Cali raised SS cat shields
Discussion in '5th Gen 4Runners (2010-2024)' started by 08TXRunner, Apr 1, 2023.
  1. Apr 19, 2023 at 5:22 AM
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    For $100 more you can get a tranny skid plate from RCI with cat guards. Best of both worlds and that's what I told my wife.
    RiverRunner and Idayota like this.
  2. Apr 19, 2023 at 6:17 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Where did you buy the transmission skid and cat guards for $300? Their website shows $425 for the set.
  3. Apr 19, 2023 at 6:25 AM
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    It was from their site. He's my order but it shows less than what I actually paid which was around $340-$350 shipped. I guess they were on sale?
  4. Apr 19, 2023 at 6:30 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Yeah looks like it was a promotion. That was a good deal!
    Austin26 likes this.
  5. Apr 20, 2023 at 7:27 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey man, here's some photos of my skid setup, may help for your reference (haven't bought cat shields yet). Cheers
    [ARB 5421110 skid kit
    4 panels: Front Panel (Protects power steering, engine sump, sway bar), Diff Panel (Protects front diff mounts, engine sump), Transmission (Protects transmission and transmission controls) and Transfer Case (Protects transfer case)
    3mm zinc-plated powder-coated, Laser cut steel. Pressed & folded sheet steel adds more strength than standard folded sheet. Silver textured finish]
  6. May 2, 2023 at 10:47 AM
    beedee
    beedee Member
    Anyone have shipping info yet? I spoke with them on Friday, and they said my order would be shipped "early next week"...which is this week. I ordered on April 7th. (yes I know there is a 3-4 week lead time disclaimed on the product page).
  7. May 2, 2023 at 11:10 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Nope, nothing yet. I was hoping we were getting close!
    waldo98 and beedee like this.
  8. May 2, 2023 at 12:25 PM
    So I guess the question arises - when does a company put an offering on their website? Once they have inventory to create orders and ship it, or do they just throw it out on their site hoping to get orders generated, then actually have inventory made, and ship it when done...?
    These seemed like a very interesting alternative, but so far there's no evidence they really exist.
  9. May 2, 2023 at 1:40 PM
    beedee
    beedee Member
    Interesting question. I know they have been making Tacoma ones for awhile now. I've seen a few posts/ads for them on FaceBook with tons of comments. Some saying they had to wait nearly 8 weeks. Really hoping that isn't the case.
  10. May 2, 2023 at 2:44 PM
    CMM15
    CMM15 New Member
    I ordered mine on 4/2/23 and I just received a shipping update today. Should arrive on Friday.
    Rocko9999 likes this.
  11. May 2, 2023 at 3:37 PM
    Captain Sensible
    Captain Sensible New Member
    I wouldn't do business with cali. I know they don't honor warranties.
  12. May 2, 2023 at 4:44 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    What other inexpensive options are there?
  13. May 2, 2023 at 6:39 PM
    08TXRunner
    08TXRunner [OP] New Member
    '20 SR5P
    I ordered mine on 4/1 and just got the same email. Should be here tomorrow. If so, I will do a short install thread. Looking forward to it.
  14. May 2, 2023 at 6:40 PM
    08TXRunner
    '20 SR5P
    That's a hell of an accusation. Post up your proof or GTFO.
  15. May 2, 2023 at 7:30 PM
    Captain Sensible
    Alright. Since you insist. Hi Jake, remember me? The guy with the cali raised lights that were professionally installed by SWAT Customs and later filled with rain water, and after you realized I already bought 2 replacement lights, (cuz that's how many had failed at that time) you refused to warranty any of them after 1 rainy season leaked water into them. Even though the website says quote-
    We’re so confident in our products here at Cali Raised LED that we tack on a 2-year warranty to help protect your investment no matter how rigorous a lifestyle you live.
    Sorry to be a dick Jake but I'm still bitter.
    Before- https://youtu.be/dOsc5V3-XI4
    After 1 winter- https://youtu.be/8uFNNyYXyOc
    5six likes this.
  16. May 3, 2023 at 2:26 PM
    beedee
    beedee Member
    Just got my shipping info an hour ago.
    Ordered April 7th, scheduled to arrive this Saturday, May 6. :)
    waldo98, BgBmBoo and OverRunner like this.
  17. May 3, 2023 at 2:37 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Man, I’m sorry to hear that.
    My experience is the exact opposite. My ditch lights were working fine, but one of them developed a rattle (the reflector came loose). I prepared myself for a battle with Cali-Raised, and called them up. They asked for a video of the ratting. My video sucked, so I asked if I could drive up there (45 mins away). The nice gentleman came outside and when I smacked it, it rattled. He asked if I minded removing it to confirm it’s the light. I came prepared and unbolted one of the lights, and he shook it, handed it back, and walked inside to get me a brand new pair, on the spot, free of charge.
