Bilstein 5100s pics with settings
Discussion in 'Suspension' started by KSapanza4Runner, Mar 18, 2020.
  1. Jan 21, 2024 at 9:08 AM
    #181
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Did you ever get your rear done? Curious how it turned out. Looked good from those pics for just the front.
  2. Jan 21, 2024 at 10:40 AM
    #182
    Armena
    Armena New Member
    Armen
    2022 Magnetic Grey SR5
    K&N filter TRD matte black Pro wheels Stock size Nitto Terra Grappler G2’s Bilstein 5100’s. .85 setting 20% nano ceramic tint all the way around Pedal Commander. City +3 normally AJT climate and radio knobs AJT chrome door handle covers Carbon fiber interior accents. TRD shift knob LED interior lights/license plate LaSfit mats Exterior black out kit/steering wheel.
    Not yet, soon. Still stock in the rear. I was considering adding a .75 spacer in the back and going up to 1.75 up front but I think I will just leave it alone lol.
  3. Jan 21, 2024 at 3:46 PM
    #183
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Hey, lemme know if you want a new .75 Cornfed spacers. I went a diff route and they won’t refund, so they’re sitting in my garage. PM me & we can discuss $
  4. Jan 21, 2024 at 5:48 PM
    #184
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    ANYONE HERE HAVE 5100's SET HIGHER THAN LOWEST 0"/STOCK CLIP SETTING, AND RUNNING LIFT SPRINGS?
    thx
  5. Jan 21, 2024 at 5:56 PM
    #185
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    I did on my Tacoma… used Dobinsons 314 then added a bumper and sagged a bit.. ok per Crikey Mike. BUT max it to 2nd from bottom. Otherwise use a bigger coil
  6. Feb 18, 2025 at 6:33 PM
    #186
    NagsHeadDeerFly
    NagsHeadDeerFly New Member
    2011 4Runner SR5 Blizzard Pearl
    Bilstein 5100s, OME 884 front coils, Dobinsons 323 Rear coils, 275 Nitto Terra Grappler G3
    Really happy with how this turned out, big thanks to TEQ Customs in Raleigh for their excellent service. I’d highly recommend them if you are in NC.
    Bilstein 5100s, OME 884 front coils, Dobinsons 323 Rear coils, 275 Nitto Terra Grappler G3. 1.75 setting with half inch rear coils.IMG_0373.jpg IMG_0375.jpg
  7. Feb 19, 2025 at 10:44 AM
    #187
    Captain Sensible
    Captain Sensible New Member
    I had those rims on my taco. Gave them to a friend who had them powder coated and now I want them back-
  8. Feb 19, 2025 at 2:49 PM
    #188
    That’s exciting, happy for ya!
    Please report back on ride quality with your 5100’s clicked up to 1.75 setting; I run OME884’s on 5100’s as well but I’m at the lowest setting 0”.
    *technically Bilstein recommends in the 5100 documentation to not set the strut to the higher ring grooves (leave at 0”) if you’re running lift springs, which you are. the lift springs are to do the lifting in theory. the selectable ring groove settings are intended to lift trucks running factory spring length. OME884’s are virtually same spring rate as factory springs as well. BUT, I am actually going to click my 5100’s up from 0” to the first ring very soon, so don’t listen to me lol
  9. Feb 20, 2025 at 4:07 PM
    #189
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Crikey Mike advised me to do so on my Tacoma after adding a bumper…. Just more than 1 clip above bottom
    djwantke[QUOTED] likes this.
  10. Feb 20, 2025 at 6:53 PM
    #190
    Crikey Mike is a legend. That’s funny, I’m also cranking mine up one notch in anticipation of steel bumper (dom)
  11. Feb 20, 2025 at 6:55 PM
    #191
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    The spacing between each groove on the 5100 is 10 mm. The next groove up from stock results in 0.85" lift or almost 22 mm so 1.0 unit of lift at the strut is about 2.2 units at the wheel. I found this handy when guesstimating lift from the height of the strut assemblies.
  12. Feb 20, 2025 at 7:40 PM
    #192
    TrailSpecial22 New Member
    PA
    whilw youre under there, upgrade those front bumpstops if havent already.
    Higgbra73 and djwantke[QUOTED] like this.
  13. Feb 25, 2025 at 9:59 AM
    #193
    NagsHeadDeerFly
    @djwantke @Captain Sensible , ride quality thus far feels great. It’s not quite as stiff as i thought I would be but still just feels so much more “crisp” than the old setup did which has 160k miles on it. Took it out on the beach on Saturday and it did so much better than it had been previously in the sand as far as ride quality which was nice.
