Brand New 4 Runner Needs Front Differential
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner 19, Mar 12, 2019.
  1. Apr 22, 2019 at 6:41 PM
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    Mine had miles on it too. The corporate rep wanted to drive it before and after so he "could experience the problem for himself." It took about 8 weeks for mine in 2017 so I guess progress is being made. P.s, have the dealer check the needle bearing every oil change for tightness.
  2. Apr 22, 2019 at 8:31 PM
    Allaboutfamily
    Allaboutfamily Regular Hound Dog
    Brett
    2019 4runner trd off road premium
    My luck this will happen to my wife’s the day after I install the lift and then they’ll blame the lift and void the warranty.
  3. Apr 23, 2019 at 6:32 AM
    jgcaps
    jgcaps Lovin the Colorado Life.!
    CO
    2018 MGM TRD ORP KDSS 4Runner
    3" Icon Stage 2, 18x9 Fuel Beast wheels, 285/65/18 BFG KO2's, N-FAB Black Rock Rails w/removable steps.
    :laugh::lalala:
  4. Apr 23, 2019 at 7:20 AM
    WallyT4R
    WallyT4R New Member
    Just a reminder it's best to adhere to to the manual and drive in 4x4 10 miles a month to keep everything lubed up there and in working order.
    Tmiesowicz likes this.
  5. Apr 23, 2019 at 11:05 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    So what other stuff is in the manual I haven't bothered to read?
  6. Apr 24, 2019 at 6:17 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    so the casting of the front diff caused this problem... needle bearing is also a issue with this type failure but the needle bearing usually takes more miles to act up .. some reported 20K range then needle bearing ..
    if the dealership was gonna keep it for over a day to do the repair I would take the plates off runner ..
  7. Apr 24, 2019 at 7:22 AM
    WallyT4R
    WallyT4R New Member
    Except dealers have magnetic mount plates which may or may not scratch the paint when they slap them on to test drive the vehicle. Forty miles does sound excessive but that amount may be necessary to thoroughly check that everything is ok. I'm sure they have to also put it in and out of 4x4 a few times and may have searched out some dirt roads to do so. Dirt roads are sometimes far from dealerships.
  8. May 15, 2019 at 1:19 PM
    t4r_gonzo
    t4r_gonzo TTC #0148
    Jordan
    2019 4runner Trd Offroad
    damn you got unlucky with that one man. I had a 2019 trd offroad taco for right under 3 months with 2400miles and got rear ended by a ford edge. my insurance totaled it out had about 18k worth of damage but totaled it for structural damage. ended up getting my 5th gen 4runner.
  9. Dec 6, 2021 at 12:56 PM
    telkins88
    telkins88 New Member
    I just picked up at 2022 from dealer Saturday evening. I noticed an odd noise on the way home. I took it to the dealer today to find out they say it needs front differential replaced. Can’t believe this is still an issue.
  10. Jan 5, 2022 at 5:45 PM
    Will
    Will New Member
    2022 4 Runner TRD Sport
    just had front differential replaced in my 2022 today for noise.
    4runrun likes this.
  11. Jan 6, 2022 at 6:12 PM
    j cat
    j cat New Member
    massachusetts
    did the new front diff creates noise ?
  12. Jan 6, 2022 at 6:14 PM
    Will
    Will New Member
    yes. They screwed up my tie rod ends and smashed up my steer knuckle fixing it but differential is now silent.
  13. Jan 6, 2022 at 6:20 PM
    j cat
    j cat New Member
    massachusetts
    change the parts ... fix the rubber grease knuckle ... the idiot did not use a tool to remove the steering rods he used uses a hammer to smash up the knuckle ...
    did the china transfercase manufacture it ? lot of new toyotas have issues ...
  14. Jan 10, 2022 at 5:12 AM
    JL-2022
    JL-2022 New Member
    I am suspecting that my new 22 SR5 Premium is having the same issue. I first thought it was the tires but it didn't go away when I put the summers on. It does go away when I put it into 4wd though. Truck only has 700 miles on it now. Any tips for explaining this all to the dealer service? I am reading that some people have had trouble getting this all addressed as it looks like the last TSB is still for 2019
  15. Jan 10, 2022 at 11:40 AM
    j cat
    j cat New Member
    massachusetts
    go to the toyota dealership to inspect it , then post what your issue is ...
  16. Feb 7, 2022 at 11:46 AM
    22t4r
    22t4r New Member
    So glad I found this forum. My brand new 2022 s5r premium is having this exact issue. I’ve been driving myself crazy trying to figure it out, my best guess was something with the winter tires put on it. Same exact symptoms though, cyclic/rhythmic humming and slight vibration in the 40-50mph range, this morning I finally confirmed thanks to y’all that it goes away in 4hi. I’ll be taking it to the dealer with TSB in hand for a new diff at 2200 miles. I’ll try to remember to post an update.
  17. Feb 7, 2022 at 12:44 PM
    Good luck! Mine is intermittent. Dealer told me they couldnt replicate, said I had loud “off-road tires” (which was probably the bearing, in reality), charged me 150 bucks for the trouble, and sent me on my way.
