Bilstein 5100s pics with settings
Discussion in 'Suspension' started by KSapanza4Runner, Mar 18, 2020.
  1. Aug 8, 2023 at 6:36 AM
    #151
    ak1215
    ak1215 New Member
    2022 Army Green ORP
    Appreciate the response. I have a Tacoma with bilsteins (5160/6112 combo) that I love. I had the Eibach pro lift that I got for a major steal back in 2019 that were ok but had this clunk that I was chasing. Swapped to the bilsteins and couldn’t be happier. I’m trying to do a little more research before I throw anything on it. Love the look of your truck, exactly what I’m looking for stance wise.
  2. Aug 8, 2023 at 6:58 AM
    #152
    OEFVet84
    OEFVet84 New Member
    Eric
    2020 ORP
    I don't do any regular off-roading, but do get off the pavement in the winter for some backcountry skiing. That said, this setup makes a lot of sense for a lot of people. I didn't want to reuse the factory front springs, so once I considered adding the cost of springs along with 5100s for the front, upgrading to 6112s really started to make sense. Aesthetically, I felt like the 1.75" lift with the 5100s also wasn't quite enough and didn't want to add a spacer to make up the difference. 1/4" is really darn close to split hairs, but I'm very picky with a truck's stance and my cargo area sits empty 99% of the time. It's obviously a personal preference and I'm not here to knock anyone who loves their 1.75/1" setup — just wanted to emphasize how happy I am with it. Glad you like it and thanks again for the compliment.
  3. Sep 22, 2023 at 10:21 PM
    #153
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    Here’s my take, just installed the 5100 set to 1.75 with stock springs. Rear is still stock, but I’ll put the rear 5100s and 1” cornfed spacer tomorrow after work. I’m debating if I want to bump the fronts to the highest setting but I’ll wait to see how it all settles after a couple days. Anyone else running the 5100s with stock springs set to 2” lift with 1” rear spacers?
    Sitting on 285 70 17 Toyo AT3
    On a side note if anyone is local in NorCal and needs help adjust or wanting to lift, I can do it all with the proper tools
    Shredder, mr h, justinfro and 2 others like this.
  4. Sep 23, 2023 at 5:02 AM
    #154
    TrailSpecial22 New Member
    PA
    I am. Look on page 5, post #142. And i didnt unbolt the upper ball joint to install or use a spring compressor.
  5. Sep 23, 2023 at 7:34 AM
    #155
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    Where tire would catch lower edge of front bumper while turning and hitting the driveway just right. Tires already removed paint so I blended that area just enough. With the lift it slightly still hit but not as loud of hit gouging into the bumper edge. But this should clear just fine now. (Yes, I went higher up to give it a blended shave rather than an obvious trim I’ve seen on others)
  6. Sep 23, 2023 at 7:40 AM
    #156
    HighSierraGuy
    HighSierraGuy New Member
    Where in nor cal are you?
  7. Sep 23, 2023 at 7:52 AM
    #157
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    Vacaville
  8. Sep 23, 2023 at 9:58 AM
    #158
    PA
    did you take your front mudflaps off?
  9. Sep 23, 2023 at 10:28 AM
    #159
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    yes, before lift they rubbed crazy but i melted them and will put them back on to see how they fit now
  10. Sep 23, 2023 at 12:49 PM
    #160
    PA
    good deal!
  11. Sep 23, 2023 at 1:26 PM
    #161
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Nice! Slick ride. Totally the #1 spot for trimming. I got 3/2 lift done, rubbed there full turn reverse and shop dremel cut it right there and then
  12. Sep 23, 2023 at 3:25 PM
    #162
    kojak
    kojak New Member
    21 SR5P 4x4
    5100 fronts set to 1.75
    Just got the 1" rear spacers in, whew. Has anyone driven around like this for a while before upgrading the rear shocks? Seems like they'd be a trivial task to replace.
    Measures 21.5" on the front driver's side, 22" at the other three--I expected a little more rake.
  13. Sep 23, 2023 at 4:53 PM
    #163
    PA
    id swap out the rear shocks asap. You wont regret it
  14. Sep 23, 2023 at 6:40 PM
    #164
    HighSierraGuy
    sweet, I'm near Sac. Did you go with SL or C rated AT3's? Truck looks great.
  15. Sep 24, 2023 at 11:29 AM
    #165
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    All done added the rear cornfed spacers and the bilstein rear shocks. I don’t know why some say it’s too stiff but we all have different comfort levels. Purposely drive over turn about curves and it’s smooth. Pot holes and rough roads great. Braking nose dive and squishy feels all gone. Great setup. I don’t have the drivers side lean but I’ll check on level ground in a couple days. My driveway is sloped so here it is parked both ways. And an additional view
  16. Sep 24, 2023 at 11:30 AM
    #166
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    I went with C rated. No need for anything more for what the 4Runner will see. I should’ve weighed them. I think the new setup weighs less than the original setup!
    mr h likes this.
