Bilstein 5100s pics with settings
Discussion in 'Suspension' started by KSapanza4Runner, Mar 18, 2020.
  1. Dec 18, 2020 at 7:51 AM
    #61
    Alive and well.
    913Racing likes this.
  2. Dec 18, 2020 at 8:00 AM
    #62
    Check out the link in post #2.
    913Racing[QUOTED] likes this.
  3. Dec 18, 2020 at 9:27 AM
    #63
    913Racing
    913Racing New Member
    2021 MGM TRD ORP
    I appreciate it. Will do! Thank you.
  4. Jan 17, 2021 at 6:35 PM
    #64
    2021T4R
    2021T4R New Member
    2021 ORP KDSS
    Hey guys! New here. I’m looking for a way to reduce the nose dive and motion sick feeling I get driving my 4Runner. My 2021 ORP has KDSS. I’d like to try a set of 5100s at .8” on the front. Can anyone walk me through install on these with KDSS? My dealer didn’t have a clue, and the 4wd shop here has never heard of it. Just changing shocks here. Stock alignment settings after install?
    Toy4X4 likes this.
  5. Jan 17, 2021 at 9:48 PM
    #65
    Search "4runner kdss lift installation" on Google. Plenty of threads/videos on the process. I could rewrite my installation, but it's been well documented.
    'The 4wd shop here'? As in, the only 4wd shop? KDSS has been around for several years...did the shop know how to change struts on a non-KDSS 4R?
  6. Jan 18, 2021 at 2:26 AM
    #66
    Welcome from Wisconsin!
  7. Jan 18, 2021 at 6:21 AM
    #67
    2021T4R
    2021T4R New Member
    2021 ORP KDSS
    I am not doing coils or UCAs, which I understand can make it much more difficult. I can’t find a write up or video for only swapping to 5100s. The shop has done many non KDSS 4runners but didn’t know if the KDSS or swaybars needed disconnected. I don’t want to leave things up chance. Also, with .8” front lift do stock alignment specs still apply ?
  8. Jan 18, 2021 at 7:26 AM
    #68
    The rear shocks are a no-brainer, just remove and replace. The front, though, is more involved. You say you're not "doing coils or UCAs,", yet just installing the Bilstein struts @ .85 is as involved as putting on new coils, because you still have to pull the stock coils to put them on the Bilstein struts. There are several methods of pulling the struts & coils, some of which involve disconnecting the front anti-sway bar from the lower control arms (the method I used), and others that don't. I researched for weeks before I attempted my install of Eibach struts and shocks, which was exactly the same as you are wanting to do, just a different brand.
    As far as alignment goes, I took mine to a Toyota dealer for the alignment. I don't know what the specs are, they just did what they do...it does need an alignment after the installation.
  9. Jan 18, 2021 at 7:28 AM
    #69
    2021T4R
    2021T4R New Member
    2021 ORP KDSS
    Great to know. Did you keep the stock alignment specs to align after your install? What was the process you used to properly disconnect the sway bars?
  10. Jan 18, 2021 at 7:39 AM
    #70
    I edited my post above in regard to the alignment - I took it to the Toyota dealership service dept. for the alignment, so I figured they knew what to do.
    On the KDSS, I put a ratchet strap around the cylinder at ride height to keep it compressed, then proceeded to unbolt the anti-sway bar from the control arms and just hang free, also with the truck still on the ground. Once I had the truck on jack stands, replaced the struts on each side and everything was back together and back on the ground, I reconnected the bar and took off the ratchet strap. I'll see if I can find some photos of my install.
    I have read other install methods that don't disconnect the ant-sway bar, however.
  11. Jan 18, 2021 at 7:46 AM
    #71
    I understand your concern about the KDSS system and what is involved. The shop I was going to have install mine, however, knew what was involved. I just ended up doing it myself after all. If that dealer and shop you talked to are your only options, I'd be concerned also, since they are unfamiliar with the KDSS system...which seems odd for the dealer. Unless the never install lifts of any kind...
    Where do you live?
  12. Jan 18, 2021 at 8:08 AM
    #72
    2021T4R
    2021T4R New Member
    2021 ORP KDSS
    Erie Pennsylvania. People in this area are incredibly cheap. The dealer will only stock base SR5 because people here are too cheap to pay for any options. They have NEVER sold a KDSS 4Runner. They didn’t even know it was a thing. I bought my 2021 500 miles away because the dealers here wouldn’t even order an ORP KDSS
  13. Jan 18, 2021 at 9:05 AM
    #73
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Just do some research regarding the install on google and YouTube. Plenty of KDSS suspension install videos out there. Your install will be just like theirs. You will need an alignment and yes, just use the OE specs with a .8 lift and, I'm assuming, stock sized tires. You should have no problem getting OE spec alignment with that lift. I recommend changing the rear shocks at the same time, also to 5100's.
  14. Jan 18, 2021 at 11:33 AM
    #74
    Here's some photos from my installation.
    Showing the KDSS cylinder strapped up, done at ride height before doing any lifting of the vehicle for suspension work, even though it shows the wheels off later on:
    Disconnecting the two lower control arm sway bar brackets, also done at ride height, after strapping the KDSS cylinder:
    The rest of the install was just following YouTube 'no spring compressor method' videos for replacing front struts.