    Various circumstances conspired to drop the vehicle off without me being along for the test drive so I could point out the noise. I would recommend going along with the tech or writer for the test drive.
    Thatbassguy and Toy4X4 like this.
  18. Feb 8, 2022 at 4:50 AM
    "Couldn't replicate the noise". This is an all too familiar response with some. The $150.00 diagnostic fee is just short of the cost of the ECGS bushing and puller/install tools, plus the aggravation of trying to "prove" there is a problem. Did anyone ever go under the vehicle and test the amount of 'slop' where the axle comes out of the diff.? Compare the pass. side with the driver side... my friend and I did, night and day difference. Good luck with this.
  19. Feb 8, 2022 at 5:44 AM
    #49
    Will
    Will New Member
    The $150 is flat out robbery. Keep that receipt. If they ever fix it under warranty you probably get a refund. I can’t believe a dealership would charge a diagnostic on a warranty claim. I’m just about done with Toyota and their practices lately.
  20. Feb 8, 2022 at 6:04 AM
    #50
    precisely what im planning to do. I’ve some time off coming up, and Im going to be stopping by more frequently and asking if they have anyone to come with me for a ride. Again, if the thing is noisy on the day Im off lol.
    Thatbassguy, AGRunner and Toy4X4 like this.
  21. Feb 8, 2022 at 3:34 PM
    #51
    JL-2022
    JL-2022 New Member
    Lots of different posts on this
    They are replacing my whole front differential on my 2022. I am just waiting for the parts to come in. Probably have the same issue but they should be held responsible. Maybe at some point they will get it really fixed with enough pressure from everyone
    j cat and AGRunner like this.
  22. Feb 8, 2022 at 4:21 PM
    #52
    AGRunner
    AGRunner New Member
    2022 TRD Offroad Prem.
    None
    There are now a few threads on this topic, and I think I've posted on all of them. Figured I'd provide an update here since this one has been popping up. This past Saturday the noise was very noticeable and constant, so my wife and I decided to stop by the dealership to have someone relisten to it. The assistant service manager rode along and informed me the service manager (guy who claimed he couldn't "locate" the noise) no longer works there. We barely made it out of the parking lot, and he could hear the noise. We took a short drive, and the noise could be heard plain as day. He arranged for a loaner and said they would get to the bottom of the issue. He contacted me today and said they verified it was the front diff and contacted Toyota who recommended the front diff be replaced along with the driver's side axle if it shows any wear/damage from the needle bearing. The parts are on back order, and we have the 4Runner back until they come in. Overall, we're relieved and feel much better that something is being done!
    Thanks again to the many folks on this forum for your contributions. I went in there on day one with a solid idea of the problem because of this forum. I'll be sure to update once the diff is replaced.
    j cat and Toy4X4 like this.
  23. Feb 8, 2022 at 4:32 PM
    #53
    Will
    Will New Member
    “parts on backorder” should tell you something is going on at a higher rate than usual right now.
    Tmiesowicz, j cat and McSpazatron like this.
  24. Feb 8, 2022 at 4:48 PM
    #54
    AGRunner
    AGRunner New Member
    None
    Good point!
  25. Feb 8, 2022 at 5:00 PM
    #55
    JL-2022
    JL-2022 New Member
    I was supposed to get a call this week to see when my parts might be in so I could schedule. Thanks for the heads-up ... I can probably expect to hear they were backorder as well.
    Glad to hear that they heard the problem. I think they need the pressure on them to address the issue. Maybe they will figure it out
    AGRunner likes this.
  26. Feb 8, 2022 at 5:51 PM
    #56
    Damn! What dealer??
    Wilde gave me no trouble. In case you're thinking of trying another.
    What's weird is how different it seems to be from one to the next. Some have no problem, some have the diff replaced and then no problem, some have had multiple replacements.
    I'm on my 2nd diff. Original was bad right away, but I ignored it for awhile. Had it replaced at 29K miles, then lifted. Now, I'm at 71K and no problem.
    Hopefully the 6th gen gets a new front differential!
    Tmiesowicz and Toy4X4 like this.
  27. Feb 14, 2022 at 9:16 AM
    #57
    telkins88
    Had the differential replaced at about 100 miles, now at 4,000 miles I’m having the same issue again.
  28. Feb 14, 2022 at 10:51 AM
    #58
    JL-2022
    JL-2022 New Member
    Yeah .. I just called the dealer parts department to find out the status of my front differential. They said it was backordered until April 25th. Guy said that as far as his computer says, there is not a single one in the country
    j cat likes this.
  29. Feb 14, 2022 at 12:37 PM
    #59
    2016Pro
    There's not a single anything in the country it seems like...
  30. Feb 14, 2022 at 2:56 PM
    #60
    Cleazy
    Cleazy New Member
    San Diego CA
    2021 TRD ORP MGM
    KO2 285/70/17 FN FX Pro Wheels Dobinsons Suspension 2.5/1.5 OME UCAs Sherpa Roof Rack Alpharex Luxx Tails
    Have q 21with 14k. After reading all the horror stories about shitty dealerships and multiple failures i went straight to the ECGS bushing install. $350. So far so good.
