Best Angle for 4Runner Picture?
Discussion in 'General 4Runner Talk' started by Awales74, Jan 31, 2024.
  1. Feb 2, 2024 at 3:47 PM
    #61
    Daddykool
    It does look angry, though.
  2. Feb 2, 2024 at 3:52 PM
    #62
    backpacker
    backpacker New Member
    2023 TRD ORP
    It has IFS - independent fin suspension
  3. Feb 2, 2024 at 4:11 PM
    #63
    Rightfully so. He thought he was getting a free dinner, until that hook sank in. :D
  4. Feb 2, 2024 at 5:42 PM
    #64
    :rofl::rofl::rofl:
  5. Feb 2, 2024 at 7:06 PM
    #65
    Steve Berman
    Steve Berman New Member
    pissn on tha pump lmao I like it
  6. Feb 2, 2024 at 7:10 PM
    #66
    Steve Berman
    That's insane, if it's not concealing the wiper, then it must be mpg? rain protection when the rear window is down?
    Still a bad ass generation w/ the proven V8
  7. Feb 2, 2024 at 7:13 PM
    #67
    Steve Berman
    Heaven!!! Is this an offroad excursion and/or your driveway? Chains? ATs?
    Hope it snows again soon
    djwantke likes this.
  8. Feb 2, 2024 at 7:15 PM
    #68
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Thanks! My house sits on 40 acres. I have several trails throughout the property and this is the main trail. I would not have gone unstuck on most of the other trails.
  9. Feb 2, 2024 at 7:34 PM
    #69
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I also concur
    My recommendations should stop sleepin on dem 2010-2013
  10. Feb 2, 2024 at 7:37 PM
    #70
    That V8 is the kicker, yes sir. The V8 4th Gen is your classic butterface. Forget her face
  11. Feb 2, 2024 at 8:23 PM
    #71
    Yotaholic
    Yotaholic New Member
    Olympia, WA
  12. Feb 2, 2024 at 8:29 PM
    #72
    Having a body of water in the background helps.
  13. Feb 2, 2024 at 8:31 PM
    #73
    Yotaholic
    Olympia, WA
  14. Feb 2, 2024 at 8:41 PM
    #74
    backpacker
    2023 TRD ORP
    Yikes! How did you acquire the extra vegetation there?
    Yotaholic[QUOTED] likes this.
  15. Feb 2, 2024 at 8:45 PM
    #75
    Yotaholic
    Olympia, WA
    I don't care after my butt surgery
  16. Feb 2, 2024 at 8:48 PM
    #76
    Yotaholic
    Olympia, WA
  17. Feb 2, 2024 at 9:00 PM
    #77
    Yotaholic
    Olympia, WA
    Trail Runnah likes this.
  18. Feb 3, 2024 at 2:18 PM
    #78
  19. Feb 4, 2024 at 10:41 AM
    #79
    Awales74
    Awales74 [OP] New Member
    My first off-road 4R adventure. All 4 wheels off the road AND dangerous cliffs. Almost forgot water with real wild life. :D Not bad for not leaving the city of Carrollton.
  20. Feb 4, 2024 at 3:33 PM
    #80
    This cracked me up! :rofl:
  21. Feb 4, 2024 at 3:48 PM
    #81
    I know I'm in the minority here, but I really liked my '03, even the way it looked. The cladding around the wheelwells held up to years of gravel roads better than any paint job would. Aside from having oodles of torque at almost any RPM, it got decent mileage, and so far has been the best vehicle I've ever owned.
    The '19 is working its way into my heart, but I really loved that '03.
    It got to a point where it needed a bunch of work, so I took the easy way out, and traded it in. It's kinda silly, but I got emotional about it when I was taking pictures of it next to the Taco. It took years of abuse and neglect, and was still a genuinely nice vehicle with almost 260K miles and 15 years on it.
    Here it was at Don Jacob's Toyota in March of 2017. I don't even miss my Supra as much as I miss that 4Runner.
    Bagman and Trail Runnah like this.
  22. Feb 18, 2024 at 9:56 AM
    #82
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    My personal favorite “beauty” angles
    MeefZah and Bagman like this.
  23. Feb 18, 2024 at 2:41 PM
    #83
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    i too can put my stock 265s over obstacles :D
  24. Feb 19, 2024 at 12:37 PM
    #84
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    LOL!! :devil:
    Gotta watch those massive obstacles!
    Pat☺
    semprenissart likes this.
