Best All Terrain Tires?
Discussion in 'Wheels & Tires' started by Diana1143, Jul 17, 2024.
  1. Jul 27, 2024 at 8:02 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I foolishly left out the Cooper Discoverer options in my recommendation :anonymous:
    Those are nice
    Wvmoonshiner and Diana1143[OP] like this.
  2. Jul 27, 2024 at 8:47 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I did a year's worth of searching reviews and got real world data to back up what i had been reading by snow plow and construction workers who use this tire. The Good Year Duratracs are by far the best all around tire, great on wet roads and awesome in the snow and a good highway ride, great off road dirt/mud too. However they will get noisy over time which will be the trade off, but that's the case with manny AT tires.
    That said, i have been super happy with them across the board. But with around 40k on them they are very noisy now and i'll probably replace them before the winter. My only other tire that i may try would be the Baja Boss A/T but they are super new and very little real world info at higher mileage. They do have a similar tread pattern as the Duratracs so i would expect them to be good, but it's going to be a tough decision to switch if i do.
    Diana1143[QUOTED][OP] likes this.
  3. Jul 27, 2024 at 9:01 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    Me too!!!!!!!!!! Good all-round! We've driven from WA St to SoCal in windy, dusty conditions (South from Bridgeport, CA then to Flag, to Vegas and reservation roads all around Gallup & Chaco Canyon Nat. Mon., N.M.) and blizzards with whiteout (From Bend, OR to Bridgeport, CA).
    Remember, there will NOT be a "best" all terrain tire. Sandy and muddy conditions require different tires from rocky conditions. Ranchers that I know use thin, aggressive tires to cut through "gumbo" on muddy roads: wide tires are better for sand like at Glamis. The Wranglers handle snow here in NC WA ST, rocky Forest Service roads; the ones I had on my pre-Taco handles rock-crawling in streams on deer & elk hunts In Utah, Wyoming, and muddy "tank tracks" @ Ft Hunter Ligget in Cali. while hunting quail and wild pigs. Once we put it in 4WD near Newport, OR and stayed in 4WD until Salt Lake City! The even handled my wife learning that, using 4WD, it works better with ALL FOUR tires on the ground! (She missed a turn in a blizzard in Rawlins, WY.
    From your location (Ohio), I would put more emphasis on handling wintry road conditions
  4. Jul 27, 2024 at 10:21 AM
    Imagine paying 60k+ and getting cheap Chinese tires. That dealer ought to be embarrassed.
    Pepper and Thatbassguy[QUOTED] like this.
  5. Jul 27, 2024 at 10:32 AM
    A friend of mine recently replaced her 2012 with a 2024 that came with the Grandtreks. She texted me the other day and asked me about them, she said "I don't know if it's just me, but these tires on here seem really bad in the wet compared to my old one. Am I crazy for wanting to replace them before winter?". I said nope, the general consensus is that these tires are garbage.
    She had some sort of Goodyear on her 2012 that her local shop had recommended. I told her to just make sure what ever she gets is 3peak rated.
    Mine came with the Dueler HTs, they were okay in rain but meh in snow.
  6. Jul 27, 2024 at 10:43 AM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    ANY tire you choose will be better than the OEM Grandtreks or Bridgestone Duelers. I lasted 2 years with the factory tires before switching them. I live in a snowy climate and could not get enough traction Shame on Toyota for putting such crap tires on the 4 runner.:mudding:
    Thatbassguy and Trail Runnah like this.
  7. Jul 27, 2024 at 10:46 AM
    X2 on these. I run the SL in stock size and they've been fantastic. Going on 65k miles with only a few rotations and they have a lot of useable tread left, they're nowhere near the wear bars.
    They're great in all weather conditions, I was especially impressed with them in winter conditions . I REALLY wish they came in 255/80/17.
    Diana1143[OP] and Thatbassguy like this.
  8. Jul 27, 2024 at 10:51 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Have you tried the newest version, the Duratrac RT ? From the pics it looks like it has a lot more siping .
    Thatbassguy and djwantke like this.
  9. Jul 27, 2024 at 11:37 AM
    DesertSurfer
    Toyo AT3 are highly touted, I don’t think the Pirelli Scorpion AT is given enough love, they’re light, quiet and 3-peak snow rated.
  10. Jul 27, 2024 at 11:51 AM
    Ripper238
    2019 TRD OR
    I saw those. They look like a good option with improved design. But they are new and little info similar to BaJa.
