Brite Box
Discussion in '5th Gen 4Runners (2010-2024)' started by Diazraf, Apr 24, 2024.
  1. Apr 24, 2024 at 10:57 AM
    Diazraf
    Diazraf [OP] New Member
    21 4Runner Premium
    Work in progress.
    Does anybody have experience with Brite Box the plug and play switch to turn on the fog lights whenever.
    Thanks in advance.
    LCJ77 and icebear like this.
  2. Apr 24, 2024 at 12:31 PM
    NE Runner
    NE Runner New Member
    Clint
    Lincoln, NE
    2018 Magnetic Gray TRD Off Road Premium
    Revtek 3/2 lift
    I installed it a couple of months ago. It was an easy install and I use it daily.
    LCJ77 and Diazraf[OP] like this.
  3. Apr 24, 2024 at 5:24 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I had it on my 2020 4Runner ORP. I removed it before I traded and reinstalled it on my 2022 4Runner ORP. I use mine all the time and I’ve never had a problem. The hardest part of the install was getting the wires through the rubber boot at the firewall. That was a little bit of a PITA but otherwise, the install was super easy.
    Diazraf[OP] likes this.
  4. Apr 24, 2024 at 5:46 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Does it require tapping into existing OEM wiring?
  5. Apr 24, 2024 at 8:21 PM
    Diazraf
    21 4Runner Premium
    Work in progress.
    I will give it a try then. Thanks!
  6. Apr 24, 2024 at 9:18 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
  7. Apr 25, 2024 at 3:53 PM
    Vito Corleone
    Georgia
    2022 4Runner ORP
    No. It is completely plug & play.
  8. Apr 25, 2024 at 4:45 PM
    icebear Recovering Kia Owner
    I’m pretty interested in this too, I really want to use the original switch on the stalk but it’s not clear if the current DIY mod applies to newer years. :/
  9. Apr 26, 2024 at 8:27 AM
    I read through multiple threads on the Brite Box Anytime mod, and did not see confirmation by anyone who had installed one whether the dash light still goes on when the fog lights are on, either with the BB switch on, or with the stalk switch with the BB switch off. Anyone able to answer that?
  10. Apr 26, 2024 at 8:56 AM
    NE Runner
    Clint
    Lincoln, NE
    Revtek 3/2 lift
    The light in the instrument cluster only illuminates when the headlights are on and the switch on the stalk is in the on position. The Brite Box switch illuminates when that switch is turned on, but the indication in the instrument cluster does not.
  11. Apr 26, 2024 at 10:00 AM
    Thank you. So when the Brite Box switch is not on, the fog light stalk switch and dash light function as usual...
    icebear and NE Runner[QUOTED] like this.
  12. Apr 26, 2024 at 10:23 AM
    NE Runner
    Clint
    Lincoln, NE
    Revtek 3/2 lift
    That is correct.
  13. Apr 26, 2024 at 10:35 AM
    One follow up question, as I am getting more interested in this product - when the Brite Box switch is off, do the fog lights only go on with the low beams as usual using the stalk switch, or do they work with the high beams also?
  14. Apr 26, 2024 at 11:10 AM
    NE Runner
    Clint
    Lincoln, NE
    Revtek 3/2 lift
    Everything operates normally. The BB switch is completely independent of the stock lighting switches.
    Trail4R.com has an article about the installation of the system. I would highly recommend looking at that first. The author suggests a minor change to the BB installation instructions that I believe is a very good idea. BB has you connect positive to the battery, this article recommends an add-a-circuit into an ignition controlled circuit in the fuse box so that you can't forget to turn the fog lights off when the truck is turned off.
    https://trail4runner.com/2021/11/24/brite-box-4runner-install-review/
    T in Texas likes this.
  15. Apr 26, 2024 at 11:34 AM
    Thank you. Good idea on the power connection. I did see some mention of a ground connection on some of the writeups, but don't see a separate ground wire mentioned on the Brite Box site.
  16. Apr 26, 2024 at 11:57 AM
    NE Runner
    Clint
    Lincoln, NE
    Revtek 3/2 lift
    Yeah, that blew my mind. There is no external ground. The only thing I can come up with to explain that is that it gets it's ground through the fog light connector.
  17. Apr 26, 2024 at 1:39 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    It all depends on which pwr supply you use. Same W/Rator lights. I have mine tapped into DRL's. In morning , dusk or rain I have DRL's Raptor & I select Fog lights.
  18. Apr 26, 2024 at 1:42 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Here's when I did the 2 light's install
    Got Raptor lights in, wired to tail lights & Brite box Anytime Fog lights. There's a "Cap" on the boot at firewall that Main harness & Hood release run through. I looked on the inside & saw that it was a tube, so I cut the "Cap" off & ran the single pwr wire for Raptor lights through, Then eventually I had the 3 pins from Pwr supply harness to get through there. I ran 0.041 safety wire from cabin to eng compartment, electric taped 3 pins into a tapered "bullet" re bent safety wire back & pulled it through!! When I tried it No lights, The fuse holder had receptacles off center. I spiral wrapped wires for both lights & Pwr supply for Brite Box, Tywrapped to Batt hold bracket. The other feature vs the "Antman" Mod I did to my 2018 is the OEM Fog Light switch on Turn Signal still works & If you use that the indicator on the cluster display shows those lights are on, W/Brite Box it does Not show they are on.