  17. Sep 24, 2023 at 11:45 AM
    #167
    PA
    looks awesome!
    svc707[QUOTED] likes this.
  18. Sep 27, 2023 at 1:13 PM
    #168
    kojak
    kojak New Member
    21 SR5P 4x4
    They're on the way; I'll at least have some time on the fronts only so I can make an informed comparison.
    Then we'll see how long I can hold out before upsizing the tires.
  19. Sep 27, 2023 at 1:31 PM
    #169
    svc707
    svc707 New Member
    Steve
    2023 Lunar Off Road
    Just order the tires now too :)
    kojak[QUOTED] and TrailSpecial22 like this.
  20. Oct 13, 2023 at 7:06 AM
    #170
    kojak
    kojak New Member
    21 SR5P 4x4
    FINE
    285/70 Wildpeak SL. The rear 5100s were worth it--corners tighter and nose dive under braking was further reduced.
    Wonder if the unsettled feeling over high speed bumps is due to the panhard bar angle, or is that even a thing with a 1" rear lift? This has been the only noticable drawback (besides fuel economy).
    Eventually I may get Dobinsons or similar especially as I add weight. I'll rethink the front shocks at that time but for now I'm quite happy with the suspension. Could see going a little higher too.
    svc707[QUOTED] and djwantke like this.
  21. Oct 13, 2023 at 7:14 AM
    #171
    Nicely done, great to see!
    Good to know, and can you please elaborate on what the unsettled feeling over high speed bumps feels like.
    Cheers
  22. Oct 13, 2023 at 7:16 AM
    #172
    I have 5100's on all four corners, plus lift OME lift springs and ICON coils. But I have not installed anything for any angle correction, except for diff drop kit. Thx
  23. Oct 14, 2023 at 8:32 AM
    #173
    kojak
    kojak New Member
    21 SR5P 4x4
    Hard to define but it's probably just an artifact of a stiffer shock. There's more side to side motion and a slight bump steer, while the softer stock shocks soaked up the bumps like an old Caddy.
  24. Oct 22, 2023 at 7:36 PM
    #174
    tameImpala
    tameImpala New Member
    im getting this as well two weeks after installing 5100s
  25. Oct 30, 2023 at 6:19 AM
    #175
    mr h
    mr h New Member
    scott
    Tucson, AZ
    front leveling kit, dog fur
    i’ve noticed load range E tires tend to make this worse.
    load C’s are much more well behaved over rough roads IMO
  26. Oct 30, 2023 at 12:28 PM
    #176
    kojak
    kojak New Member
    21 SR5P 4x4
    Interesting. I've got SLs though!
    Perhaps I just do away with the the preload and spacers. Any suggestions for springs? Adding around 100lbs up front anyway, plus I need a bit more rake for cargo.
  27. Oct 31, 2023 at 1:31 AM
    #177
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    How many miles do you have on your truck? Mine too started feeling a bit more "unsettled" right at 2 wks after I installed mine. Ive got 90K and im thinking its bc of old coils with new firm shocks. I put Dobinsons on my Tacoma and what a massive difference in ride quality with 5100's. Ill be doing the same with this!
  28. Nov 20, 2023 at 7:03 AM
    #178
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Put Dobinsons 302 2.5” coils on 5100 @ lowest clip & Ironman light load 1.5” rears
    djwantke and TrailSpecial22 like this.
  29. Dec 4, 2023 at 7:32 PM
    #179
    Armena
    Armena New Member
    Armen
    2022 Magnetic Grey SR5
    K&N filter TRD matte black Pro wheels Stock size Nitto Terra Grappler G2’s Bilstein 5100’s. .85 setting 20% nano ceramic tint all the way around Pedal Commander. City +3 normally AJT climate and radio knobs AJT chrome door handle covers Carbon fiber interior accents. TRD shift knob LED interior lights/license plate LaSfit mats Exterior black out kit/steering wheel.
    These made up my mind. I’m going with .85 up front and no lift in back. I’m running stock size Terra Grappler G2’s so it should look pretty good.
    glwood54[QUOTED] likes this.
  30. Dec 9, 2023 at 8:35 PM
    #180
    Armena
    Armena New Member
    Armen
    Bilstein 5100’s just in front. .85
    2022 SR5. 5100’s front only set at .85. Rear is stock for now. I’m doing the back next month. Pretty happy with how it turned out! Stock tire size. Nitto Terra Grappler G2’s!
    laxman09, HuskerRunner and nimby like this.
