Cali raised SS cat shields
Discussion in '5th Gen 4Runners (2010-2024)' started by 08TXRunner, Apr 1, 2023.
  1. May 14, 2023 at 4:43 PM
    #121
    CMM15
    CMM15 New Member
    I get a vibration from my drivers side shield every time I drive. It will be a short vibration sound for about 2 seconds at a low cruising speed/rpm range. This has to be because of the cat shield touching. Is there anything being done about this? Anyone else have the same issue. I have checked all the hardware and have installed twice just to make sure there wasn’t something interfering that I caused.
  2. May 14, 2023 at 7:29 PM
    #122
    08TXRunner
    08TXRunner [OP] New Member
    '20 SR5P
    I have not, and my driver's side *just* kissed the converter shell when it was in place. Same for yours, or did it take more force to draw it up with the bolts?
  3. May 15, 2023 at 6:59 AM
    #123
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    Just so you know, copied from the other site.
    you can buy a set of "security bits" to remove those security bolts at harbor freight for $6
  4. May 15, 2023 at 10:51 AM
    #124
    08TXRunner
    '20 SR5P
    I'm sure that got lots of OMG!'s on the other site. But any bolt you put in there will have a way to remove it. What's a thief more likely to have - one of a dozen tools to remove a hex head, or the one tool to remove one with a security head, allen head, etc? Just like the shields themselves, the security bolts are a deterrent.
    Nubes likes this.
  5. May 15, 2023 at 11:34 AM
    #125
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Don't worry, being stainless steel you have a good shot at stripping out the head during the install so that will slow them down too.
    08TXRunner[OP] and NE Runner like this.
  6. May 15, 2023 at 11:57 AM
    #126
    NE Runner
    NE Runner New Member
    Clint
    Lincoln, NE
    2018 Magnetic Gray TRD Off Road Premium
    Or, the stainless fasteners will gall and you'll never get them out.
    BgBmBoo[QUOTED] likes this.
  7. May 15, 2023 at 12:00 PM
    #127
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Very true, a deterrent nonetheless. Criminals can be smart plus they have google search now on they're burner phone.
    I once had car thieves break in, demolish my ignition assembly and started up a with flathead only to be stopped by Code Alarm immobilizer.
    So they stole my bolted down amplifier, and the Jeep parked next to me hahaha
    BUT ran out of time stealing my 12" square Kicker woofer, left it hanging cuz too many security screws!
  8. May 15, 2023 at 12:34 PM
    #128
    salvojimmy
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    I agree, but then a good set of vice grips might even do the trick. However, the shield is still somewhat of a deterrent as it adds time to the job.
  9. May 22, 2023 at 9:56 AM
    #129
    technikal
    technikal New Member
    I just installed these - great info in this thread. A couple of things that helped me doing this on my back in the garage:
    - Definitely get the longer bolts for the frame cross brace. You really only need 1 as once you have on bolt on each side snugged up, you can remove the longer bolt and use the supplied hardware
    - Add a dab of grease on the washer on the bolt head in the transmission support. This will help keep the washer stuck to the bolt head and make it easier to fit the shield.
    - Use a long screwdriver to lever the transmission support in place and it'll be much easier to remove/install the 'tight' bolt.
    - It's tight in some spots - ratcheting 14mm wrenches helped a lot.
  10. May 22, 2023 at 12:44 PM
    #130
    08TXRunner
    '20 SR5P
    Question for you guys - what is the point of the stupid braces that run from the frame to the trans cross member? By that I mean, are they necessary? Has anyone taken them off and had the trans tumble down the highway?
    The day I bought my truck I removed the ugly tube steps - I like the cleaner look. Problem is that those braces are really visible and I've often wondered if we can just toss them.
  11. May 22, 2023 at 2:44 PM
    #131
    They probably fall into the category of similar cross braces up front under the skid plate. Some skids require removing those, and it doesn't seem there's any real disadvantage to them being gone (unless the skid plate itself does the same thing those cross braces do). Personally, I don't want any structural pieces missing if I can help it; it seems they are there for a reason, but I'm not a Toyota design engineer by any means, so...
    I'm sure we would have heard of it if someone had.
  12. May 22, 2023 at 2:58 PM
    #132
    08TXRunner
    '20 SR5P
    Off they go. If I run over my transmission, I'm telling my adjuster that glwood guaranteed me it was ok.
  13. May 22, 2023 at 3:23 PM
    #133
    Wow, launching out into the unknown...does that mean you will need new shorter bolts for the cat shields?
  14. Jun 4, 2023 at 4:06 PM
    #134
    08TXRunner
    '20 SR5P
    Strange how Cali has hidden all the reviews for this product on their site. I made a review politely detailing the things that need to be changed and - poof! Gone.
  15. Jun 4, 2023 at 4:10 PM
    #135
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    I just looked and see 16 reviews on their webpage.
  16. Jun 4, 2023 at 5:15 PM
    #136
    08TXRunner
    '20 SR5P
    Strange - on Chrome and Edge I see no reviews. I'll take your word for it.
  17. Jun 4, 2023 at 5:48 PM
    #137
    backpacker
    backpacker New Member
    2023 TRD ORP
    The reviews might be coming from a third-party site affected by ad blockers or some web security settings.
