Best Angle for 4Runner Picture?
Discussion in 'General 4Runner Talk' started by Awales74, Jan 31, 2024.
  1. Jan 31, 2024 at 5:49 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Sucks when a diesel sounding motor has the keyless crap. I hate it so much I contacted the dealer senior technician to get rid of it. He said it will be like rebuilding the truck, will cost thousands and will not be like as if it came from the factory
  2. Jan 31, 2024 at 5:58 PM
    engineer90
    engineer90 New Member
    NJ
    I noticed that with iPhones, sometimes they look like they got a big head. But this pic of mine is pretty decent.
    Awales74[OP] and Yotaholic like this.
  3. Jan 31, 2024 at 6:24 PM
    Photon_Chaser 49787 and counting…
    Sierra Nevada Mountains and the Central Coast
  4. Feb 1, 2024 at 8:08 AM
    I really like the rear 3/4 angle personally. Or anything that shows the underbits.
    Thats hot
  5. Feb 1, 2024 at 8:18 AM
  6. Feb 1, 2024 at 8:34 AM
    zonzin
    zonzin New Member
    Bob
    Many
    Works for me.
  7. Feb 1, 2024 at 8:41 AM
    Steve Berman
    Steve Berman New Member
    the only angle that matters
  8. Feb 1, 2024 at 9:21 AM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    You’ll get more knee room if you remove that spoiler;)
  9. Feb 1, 2024 at 9:47 AM
    Steve Berman
    beats that shitty buick we got from yall..
    Mass4runner[QUOTED] likes this.
  10. Feb 1, 2024 at 11:00 AM
    A little father and son time out in Wyoming last summer.
    TacoGeeloor, BS67 and kolter45 like this.
  11. Feb 1, 2024 at 12:07 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
  12. Feb 1, 2024 at 1:50 PM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    I get jealous of your 4R :(
  13. Feb 1, 2024 at 2:25 PM
    wingo
    wingo *****
    2020 Venture
    photo shot pic 1.jpg To me , this is a good angle shot.
  14. Feb 1, 2024 at 2:25 PM
    Yours looks pretty kick-ass to me. I see a roof rack, bumper and winch just in your profile picture.
    Yotaholic and Ksny15[QUOTED] like this.
  15. Feb 1, 2024 at 2:45 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Mr. Rock says OUCH! Get your 295's off my head
    Yotaholic likes this.
  16. Feb 1, 2024 at 4:20 PM
    Another thing with the spoiler, if you’re camping inside, the spoiler allows you to roll down the window quite a bit for ventilation, without water getting inside if it rains. As long as it’s not raining sideways.
  17. Feb 1, 2024 at 4:59 PM
    4th is by far the ugliest gen, hideous beast.
    It started the bloated spoiler look, I blame it
    Steve Berman[QUOTED] likes this.
  18. Feb 1, 2024 at 5:06 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Yep :)
    JChiz, YetiMtnBkr, djwantke and 3 others like this.
  19. Feb 1, 2024 at 5:13 PM
    #49
    I like the front 3/4 view, especially when the light is right to show off the body lines. I think the flared fenders look really good when the light hits them.
  20. Feb 1, 2024 at 5:16 PM
    #50
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
  21. Feb 1, 2024 at 9:28 PM
    #51
    Ugh, early 5th gens can get away with a front quarter view. Classy. The current ones are too pokemon.
  22. Feb 1, 2024 at 9:40 PM
    #52
    A good buddy sent me this (he's a devout RAM kinda guy)
    MWinkTRD, Yotaholic and djwantke like this.
  23. Feb 1, 2024 at 9:44 PM
    #53
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Yours dwarfs mine lmao but thank you!
  24. Feb 2, 2024 at 10:21 AM
    #54
    We all like parking on boulders, but c’mon, this is ridiculous. What a show off.:p
  25. Feb 2, 2024 at 10:29 AM
    #55
    Awales74
    Awales74 [OP] New Member
    Thanks for all the input! I think the consensus is that it's the front corner. Anywhere from around 10 o'clock to 11 (or 1 o'clock to 2 on the passenger side). A few side on and fewer still rear corner. A lot different than my Supra where it's all about the rear end of that car. Only a picture or two upwards to make the truck look taller but not a lot.
    I'll try and come back when I get a little sun on a weekend here in Dallas. Any Dallas members know a pseudo offroadish (my truck is newer than my balls are big :) ) place I might get a photo that's a short jaunt from town?
  26. Feb 2, 2024 at 10:39 AM
    #56
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Front corner is a good call. But I also like this downhill shot
  27. Feb 2, 2024 at 11:05 AM
    #57
    Well, I kinda take it back. Sometimes a front quarter pic works on current 4runners as long as you’re not too close. And I think a little tire angle is needed to draw attention away from the insectoid eyes lol
    Regardless, OG 5th gens are still the perfect 4runner aesthetically if you as me, especially the Trails with the roof rack rails and black flares.
  28. Feb 2, 2024 at 11:09 AM
    #58
    1SilverRunner
    Tejas
    I agree with that sentiment. Pre facelift 4Rs are very slept on.
    Yotaholic and Trail Runnah like this.
  29. Feb 2, 2024 at 2:56 PM
    #59
    Thanks!
    And yeah, I think the angry catfish look is pretty awkward looking. I don't understand why Toyota insists on making all their vehicles look like angry anime characters.
  30. Feb 2, 2024 at 3:41 PM
    #60
    I don't know what everyone is talking about. Here's a picture of my 5th gen posing in some rocks. I don't think it looks like a catfish. :notsure:
