Cali raised SS cat shields
Discussion in '5th Gen 4Runners (2010-2024)' started by 08TXRunner, Apr 1, 2023.
  1. Jun 22, 2023 at 3:27 PM
    #151
    Did you happen to notice if the supplied bolts are the same length as the oem bolts for the cross bars?
  2. Jun 22, 2023 at 3:29 PM
    #152
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    From my situation, the supplied bolts were actually a hair shorter than the OEM bolts.
  3. Jun 22, 2023 at 5:02 PM
    #153
    beedee
    beedee Member
    Do you have the product? If so, have you tried installing it? If not, wait until you try to install them with the 30mm bolts, while the CR guy in the video appeared to do it with ease, it was a different story for myself, and many others here. I also documented that as well in my post around page 3.
    They are a smidge shorter, I mentioned it in a post of mine on page 3 I think.
    Seems like you are doubting us here (or don't want to believe us) that have real world experiences with the bolts and installation of them. We have no reason to lie or bend the truth. I am very happy with my purchase, if they included the M8 40mm bolts from the get-go, it would have been a 10/10 experience for me. I was fortunate and received all the hardware, plus a bonus spacer, washer or two as well.
    Here is my post: Provided bolts struggle
    08TXRunner[OP] likes this.
  4. Jun 22, 2023 at 6:10 PM
    #154
    08TXRunner
    08TXRunner [OP] New Member
    '20 SR5P
    For anyone wanting to cut or grind stainless, it's a totally different approach to aluminum or iron/steel. The way to go is carbide bits with lots of lube and extremely slow rpm. Very, very slow to take material off. Any kind of speed will harden the SS and turn it blue. You want to almost chip away at the material. Die grinders are a no-no - way too much rpm. If you're using a bit in a drill press, change the belt/pulley arrangement to give you the lowest RPM possible and lots of lube. Even with all of that, you'll probably ruin a few bits. SS is like granite.
  5. Jun 22, 2023 at 6:27 PM
    #155
    08TXRunner
    '20 SR5P
    This was also pretty well documented in my posts through #67 or so. Not sure why at this point anyone is questioning the bolt issue.
    beedee[QUOTED] likes this.
  6. Jun 22, 2023 at 8:55 PM
    #156
    You guys are getting me all wrong...I'm not questioning why everyone is complaining about short bolts. The point I was making is why Cali Raised keeps sending bolts that are too short; why haven't they fixed the problem?? It's amazing to me that this, along with missing spacers, keeps happening. Sorry if it sounded like I was doubting your word - not my intention.
    There's no reason on earth to have to run to the hardware store to install a new part, especially when they have documented feedback from customers that the bolts are too short.
  7. Jun 22, 2023 at 10:33 PM
    #157
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I see. This thread is great, really drilling down
  8. Jun 23, 2023 at 1:12 PM
    #158
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    My security bolts seemed short. Maybe got 3 threads if that. I took them out and ran a tap through holes then put in some 50mm Phillips heads until I get some longer security heads. Pretty sure my drivers side rattles at idle in Drive. Goes away in park or neutral. Going to take it off next week to see if the rattle goes away. Anybody else's rattle?
  9. Jun 23, 2023 at 2:28 PM
    #159
    08TXRunner
    '20 SR5P
    That driver's side is way too close for my taste. Mine is just far enough away that it doesn't, but it's real damn close. If it were aluminum I'd say take it off and shape it a little with a dead blow hammer and reinstall. But SS is hard as hell and I don't think that would work.
    I really appreciate Cali bringing these to market. But between the driver's side issue, fastener issue, and the fact that they didn't bother to figure out what submodels they fit on, it seems to me that they got about 90% there and quit.
    djwantke likes this.
  10. Jun 23, 2023 at 3:04 PM
    #160
    steelevo
    Utah
    I wouldn’t necessarily say that they quit after getting to 90%. They are using the first few batches of buyers as the R&D Guinea pigs. The next revision will hopefully have a few of the kinks worked out. It’s just like buying the first MY of a new car.