    This was my synopsis of the process:
    https://www.4runners.com/threads/glwood54-vs-stock-4r.12659/page-3#post-142135
    captainSteve likes this.
  15. Jan 18, 2021 at 2:13 PM
    #75
    2021T4R
    2021T4R New Member
    2021 ORP KDSS
    Excellent! Thank you! Did you strap both sides or just driver side?
  16. Jan 18, 2021 at 3:25 PM
    #76
    There's only one cylinder, on the driver side. The other side has a solid link, no cylinder. The rear is the same way, but you don't do anything to the rear KDSS to change shocks.
  17. Jan 20, 2021 at 6:59 PM
    #77
    DJPSC
    DJPSC New Member
    2021 4Runner TRD Off Road Premium Super White KDSS
    XP Package, KDSS, TRD Wheels, Pro Grille
    Just got mine done on Monday/ front only 1.75. I’m still stock in back which is roughly 1 inch higher to take into consideration for passenger and gear. Happy so far with the look and also ride feel 36F52EED-F6B9-4B09-BD92-2A0BE1F04064.jpg
    jblawrence25 and Reldn like this.
  18. Feb 8, 2021 at 1:36 PM
    #78
    913Racing
    2021 MGM TRD ORP
    I know each dealership experience will be different, but have any of you had the 5100s installed at a dealership? If so, any concerns? Price?
  19. Feb 14, 2021 at 9:26 AM
    #79
    913Racing
    2021 MGM TRD ORP
    Where are you taking measurements to determine the rear is still one inch higher? Thank you.
  20. Feb 14, 2021 at 9:51 PM
    #80
    DJPSC
    DJPSC New Member
    I measured from the ground up, but after reading many posts I ended up ordering the 1 inch corn fed spacer to ensure it would account for passengers/gear. Also adding rear billstein 5100. Install should be in next couple of weeks
  21. Feb 15, 2021 at 4:37 AM
    #81
    913Racing
    2021 MGM TRD ORP
    Thank you for your reply. After reading through this thread, many posts said .85 would level so I was just curious about your experience and what you measured. Again, the information is much appreciated! Thank you.
    DJPSC[QUOTED] likes this.
  22. Feb 15, 2021 at 5:01 AM
    #82
    DJPSC
    DJPSC New Member
    NP 913! There are so many informative posts here that truth be told, I just liked (personal preference) the look of the 1.75 better. The great thing about the Billstein is the flexibility to go with 0-2.75 on four settings. I was incorrect with my original post as even with the back higher, it was almost a reverse rake when I had cargo in back. I’ll make sure to send updated pics once the back gets installed
  23. Feb 15, 2021 at 5:12 AM
    #83
    913Racing
    2021 MGM TRD ORP
    10 4. I agree, everything comes down to personal preference. Your 4Runner looks clean. Looking forward to the photos. Sorry, one last thing ... were there any issues with installation or alignment? Again, thank you for the information!
  24. Feb 15, 2021 at 5:29 AM
    #84
    DJPSC
    DJPSC New Member
    Thanks 913! Appreciate that. I had zero issues with alignment to date. Just took her out Saturday/Sunday for a 600 mile spin and also no issues 75+ on Highway. I’m not a fast driver by any means (we don’t buy these amazing vehicles to go fast!)....but it was my first long Highway trip and I was pleased with the ride.
  25. Feb 15, 2021 at 7:13 AM
    #85
    913Racing
    2021 MGM TRD ORP
    Good to hear there were no issues! Thanks again!
  26. Feb 16, 2021 at 3:41 AM
    #86
    Lab Hiken
    Lab Hiken New Member
    2020 SR5 4x4
    2” front 1.5” rear on 275/70/17 Falken Wildpeakes
  27. Feb 21, 2021 at 3:29 PM
    #87
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    That's looking really good! I'm going to guess that the Eibach's set at 1.6 will look almost exactly like this as well. I think I may end up setting mine at that height instead of the .85 setting I was initially planning on.
  28. Feb 21, 2021 at 4:53 PM
    #88
    DJPSC
    DJPSC New Member
    Good luck Reldn! Billstein has 0, .85, 1.75 and 2.75. I read so many informative posts on this forum and ended up with 1.75. Take before and after pics! Sure it will look great for you.
    Reldn likes this.
  29. Feb 27, 2021 at 7:35 AM
    #89
    adrian2310
    adrian2310 New Member
    Adrian
    2021 trd o/r
    265/70R17 ko2’s
    Hey guys. New to the forum. I have a base 2021 trd off road. Got the 265/70r17 ko2’s. It only has 1600 miles, decided to get the bilstein 5100 on the front for the mean time, rears are on back order. My issue now is that after doing the lift on the second Clip .85 to get it leveled it got more, about 2” and now it has a reverse rake. The front is sitting taller than the rear. The gap between the tire and the fender is the same front and rear. Has anyone experienced something like this. Mine doesn’t have the kdss. My alignment came out ok but is already maxed out. Will have to re-do the whole thing again and try the first clip to see if is going to level.
  30. Feb 27, 2021 at 7:38 AM
    #90
    Sounds like your spring perches might be upside down.
    Take a picture and we can confirm or debunk.