  18. Jun 4, 2023 at 6:07 PM
    #138
    Stitches1974
    I use Chrome and have no issues. With the latest review on 5/29/23
    Brad
    Verified Reviewer
    4.0 star rating
    05/29/23
    Great fit, a little snug
    Review by Brad on 29 May 2023review stating Great fit, a little snug
    Just installed these today. Able to do it with all four wheels on the floor. Like others have said, the replacing security bolts are shorter than they need to be. If the security bolts were half inch longer, it would make the install easier.
    1 tip:
    When replacing the supplied long bolts to the trans subframe, the two which feel “tightRead more about review stating Great fit, a little snug
    ”, jack up the cross frame to allow the bolts to smoothly go in and out easier.
  19. Jun 20, 2023 at 3:50 PM
    #139
    Lirokan
    Lirokan New Member
    Has anybody installed these on KDSS models? Any fitment issues?
  20. Jun 22, 2023 at 10:30 AM
    #140
    MidniteTRD
    MidniteTRD New Member
    Augusta GA
    put mine on last weekend. i had to also buy 4 longer allen button-head bolts (40mm as i recall, from someone else's advice here) and had to wait an additional week to get the 4 spacers that go on the long crossmember bolts because they were missing. CaliRaised responded as fast as I could reasonably expect for the missing parts and sent them out free of charge.
    i think its a very well designed deterrent and i also like that they're meant to be able to fit in conjunction with a skid plate that i can put on later. super clean laser cuts on the shields and the 12ga stainless is robust. fitment was tight but precise and it was less than an hour to install. as noted, use a jack on the crossmember and that will help to keep the bolts loose enough to slide out when you're replacing them. 10/10 execution, 5/10 convenience due to the mis-spec'd bolts and missing parts, so call it a 8/10 average rounding up a little because its Friday, ha. that's how some aftermarket stuff goes though, its not always perfect and i accept that, and still think this is one of the best options out there. i feel quite a bit better about leaving this thing alone at trailheads and parked downtown now.
    MTMik109 and 08TXRunner[OP] like this.
  21. Jun 22, 2023 at 10:45 AM
    #141
    Do you have KDSS to answer @Lirokan's question above?
  22. Jun 22, 2023 at 11:02 AM
    #142
    Nubes
    Nubes Toyota Addict
    But but, its Thursday? LOL!
  23. Jun 22, 2023 at 11:27 AM
    #143
    MidniteTRD
    Augusta GA
    nah, plain jane TRD OR
    LOL. i'm on a 9/80 schedule so today's my "friday", completely forgot!
    Nubes[QUOTED] likes this.
  24. Jun 22, 2023 at 11:38 AM
    #144
    I can't figure out why people keep talking about bolts for the angled cross braces that are too short. Even Cali Raised's instruction video shows installing those, so why would they send out bolts that are too short?
    I also don't get why they say these won't work on a KDSS or Xreas equipped 4R. I can't speak to the Xreas, but I don't see anything about a KDSS equipped 4R that would prevent mounting these...there are no hydraulic lines in that area that I can see...
  25. Jun 22, 2023 at 11:56 AM
    #145
    MidniteTRD
    Augusta GA
    there feels like minimal thread engagement with the stock cross brace bolts. my observation was the same, and it was a simple fix so i'd rather take care of adding some safety margin up front.
  26. Jun 22, 2023 at 12:29 PM
    #146
    08TXRunner
    '20 SR5P
    They admitted to me in an email that the bolts are too short. But they're also still leaving out the spacers, so it may just be the guy in the packing department grabbing the wrong stuff. As for the KDSS or Xreas, they just may work. Their ad on the website still says "4WD only" when they do, in fact, work on a 2WD (like mine). I told them months ago and sent pics showing the fit on my truck. They said at the time that they just hadn't tested a 2WD. So maybe they haven't tested the KDSS or Xreas.
  27. Jun 22, 2023 at 1:12 PM
    #147
    Thanks. I think they put that just not knowing for sure. The MillerCat had that situation early on also, where they said theirs would not work with KDSS or Xreas, but then they came out with a version that does. I don't even know what the difference is. I did wonder about the 4WD thing also...
    I'm waiting for someone with KDSS to bite the bullet and take one for the team! If I didn't already have the MillerCat, that would be me. The worst that could happen is having to grind a small area to fit, which isn't a big deal because they are bare metal.
    The 'guy in the packing area' apparently is still at it, though.
  28. Jun 22, 2023 at 1:52 PM
    #148
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    I have a KDSS equipped 4Runner and I didn't run into any issues with the KDSS module or any other associated components during the installation. I just needed longer bolts when re-installing the crossbars but it's not a KDSS related issue.
    djwantke, glwood54 and 08TXRunner[OP] like this.
  29. Jun 22, 2023 at 2:55 PM
    #149
    08TXRunner
    '20 SR5P
    Spoken like a man who's never had to grind stainless steel :D
    djwantke likes this.
  30. Jun 22, 2023 at 2:56 PM
    #150
    08TXRunner
    '20 SR5P
    And there we go! Thanks for chiming in.