  11. Jun 23, 2023 at 5:02 PM
    #161
    08TXRunner
    '20 SR5P
    I don't appreciate being a guinea pig for what fasteners fit or don't fit, or whether I complain about not getting all the parts. Send the correct stuff the first time.
    djwantke and Stitches1974 like this.
  12. Jun 26, 2023 at 6:39 AM
    #162
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    I ordered a set of these last Friday. Will report back on whether I receive all the correct hardware when the kit arrives.
  13. Jun 26, 2023 at 9:19 AM
    #163
    MidniteTRD
    MidniteTRD New Member
    Augusta GA
    yep. had to adjust mine this weekend. on friday i found out it was rattling at very low RPM under load, like going up a hill with the converter locked in 4th. got under there and sure enough the converter's metal shroud was touching the CaliRaised shield, slightly wearing an area that is about penny-sized right near the logo. I pulled off that driver's side one and trimmed about a 1/2" off each lower corner using a dremel heavy duty cutoff wheel and a fine toothed flat file. that gave me the room to drop the shield down to where the 2 big crossmember bolts were at the top of their slots, without hitting interference with the brace or a raised part of the frame. then i reinstalled the 2 smaller allen bolts to cinch it up. that gave me about 1/4" of clearance back between the shield and cat.
    i did about 100 miles since then, no issues. i'll try to grab a pic later.
    disappointing, but thankfully the shield can still do its job.
    Guppy1301[QUOTED] likes this.
  14. Jun 26, 2023 at 10:33 AM
    #164
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Same experience on mine. Low RPM, taking off from stop signs under load. It's not very loud, but I do notice the rattle.
    Guppy1301 likes this.
  15. Jul 7, 2023 at 6:34 PM
    #165
    mr samster
    mr samster New Member
    19 MGM SR5 Premium
    Did you happen to take pictures of what you did? I am having the same issues as you and I did try prying it away from the converter but there is still some rattling.
  16. Jul 8, 2023 at 8:09 AM
    #166
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Sub'd because mine was shipped without the spacers but CR sent it after I sent them a email. Also no issues with my kdss when it was installed.
  17. Jul 11, 2023 at 7:05 AM
    #167
    MidniteTRD
    Augusta GA
    here you go. i had to lower the shield by tightening the bolts at the very top of their slot. however, if you do this, you'll see the flange will hit interference with the crossmember brace on the inboard side and some crossmember protrusions on the outboard side. so i basically cut a dog-ear off of each lower corner of the flange with a dremel cutoff and smoothed with a metal file (you can see in the image how much less square the flange corners are now). doing this allowed me to lower the shield with some margin to spare.
    after another couple hundred miles of testing, this has solved the rattle on the driver's side. there's about 1/8" of clearance between the cat and the shield now, where before they were essentially touching.
    it sucks we seem to all share the same basic issues which points to a lack of testing/rushing to market on the manufacturer's end, but at the end of the day its not a complicated or critical part, just annoying.
  18. Jul 11, 2023 at 11:18 AM
    #168
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Finally bit the bullet on my order today. Whats the consensus buy the longer bolts locally or try to do the install with the hardware provided (assuming it all shows up)?
  19. Jul 11, 2023 at 12:07 PM
    #169
    If I were installing these, I would get one longer bolt with the same threads as the oem bolt, and use that to snug up that brace. Then try the supplied bolt in the second hole to see if it's long enough. If yes, when that supplied bolt is snug, I would remove the longer bolt and replace it with a supplied bolt. Rinse and repeat for the other brace bolts.
    Unless you simply want to be a supplier for Cali Raised and get all longer bolts up front.
  20. Jul 11, 2023 at 12:26 PM
    #170
    Squ1dward
    Squ1dward New Member
    Installed them on my 4R and it was more of PITA than I thought it would be. Supplied security bolts can easily strip out if not careful.
