Bronco versus 4 runner
Discussion in '5th Gen 4Runners (2010-2024)' started by Over the road, Jan 13, 2024.
  1. Jan 14, 2024 at 8:43 AM
    #61
    They did make that, it was the WK.
    Why on earth would you want IFS on one of these?
  2. Jan 14, 2024 at 8:45 AM
    #62
    I'd counter that as long as it had low range and good offroad specs, hardly anybody would care.
    Yotaholic[QUOTED] and icebear like this.
  3. Jan 14, 2024 at 8:51 AM
    #63
    Jeep has a lot of history on the Rubicon Trail, it makes sense to me that it's the top off-road
    trim.
    If they were to change the order around now, it would probably just confuse buyers. Like when Toyota came out with the "trail edition" SR5 a few years ago.
  4. Jan 14, 2024 at 8:53 AM
    #64
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I mean Jeep is Willys right? :p
    gomiami and Yotaholic[QUOTED] like this.
  5. Jan 14, 2024 at 8:58 AM
    #65
    To the OP's original question, I think it depends on your uses.
    Do you want a reliable and fairly capable appliance that you are going to use as a DD and put hundreds of thousands of miles on? Definitely 4Runner.
    Do you want something as a weekend toy that you can take the tops off and hit the trails? Definitely Wrangler.
    When the Broncos first came out. I was all in on them, I still think they look fantastic and have great specs. However, in real life, I'm just reading about too many issues with them, weaknesses, and reliability issues. Witnessing one blow the front differential on a simple obstacle sealed the deal for me.
    I think unless you absolutely love the look or are a Ford guy, the Bronco is just too middle ground. It's not as good on road as a 4Runner and not as reliable, and if you want something as a toy to build into a trail beast, the Wrangler is much better at that.
    I think the Bronco would be much better with a fixed roof, that would at least remove the issue of poor fitting and leaky/creaky tops.
    Yotaholic and gomiami like this.
  6. Jan 14, 2024 at 9:02 AM
    #66
    Hey OP @overtheroad
    Just look at this pathetic rear Bronco window. It doesn't even roll down. Dreadful.
    In other news, almost 8 years since purchasing, five All Auto windows, still perfect. Not so much as a single light bulb has malfunctioned on the 4R. Engine solid. Leather interior and steering still perfect in my case.
  7. Jan 14, 2024 at 9:09 AM
    #67
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    Please, no. If Jeep made more use of "Willys", I'd go nuts listening to folks mis-pronouncing it as "willies" rather then "Willis".
  8. Jan 14, 2024 at 10:35 AM
    #68
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    Everything!!!! Looks, reliability, simplicity (SR5 Premium), history, reputation, experience (with both a '92 Bronco vs 2 RAV4s, 2 FJ40s, 4 Trucks), Bronco negative reputation/reports/recalls. "Nuff said!
  9. Jan 14, 2024 at 11:03 AM
    #69
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    IFS is nice lol. For rock crawling the Wrangler is there.
  10. Jan 14, 2024 at 11:10 AM
    #70
    I’d honestly consider that, maybe not with how the new Frontier is going but on paper something between Outback/Passport and a bona fide 4x4 would tempt me. The interior packaging of the former with some of the goodies of the latter!
    The Cherokee TH, Grand Cherokee and Durango all sorta kinda fit with the Cherokee being spot on but was smaller inside than I expected and a Stellantis product, the middle is an upscale and also a Stellantis product. The latter requires the V8 to get low range and still had normal Durango angles.
    But then again, it’d have to compete with those modding the Outback/Passport/etc and a stock 4Runner/etc so it might just fail down the middle like most of the midsize BOF SUVs around and after the Recession.
  11. Jan 14, 2024 at 11:22 AM
    #71
    :101010:
    kmeeg[QUOTED] likes this.
  12. Jan 14, 2024 at 11:35 AM
    #72
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Done a LOT of rock crawling in my pre-Taco p/u!
    Yotaholic[QUOTED] likes this.
  13. Jan 14, 2024 at 11:38 AM
    #73
    Pre-'86?
    Yotaholic likes this.
  14. Jan 14, 2024 at 12:34 PM
    #74
    I will stop pronouncing it Willies immediately :hattip:
    Old Tanker[QUOTED] and Yotaholic like this.
  15. Jan 14, 2024 at 12:37 PM
    #75
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Yeah, an '85 SR5.
  16. Jan 14, 2024 at 1:00 PM
    #76
    Yotaholic
    Olympia, WA
    So I came here again with Viper Cut this time to get a good view. And this is the absolute max, which is not bad at all. I am confident I can take on a connected Rubicon and beat it any day of the week
    20240114_124957.jpg 20240114_125009.jpg 20240114_125022.jpg 20240114_125032.jpg 20240114_125046.jpg 20240114_125451.jpg 20240114_125112.jpg 20240114_125124.jpg 20240114_125140.jpg
    djwantke likes this.
  17. Jan 14, 2024 at 2:02 PM
    #77
    Yotaholic
    Olympia, WA
    I will keep saying Willies :)
    RumHamRunner73 likes this.
  18. Jan 14, 2024 at 3:09 PM
    #78
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Death wobble is a VIOLENT shake of the entire front end. Mainly Due to worn parts.
    4runner steering shimmy, more like a slight viberation. And its mainly from poor tire balancing.
    Thatbassguy and Yotaholic like this.
  19. Jan 14, 2024 at 3:14 PM
    #79
    Easily fixed, shouldn't even be an issue.