    I was dating my wife when she bought this thing off the lot new in 2011 and i remember thinking the wheels gave it a classic Mickey Thompson look at the time. They have aged pretty well I think. Overall I’m stoked. Had to trade my beloved Tacoma in for us to get a tahoe. So getting her hand me down 4Runner is actually starting to feel like an upgrade. They are such functional vehicles for surfing etc.
  14. Feb 27, 2025 at 5:49 PM
    #194
    Any smart suspension folks here know if this is true about 5100 lift adjustment being forbidden if you run 3” lift springs?
  15. Feb 27, 2025 at 8:05 PM
    #195
    Bilstein 5100 height settings go up to 2.75".
    With a 3" lift coil and the snap ring set to 0", you're already overextending the shock.
    I would definitely not go higher unless you're dealing with significant additional weight up front and even in that case I would recommend a smaller coil with a higher spring rate before using a 3" coil on that shock.
  16. Feb 27, 2025 at 8:10 PM
    #196
    Thank you for explaining, now that is something I can understand.
    My shop seemed to disagree at the moment, but I thought there was a type of top hat spacer that can give me more height without changing the strut and coil relationship ? (short of a body lift)
  17. Feb 27, 2025 at 9:35 PM
    #197
    @nimby
    Some new developments tonight from my shop. and I’ll say again, these guys are quite experienced.
    Looks like I can safely increase the circlip after all. I would value your opinion on what you think about this info and reasoning.
    • 884--- 2.5"-3" lift standard coils - Stock weight
    • Fitment Notes:
    • OME front coils can only be installed with OME Nitrocharger struts and coil seats
    • These coils will NOT work on stock shocks.
    So your coil springs are technically a 2.5-3" coil spring but ONLY when on an OME Strut which you do not have. This puts us in a really tough spot not having a pre-measurement of the truck and a post measurement when you put that system in unless you have that? I'm a bit concerned about the stock struts not working and the need for the OME coil seats as the 5100's essentially mimic an OEM coil seat.
    Furthermore, if you wanted to support for a bumper/winch setup properly then the front coilovers should be swapped out for something more appropriate and preferably something in an inverted mono-tube adjustable height coilover. I'm not sure the circlip on the 5100's would hold with heavier OME springs.
    So having found this out now, I think the best way would be to increase the circlip setting on the Bilsteins to increase the ride height and try to mimic where it would have sat on the Nitrocharger struts. There is no way for me to tell you how much to go up so you'll have to make a judgement call on this and let me know what you want to try.”
    I told him my before and after ride height:
    (noted after settling time):
    Before:
    19.5" front and 22" rear
    After:
    22" front and 23.5" rear
    Front 2.5-3" OME springs, Rear 2" ICON springs
  18. Mar 1, 2025 at 7:53 AM
    #198
    I don't know enough about the interaction between OME coils and 5100 spring perches to give you an informed opinion on combining the two. But frankenstein-ing coils and shocks in this situation sounds problematic to me.
    If it were me, I'd spring for some new coils of the appropriate size and spring weight to accommodate the bumper you plan on. I don't think it's worth holding on to OME coils and trying them work. Coils really aren't that expensive. I'd check with Dobinsons first.
    If you're in a pinch and need the truck back right away, then I guess you could go with OME coils. Just know it's a gamble and it might not work like you hoped.....in which case you'd have to buy the new coils and pay for labor twice instead of just the once.
  19. Mar 1, 2025 at 8:26 AM
    #199
    Thanks buddy, smart advice.
    4 Wheel Parts installed my lift in 2021. They were quite reputable at the time and specifically chose OME coils to go with the Bilsteins, and had done so many times before. This information about the OME springs not playing nice with 5100 perch is news to me that I’ve never read anywhere. I actually think there’s no problem or risk, and I would be surprised that Bilstein built a perch that can’t handle slightly heavier gauge lift springs. I would think I just need to switch to Bilstein springs, if anything.
    Fckn 4 Wheel Parts…lol
    When I get a winch bumper, I was not planning to be in the market for all new struts. I am now though :p
    nimby[QUOTED] likes this.
  20. Mar 1, 2025 at 8:41 AM
    #200
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    I did this for several years on my Tacoma with 5100’s and DOB 314’s w zéro issues and did not notice ride diff. But I also did it due to bumper install (keep that in mind)! Not much diff than adjusting a coil over. BUT, was warned not to exceed more than 1 circ clip from bottom (if using a lift coil).
    djwantke likes this.