    I actually wasn’t a huge fan of Cali-Raised prior to this (something about poor naming in Texas, lol), but they have won me over.
  18. May 3, 2023 at 4:26 PM
    08TXRunner
    '20 SR5P
    Mine is scheduled for today, but as usual, the FedEx site is all kind of weird. Will post pics when it arrives.
    beedee likes this.
  19. May 4, 2023 at 9:37 AM
    #49
    08TXRunner
    '20 SR5P
    And here we go. Really good quality with no sharp edges or fractures in the bends. I'll take a few pics this weekend when I have time to install them.
  20. May 4, 2023 at 9:50 AM
    #50
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    would like your opinion if they would have to be removed for any routine maintenance, like access to grease prop shaft, change transmission or transfer case fluid, etc.
  21. May 4, 2023 at 11:56 AM
    #51
    X2.
    salvojimmy[QUOTED] likes this.
  22. May 4, 2023 at 12:05 PM
    #52
    08TXRunner
    '20 SR5P
    I'll certainly take pics. But from the ones I see on Cali's site, these are tucked up and form fitting so they don't come anywhere near that stuff.
    I will say that just messing with them on the bench, the finish work is what impresses me. Frankly these are one hell of a bargain for under $200.
    beedee and salvojimmy like this.
  23. May 4, 2023 at 1:31 PM
    #53
    beedee
    beedee Member
    Awesome! Are you planning on getting 4 more security bolts? Or are you going to put one on each end of the support brackets rather than two on the same end?
  24. May 4, 2023 at 2:58 PM
    #54
    08TXRunner
    '20 SR5P
    I'd like the Cali rep to chime in here as to what they use to cut these. I've seen a lot of water-jetted aluminum and this doesn't appear to be that - it's way too clean and precise. No burrs, no slag, I'm guessing laser cut?
    In any case I'll start a new thread for the install this weekend. I slid up under the truck with one in hand and it seems like it's going to be ridiculously easy. Probably one of those "30 minutes the first time and 10 minutes the second time" things.
    Nubes likes this.
  25. May 5, 2023 at 9:52 AM
    #55
    08TXRunner
    '20 SR5P
    Would someone take a look at the install link below and tell me why these shields require a 4WD truck? I don't understand why. I swear when I placed my order, Cali's site said nothing of 4WD. Now it does, and I'm 2WD. Am I going to have to return them? Have not been able to reach anyone at Cali yet.
    Cali Raised LED Catalytic Converter Shields 5th Gen 4Runner (trail4runner.com)
    EDIT: Ok, I just pulled down the crossbraces and hand-fit the shields in place. They seem to fit just fine - I can't see why they would not fit a 2WD. Maybe it's just laziness that Cali didn't bother to check fitment. Any way I'll get them on this weekend and report back.
    2nd Edit: Cali confirmed they don't know if these will fit a 2WD and asked me to fit them up. The problem is that they didn't include the required transmission bolt spacers so I can't. So anyone attempting to install these, make sure you have all the hardware before starting.
    Nubes likes this.
  26. May 5, 2023 at 1:28 PM
    #56
    08TXRunner
    '20 SR5P
    OK, I used a straight edge and a depth micrometer and figured out what size spacers I needed, ran to Ace and got them.
    Boy was I wrong on the 30 minute install. The main problem is that when you are getting them into place to start running bolts in, you are juggling the front of the shield, the back of the shield (which is real hard to keep in alignment with the crossmember bolts due to the "slip in" design), and those damn crossmember support brackets. Anything slightly out of alignment will cause things not to line up. My very strong recommendation is to have a helper because one more hand to hold things while I started the bolts would have been a huge help.
    I did not use the security bolts for the simple fact that they are waay too short. By at least 10mm. Luckily I have a huge assortment of SS metric bolts from all my jetski projects. Here's the best I could do on pics:
    And if anyone needs the crossmember bolt spacers because they're not in your kit, go to ACE and get 1/2" thick spacers like these that will allow a 10MM bolt to go through:
    Doglover2003 and djwantke like this.
  27. May 5, 2023 at 1:44 PM
    #57
    beedee
    beedee Member
    Thanks for the update. That is a bummer about them not including the spacers, as well as the security bolts not being long enough. Wonder if they all are like that?
  28. May 5, 2023 at 1:51 PM
    #58
    X2. Their installation video clearly shows the spacers as part of the kit. I suppose they are the ones that go here:
    beedee[QUOTED] likes this.
  29. May 5, 2023 at 1:53 PM
    #59
    beedee
    beedee Member
    Yup, also concerning that the security bolts provided aren't long enough. I guess I'll find out tomorrow or Sunday. I'll report back here my experience as well.
  30. May 5, 2023 at 1:54 PM
    #60
    08TXRunner
    '20 SR5P
    I guess we'll find out soon. I would get four 40mm SS bolts to make life easier to replace the security bolts. I'm going to replace my hex heads with button head Allen bolts when I have time.
