BF Goodrich All Terrain A/T KO2's
Discussion in '5th Gen 4Runners (2010-2024)' started by ivanoverland, Jan 13, 2020.
  1. Dec 26, 2020 at 11:04 PM
    #61
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Sweet! Thanks a bunch Bassguy. Hope you can keep us updated on your experience with them. I'll be interested to hear about winter driving when you have some more of that.
    In the meantime, how do they seem in the wet? And on the highway? As I've mentioned in some other posts, one of my few complaints about my 4R is the amount of steering correction needed at highway speeds. I'm guessing that some of this is due to the nature of the vehicle (high wind resistance and relatively soft/long travel suspension) but I've wondered if there are great tires out there that would also track better than the stock Duelers on my Limited. I def plan to upgrade these tires once I start driving more!
  2. Dec 28, 2020 at 2:53 PM
    #62
    Starr
    Jonathan
    SouthEast Maui
    KO2s are great tires. Especially if you put them in harms way, the E Rated KO2s will survive and get you where you want to go. Been running them on multiple vehicles for many years.
    ThePnsh3r and Thatbassguy like this.
  3. Dec 29, 2020 at 10:00 AM
    #63
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Per the original poster, I'm in my third set of those BFG-A/T tires with my 2010 FJ Cruiser, and will use the same tire on my 2021 4R/ORP in March.
    They seem to be a good combination on/off road tire. Rotating the tires every 10,000 miles I always get 60,000 miles out of them. Never an issue with them in my case. And they look good !! LOL.
    By the way, the OP's photo of his rig appears to show these tires on stock type rims with the white letters on the tires outward. Looks really good.
    Hmmmm....maybe I'll go this route versus the TRD wheels (?) Thanks for that photo. I plan on ordering the same dark grey.
    Rick
  4. Dec 30, 2020 at 10:27 AM
    #64
    Do you have aftermarket UCA's?
    What's your caster set at?
    Singleminded[QUOTED] likes this.
  5. Dec 31, 2020 at 10:41 AM
    #65
    Singleminded
    OEM LED foglights
    Thanks for follow up on this. Mine is all stock. OEM tires, suspension etc. I've wondered about the caster (and/or camber and or toe?) but it hasn't been measured.
  6. Dec 31, 2020 at 10:59 AM
    #66
    No worries man.
    It sounds like you could reduce the wandering with a higher caster number. If you're stock, you should ask them to adjust your caster to the higher end of spec (somewhere between +3.5 - 3.9 degrees). That will make it track straighter and tighten up the steering wheel a bit.
  7. Dec 31, 2020 at 11:02 AM
    #67
    Singleminded
    OEM LED foglights
    Sweet, thanks nimby.
    SM
    nimby likes this.
  8. Dec 31, 2020 at 12:14 PM
    #68
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    When they start that I pull the weights and put in beads. I’ve had great luck on my ‘97 F-350 with a lb of beads in each running Mud Grapplers.
    EDIT: when they don’t balance great anymore.
  9. Feb 24, 2024 at 12:24 PM
    #69
    verdelaw
    verdelaw New Member
    Elyas
    2011 White SR5
    Running boards, grill, ladder... that's it!
    Can I see a picture please? I'm thinking about doing the same thing on my white 2011 SR5.
  10. Feb 24, 2024 at 12:27 PM
    #70
    verdelaw
    verdelaw New Member
    Elyas
    2011 White SR5
    [/QUOTE]
    Hey there.. semi-related: what size tire are you running in these pics? Thanks.
  11. Feb 24, 2024 at 2:05 PM
    #71
    smatson
    smatson New Member
    Scott
    2019 TRD PRO
    Westcott lift / Mickey Thompson Baja Boss AT’s / S&B CAI/ Sprint Booster / DDS3 Max PODS / TRD Exhaust
    Ran multiple sets of KO2’s for years and years (C-Load 285/70/17) and overall I really liked the look, performance and versatility of these tires. The had always been my go-to-tire.
    My only real complaint was driving in wet conditions. Tires didn’t always seem to grip well braking in wet conditions, occasionally slipped out when cornering and hydroplaning in standing water situations.
    I live in the PNW where it rains all the time and I commute about 75 miles per day on highways with grooves, that are poorly lit that are constantly under construction.
    When I replaced my tires a few months ago I did a ton of research and ended up switching to Mickey Thompson Baja Boss AT’s - so far these are the best tires I’ve ever owned and I e not had any wet driving issues.
    The only downside thus far is the extra weight resulting in 1 less mpg.
    Just my 2-cents having been a lifelong BFG loyalist who was open minded, and nervous, about making a switch…