  25. Feb 19, 2024 at 1:34 PM
    #85
    backpacker
    2023 TRD ORP
    Is that a leveling block? I tie myself in knots trying to guess how many leveling blocks to carry for uneven campsites.
  26. Feb 19, 2024 at 1:49 PM
    #86
    semprenissart
    semprenissart Mèfi
    Yes, sir.
    I bring the whole thing but usually I need between 1 and 4 depending on the terrain
    https://www.amazon.com/gp/product/B07ZHP8XFD?ie=UTF8&th=1
    backpacker[QUOTED] likes this.
  27. Jun 1, 2024 at 9:40 PM
    #87
    took a photo today that triggered my memory and a thread resurrection.
    :evil:
    not a terrible shot from this angle, even though the lights are a little buggy on these things. new grille mesh:
    blacked out the white inner fenders:
  28. Jun 2, 2024 at 5:19 PM
    #88
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    My druthers is a front 1/4 shot but there are lots of ways to make a good image if you put some effort in --->
    I say this in good spirits and with intent to offer advice to make people's pics better - I see a lot of images that could be great if people took two seconds to frame shit up and tidy shit up. If you are going to take a picture why not take it well? My advice for pics of vehicles is:
    Use the rule of thirds.
    Watch your lighting and watch for your shadow being cast onto the scene. Seeing the photographers shadow right in the middle of the object being photographed is a image killer.
    Take the image slightly upwards if possible, even if you just kneel down. Looking up at a thing connotes size and power. Shooting downward, even just from eye level, makes stuff seem smaller, which can be useful but not in the way most people here are wanting to capture an image.
    Frame your background and crop out distractions - like another vehicle or telephone poles. It's often easy to crop shit out if you just move slightly and place the offending thing behind your truck, or just out of frame. Move forward if there are phone lines hanging above the truck to move them up and out of frame.
    Gas station pics are retarded. Sorry to the fuckbois that like them LOL. :crapstorm:You know why? Because a fucking moped can go to a gas station. Every schlub with a 1987 Tercel goes to the gas station twice a week. The idea is to communicate adventure and remoteness and restlessness and solitude and the opposite of a convenience-store-everyone-can-do-it mentality to your viewers. Same for garage pics and pics with a condo in the background or really anything that says "developed area, people here" (edit, unless the point of the image is to explore that - in which case embrace it - but those pics trying to look remote but with a housing tract in the background...no).
    Close the doors.
    Watch what your passenger is doing if they are going to be visible in the image.
    Turn the front wheels so they are close to parallel to the camera.
    Get the entirety of the vehicle in the shot unless the point of the image is to use a portion of the vehicle's lines to point towards something else in the background.
    Watch how you cut off shadows and certain things in the background as those can make an image seem abrupt and not tied together. Keep an eye on reflections of the truck in water and don't cut those in half, include the entirety of the reflection or none of the reflection if possible.
    Shoot horizontally. We have two eyes set on a horizontal plane. Shooting vertically sends a message that something just isn't quite right with the image even if the viewer can't figure out what that is. It also allows for too much shit in the foreground "below" the subject of the picture, generally.
    Background is as important as foreground. Maybe more so.
    Frame the image prior to taking the shot or edit / crop it afterwards to minimize wasted space, e.g. acres of sky above or tons of ground in front of the truck, unless that's the point of the image.
    Action beats static.
    Fill the frame.
    Use focus to change perception and connote that the vehicle is secondary to the landscape, by putting the vehicle in the background and out of focus.
    Pick up litter that may be visible in the pic.
    And finally the 1/4 shot connotes depth that a front on or side on shot cannot.
    Examples:
    I also like rear 1/4 shots and try and frame those as if the 4R is looking at the landscape ahead of it, same other rules as above...
    And while not a 4R thing, if you have a cycle then take those images from the opposite side of the kickstand so the cycle is leaning away from the camera. It looks bigger and the side closest to the camera isn't in shadow. I generally use 1/4 front or rear for bikes as well.
  29. Jun 2, 2024 at 6:01 PM
    #89
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    All of those shots of the front where taken with a telephoto or normal fov lens.. that reinforces my thinking the 5G has an ugly front end when even slightly distorted by the lens..
  30. Jun 2, 2024 at 6:05 PM
    #90
    :rolleyes:
    well aren’t you something eh, my goodness
    I felt like I was putting effort in lol
    Many just use their cell phone dude
    MeefZah[QUOTED] and Thatbassguy like this.
