would ask someone who recently added them.
  10. Oct 4, 2023 at 11:14 AM
    #250
    Tino
    Tino New Member
    New York City
    Just accessories
    I was wondering if the cooling fans are electric. That is the only time I felt a slight vibration like when the cooling fans turn on type of thing. I haven't heard any rattling while driving. I haven't heard anything except that one time.
  11. Oct 4, 2023 at 11:28 AM
    #251
    Cooling fans? This is the first I've heard of cooling fans and cat shields being mentioned in the same reply...
    08TXRunner[OP] likes this.
  12. Oct 4, 2023 at 11:44 AM
    #252
    Tino
    Tino New Member
    New York City
    Just accessories
    Don't wish to create another thread for that . As for the cat shields no vibrations. I guess that is what you wanted to know. So far so good if I experience anything down the road I will post here. We don't really drive the car much for now. I only put about 50 miles since the install.
    RusPro17 likes this.
  13. Oct 22, 2023 at 10:32 AM
    #253
    regius123
    regius123 New Member
    Reginald
    2023 TRD ORP white
    Tri-color retro body decal; OME BP-51 front coilover; OME Nitrocharger Sport rear (stock height); TRD Pro bronze wheels, TRD skid plate.
    Speaking of these tubular braces, when I traded in my GX460 that had the Talon shield, I first had the Talon removed. During removal the mechanic wasn’t able to put the tubes back on as the four bolts were tossed by the original installer of the Talon (a mouthful sorry). So, I was driving around a day or two without the tubes. Then here’s the fun part, at the Toyota dealership, the shop saw the tubes in the trunk of the GX460 and brought them to me asking “do you want these?”. LMAO, “do you want these??????”. I said, “you should put them back on for the next guy.”
  14. Oct 22, 2023 at 11:08 AM
    #254
    regius123
    Reginald
    2023 TRD ORP white
    I had the CaliR shield on my previous 4Runner “23 4WD no-KDSS, no vibration.
    Last week I received a pair of new shield, these are the hardwares in the box (I buy from 4Runner lifestyle, they always have stock).
    Bullnettles likes this.
  15. Oct 22, 2023 at 11:22 AM
    #255
    08TXRunner
    08TXRunner [OP] New Member
    '20 SR5P
    ^^^ Looks like they finally fixed the hardware package - good for you!
    Update on mine - just because I like piddling, on the driver's side I put some 1/8" washers under the front and moved the rear down as much as I could. I now have a slight rattling at idle in drive, so it appears as originally installed the shields were kissing the cats just enough to prevent that. Gonna have to move it back up.
  16. Dec 9, 2023 at 6:11 AM
    #256
    regius123
    Reginald
    2023 TRD ORP white
    Is Cat theft still rampant in your area? I’m in NY/lower Fairfield, CT. Ever since I received the Cali raised shield, it’s been in my car, at first I was very nervous about the theft but it’s been two months, I wonder if I should return or sell the shield
    jake long15 likes this.
  17. Dec 9, 2023 at 6:40 AM
    #257
    Tino
    Tino New Member
    New York City
    Just accessories
    Are you in NY or CT ? If you are in NY definitely put them on. If you are in CT only you can decide if they are necessary. I am not really familiar with Ct. You should ask your neighbors or maybe someone here might be able to help you that lives in CT.
    regius123[QUOTED] likes this.
  18. Dec 9, 2023 at 6:52 AM
    #258
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    I had looked at these but ordered the MillerCAT shield as I liked that it looks like more of a skid plate and both sides are connected.
  19. Dec 15, 2023 at 8:44 AM
    #259
    jake long15
    jake long15 Cali Raised LED
    At the end of the day, it is better safe than sorry!! From our end, we are still getting calls every day of people need to protect the cats as theres were stolen.
  20. Dec 15, 2023 at 8:58 AM
    #260
    RusPro17
    Don
    Pa.
    I recently added mine. I wish you could buy extra keyed bolts and just use all the holes with them. I don’t see on Cali’s web site you can buy them.
  21. Dec 15, 2023 at 9:03 AM
    #261
    jake long15
    We can sell them if that is something that interests you. Please email info@caliraisedled.com if you would like to buy them :)
  22. Dec 15, 2023 at 9:04 AM
    #262
    RusPro17
    Don
    Pa.
    Thank you Jake!!
    jake long15[QUOTED] likes this.
  23. Dec 15, 2023 at 9:07 AM
    #263
    jake long15
    Of course, please let us know if you have any questions :)
    RusPro17[QUOTED] likes this.
  24. Dec 15, 2023 at 9:14 AM
    #264
    RusPro17
    Don
    Pa.
    Emailed sent also with something I ran into why I want the longer bolts.
  25. Dec 15, 2023 at 12:47 PM
    #265
    RusPro17
    Don
    Pa.
    Just ordered another set of bolts. 4 of them to make all of them with the bit. I had one issue where one of the oem bolts would not grab so I used 2 of the special cat bolts. So that’s why I wanted all 8 to be longer.
  26. Dec 19, 2023 at 11:07 AM
    #266
    jake long15
  27. Dec 20, 2023 at 7:59 AM
    #267
    RusPro17
    Don
    Pa.
    Finally got a pic. Not the greatest. Finally got them on. Cali is sending me 4 more bolts I ordered so all of them to be with the key. IMG_4744.jpg
    Doglover2003 and jake long15 like this.
  28. Dec 20, 2023 at 1:58 PM
    #268
    Have you noticed if these leave plenty of space to get to the drive shaft grease zerks without removing anything?
  29. Dec 20, 2023 at 2:02 PM
    #269
    RusPro17
    Don
    Pa.
    Never looked at that. Probably when I take it in for oil change I will have my mechanic look that over to see with greasing. I know I have no noise or rattling.
  30. Dec 22, 2023 at 6:49 AM
    #270
    RusPro17
    Don
    Pa.