    I had to use the Toyota-supplied jack to push the shield into place since it would not sit flush like shown in the installation video.
    I had to push up the shields so i could get the bolt to hit the threads. Bolts should be longer. I had to run to Toyota to get extra cross member bolts since the old ones were a little corroded at 25k miles. surprising.
    One thing I have noticed, it the shields rattle when I go over bumps. A bit annoying when i don't have the tunes cranked.
    The shields are a very good idea which could have been designed a little better IMHO.
    I may try the Dremel solution listed above if I get ambitious
  21. Jul 11, 2023 at 12:26 PM
    #171
    BgBmBoo
    BgBmBoo New Member
    Kansas
    I did the same as glwood suggests but re-installed the factory hardware and called it good. The day comes that cat thieves show up with a full socket set, not much will stop them..
  22. Jul 11, 2023 at 1:22 PM
    #172
    beedee
    beedee Member
    Yes, get the bolts I posted earlier in the thread, 40mm will do the trick. I bought 4 to just make it easier all around.
    Doglover2003 likes this.
  23. Jul 11, 2023 at 1:34 PM
    #173
    08TXRunner
    '20 SR5P
    If Cali were to ask me, I'd give them two pieces of advice: go back to the drawing board on the driver's side shield and make it 3/8 or 1/2 deeper; and redo your hardware package to include 40mm bolts and don't forget the spacers. It's otherwise a really nice package. But as mentioned by @MidniteTRD the whole thing feels rushed.
    Given that the hardware package seems to be an ongoing problem, it seems Cali is not paying attention to complaints coming their way. I installed mine over 3 months ago, telling them at that time of the hardware problem. It's really surprising they are still shipping kits with no spacers and too-short bolts.
    glwood54 likes this.
  24. Jul 11, 2023 at 3:38 PM
    #174
    08TXRunner
    '20 SR5P
    @beedee I think @glwood54 is just trying to help. He's a good guy - maybe give him some slack? Just a suggestion.
    I've appreciated both of your contributions to this thread.
  25. Jul 11, 2023 at 8:14 PM
    #175
    I've been following this thread since the original post. I am impressed with the design, and seriously considered getting a set of these to replace my Miller Cat version, and stated that early on. I like how they provide access to the transmission and driveshaft for service. Because I've questioned why Cali continues to ship sets with apparently missing or inadequate hardware, but don't actually have them in hand, I'm being asked why I post.
    If I have further observations or requests, I won't hesitate to post them.
    @08TXRunner - I appreciate your input. I am genuinely interested in these, and will see if Cali Raised listens to those who've notified them of the hardware issues.
  26. Jul 11, 2023 at 8:28 PM
    #176
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    Only reason I have not ordered them. With how many people told Cali what's up and continues to do so, is mind boggling. I think someone needs to send them a link to this thread showing them they're losing business.
  27. Jul 12, 2023 at 4:19 AM
    #177
    BgBmBoo
    BgBmBoo New Member
    Kansas
    FWIW, my hardware packet was complete. Must have caught the parts guy on a good day.
    It's sad they can't seem to straighten that issue out. The shields themselves are a solid product and I wouldn't hesitate to buy again.
  28. Jul 12, 2023 at 7:22 AM
    #178
    Connor MacLeod
    Connor
    2023 TRD Off Road
    I received my kit probably a couple of weeks ago now; planning to install this weekend. Looks like I got the long bolts and spacers were included. I spoke to CaliRaised about the hardware after I placed my order, and they said they were aware of the issue and are now including all the hardware with each shipment (just reporting what they told me; not questioning anyone else's account if they are missing hardware).
  29. Jul 12, 2023 at 10:10 AM
    #179
    beedee
    beedee Member
    For sure, sorry for the lame posts on my end. I deleted them.
  30. Jul 12, 2023 at 12:01 PM
    #180
    So were the bolts you got closer to 40mm like people have been suggesting?
