Brite Box Anytime Fog Lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Vito Corleone, May 16, 2021.
  1. Dec 18, 2021 at 8:54 AM
    kwill
    kwill New Member
    Did you hook it directly to the battery or use an add-a-circuit?
  2. Dec 18, 2021 at 9:07 AM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    I did hook it up directly into the battery. I might try the add-a-circuit though.
  3. Dec 18, 2021 at 9:13 AM
    kwill
    kwill New Member
    It shouldn't make any difference. I tested mine by hooking directly to the battery first and it worked fine. I would contact Aspire--their customer service is good.
  4. Dec 19, 2021 at 3:23 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Has anyone figured out how to wire this so it can only turn when when the key is in the accessory position or when the vehicle is running? I have forgotten to turn it off once after parking. Would be nice if this shuts off when the car is off to prevent this in the future.
  5. Dec 19, 2021 at 3:29 PM
    kwill
    kwill New Member
    Look at the link I posted.
  6. Dec 19, 2021 at 9:13 PM
    Emmantik
    Emmantik New Member
    Thanks for pointing it out in that link!
    I currently have the anytime fog light option installed not the fogster option. Power wire is currently connected to the + side of the battery. If I switch that to plug into the INJ fuse slot instead like mentioned in the link, the fog lights will turn off when the vehicle is off? Or am I missing anything else? Thanks!
  7. Dec 19, 2021 at 9:46 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    It’s name is “The Britebox Anytime”. What it does is “anytime” you push the button to switch it On, the battery +12V is connected to the fog lights. No matter the state of the key position or if the engine is running or not.
    If you want the fogs to turn off when the engine is off connect that supply wire to a 12V source that acts that way. The INJ fuse is one.
    A&P and Emmantik like this.
  8. Dec 20, 2021 at 6:48 AM
    kwill
    kwill New Member
    Correct.
    Emmantik[QUOTED] likes this.
  9. Jan 1, 2022 at 2:06 PM
    TRDJay
    TRDJay New Member
    Jay
    I am about to buy the anytime kit (at least I think that’s the one I want) for my 21 orp but my question is, which version of this kit is the one that will make your low beams stay on while you have your high beams on? I thought I read when your high beams are on your low beams can stay on as well. Is that a different version of this kit? I’ve only read about the anytime fog light option so far on this thread. I would like the option to do both things if possible. Keep my low beams on with my highs if I want & also use my fogs ‘anytime’. If there is a certain kit I need to get for that please lmk. Or if that’s not possible & I have to choose one or the other also lmk please. Any info would be greatly appreciated. Thanks!
  10. Jan 1, 2022 at 2:21 PM
    kwill
    kwill New Member
    Why not direct your questions to Aspire? They'll steer you to the right solution.
    A&P likes this.
  11. Jan 1, 2022 at 3:00 PM
    TRDJay
    TRDJay New Member
    Jay
    I actually did. Right after I asked here I sent them an email. I think the answer is that the low beams do stay on with the highs and the fogs become an option via toggle switch (with the anytime kit anyway) but I hadn’t heard any talk of the low beams staying on with the highs throughout this thread so I just wanted to ask to get feedback from people who’ve already installed the Brite box. If I hear back from them before I get an answer here I will post their reply incase it helps anyone else. Thanks.
  12. Jan 1, 2022 at 4:16 PM
    kwill
    kwill New Member
    Yes, high beams, low beams and fog lights can all be on at the same time.
    TRDJay likes this.
  13. Jan 1, 2022 at 4:58 PM
    TRDJay
    TRDJay New Member
    Jay
    Excellent thanks! One more question, do the fog lights go on & off with the provided toggle switch or is that switch just to turn on the ‘anytime’ function & then u use the factory fog light switch? Just wondering if after this install the factory fog light switch is still used. Or is it only used when you want to use the fog lights as u would have pre-broke box install?
  14. Jan 1, 2022 at 5:13 PM
    kwill
    kwill New Member
    If the BriteBox switch is off the factory switches work normally, i.e. as designed. With the BB switch on the fog lights are on and the headlights can be low beam or both high and low beam.
    TRDJay likes this.
  15. Jan 2, 2022 at 11:38 AM
    TRDJay
    TRDJay New Member
    Jay
    Ok thanks, I get it now. Appreciate u taking the time to explain it. Placed my order for one & am looking forward to installing it.
  16. Jan 2, 2022 at 11:47 AM
    Did you order the 'anytime' or 'fogster' version?
  17. Jan 2, 2022 at 11:52 AM
    TRDJay
    TRDJay New Member
    Jay
    I ordered the anytime
  18. Jan 2, 2022 at 11:59 AM
    I just realized the anytime or fogster is determined by the installation, thanks.
  19. Jan 2, 2022 at 2:35 PM
    #49
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I want to order this so I can run the fog with hi beams since they are so terrible..
  20. Jan 2, 2022 at 2:43 PM
    #50
    DallasTRDPro
    Dallas
    I have the LED highs
    A&P[QUOTED] likes this.
  21. Jan 2, 2022 at 10:49 PM
    #51
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Sounds like you might want to look into the mod to turn your halogen DRLs into auxiliary high beams. Fogs plus high beams do not equal better high beam (distance) performance.
    Too Stroked likes this.
  22. Jan 3, 2022 at 3:30 AM
    #52
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    I have a '22 and am interested in both the Anytime Bright Box and the halogen DRL mod. Info or link on the DRL mod? Maybe I missed the DRL info
    Thanks
    peaceloveandtattoos likes this.
  23. Jan 3, 2022 at 7:16 AM
    #53
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    following
  24. Jan 3, 2022 at 4:44 PM
    #54
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    There’s a long thread on the other forum about upgrading to OEM LED headlights. Some people with the 2022 bi-LED headlights have said they made mods to power up the halogen DRLs when the high beams are on. I have not seen any detailed how-to instructions to do this. But if I did it I’d use a fuse tap to get headlight power, maybe from fuse (10A H-LP H-LO) (see page 2 of schematic), run it to a relay and control it with the LED headlight wire that selects high or low beams. Wire the relay output through a fuse to the right halogen high beam and through another fuse to the left halogen high beam. And provide a wire to GND for each headlight. This would require some cutting and splicing into the halogen headlights connectors, or using purchased mating connectors to be able to restore it to OEM. Note that you would not have DRLs anymore.
    Then there’s a thread about just converting the 2022 halogen DRLs to dim LED DRLs. At post 17 I posted the headlight schematics as a reference. Let us know if you do this mod. Good luck.
  25. Nov 13, 2022 at 3:46 PM
    #55
    Burnt Taco
    Tucson, AZ
    Reviving this subject.
    Anyone with a '22 done the install yet? If so, where did you plug in the fuse tap on the engine fuse box? Alterations? Recommendations?
    I've ordered one but seem to remember that the '22s have a different engine fuse box set up?
    Thanks
  26. Apr 3, 2023 at 4:48 PM
    #56
    4runningMan
    4runningMan New Member
    New Mexico
    Did you ever get this installed?
  27. Apr 3, 2023 at 7:51 PM
    #57
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
  28. Apr 3, 2023 at 8:09 PM
    #58
    Burnt Taco
    Tucson, AZ
    Waiting for it to warm up.