  11. Jul 27, 2024 at 12:17 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Atlander? Isn't that a city in Georgiar?
  12. Jul 27, 2024 at 12:22 PM
    Lol! Maybe they were specially designed for weaving in and out of traffic at 90 MPH.
    Ironguy and Trail Runnah like this.
  13. Jul 27, 2024 at 12:35 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    How’s the road noise ?
  14. Jul 27, 2024 at 12:36 PM
    They are nice looking
    They get real loud as they start to wear out
    They do not last anywhere near what you would consider a "long life" tire would last. You are going to get about 50,000 on them at best, maybe 55,000 if you drive good and rotate.
    Trail Runnah and Thatbassguy like this.
  15. Jul 27, 2024 at 1:01 PM
    Hwat the What is that?
    Those are terrible may-pops
  16. Jul 27, 2024 at 4:13 PM
    TrailSpecial22 New Member
    PA
    welcome! I can only recommend Falken WP AT3 or 4. I cannot say anything negative about them. Had them for years on my 2007, still use them on my 2011 and my 2022 has them. Great offroad and in any on road condition. Theyre quiet on the hwy, balance easy and have great tread life when you rotate every 3-5k miles. I do 90% highway and can get 50-55k on a set before theyre ready for a new set.
  17. Jul 27, 2024 at 4:18 PM
    PA
    i dumped them 100 miles after i took possession of my 2022 TSE. I nickname them “Dudlops”.
  18. Jul 27, 2024 at 6:34 PM
    :rofl:
    I also like "Dunflops" :D
  19. Jul 27, 2024 at 11:32 PM
    #49
    DR_4Runner
    DR_4Runner New Member
    Arizona High Desert
    '23 TRD Off Road- Bone stock except for KO2's....for now
    I ran the Falken WP's on my 2016 Jeep Cherokee and found they didn't perform very well in mud or muddy wet grass on a gentle incline, even in 4WD. I no longer have it, but I remember they were pretty quite on the road/hwy, and did perform somewhat decently in snow (at least on-road and on flat surfaces). I was going to replace the stock 4Runner tires with them until I remembered the mud issue we had. I'm not bagging on the Falkens at all. I think they're a great tire, I'm just in need for a more well-rounded performance from an A/T tire since I live in the high desert where we see the full gamut of weather conditions.
  20. Jul 28, 2024 at 1:51 AM
    #50
    Yotaholic
    Yotaholic New Member
    Olympia, WA
  21. Jul 28, 2024 at 1:53 AM
    #51
    Yotaholic
    Olympia, WA
    I had an appointment with Discount Tire for KO2s before I took possession of my 2023 lol
  22. Jul 28, 2024 at 1:55 AM
    #52
    Yotaholic
    Olympia, WA
    Their Baja Legend MKZ are even better
    Diana1143[OP] likes this.
  23. Jul 28, 2024 at 3:13 AM
    #53
    34 TRD OFFROAD
    34 TRD OFFROAD New Member
    2018 Red TRD OffRoad
    Rough County 2” lift ... 285/75/17 KO2
    IMG_2760.jpgI IMG_2758.jpg I have a 2018 TRD Off Road / Barcelona Red also. I went with Mickey Thompson Baja 285/70/17 with RRW rims. For looks only and run only in summer in upstate NY
    Trail Runnah and TrailSpecial22 like this.
  24. Jul 28, 2024 at 4:47 AM
    #54
    PA
    interesting to hear of your difficulties with them.
    ive had no issues in mud, wet grass or snow (10+ in pic below w/slight incline in my front yard).
  25. Jul 28, 2024 at 6:43 PM
    #55
    DR_4Runner
    Arizona High Desert
    Maybe it was the Jeep...lol:D
    TrailSpecial22 and Thatbassguy like this.
  26. Jul 28, 2024 at 6:57 PM
    #56
    DR_4Runner
    Arizona High Desert
    Originally KO2's were the plan until I discovered that they were discontinued and my local tire shop doesn't have any in stock. The KO3's don't seem to be as sturdy according to the research I've done. So I'm going back and forth between Toyo Open Country R/T Trail and Nitto Ridge Grappler :annoyed:
    BC Hunter and Thatbassguy like this.
  27. Jul 28, 2024 at 7:44 PM
    #57
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    Those Toyo AT and Nitto Grappler are good choices. I usually try stick to milder trails but in Northern NV most have lotsof rocks. If my Cooper ATs ever puncture I’ll replace them with one of those two. Most around here like E rated KO2 for less chance of puncture.
    BC Hunter and Diana1143[OP] like this.
  28. Jul 28, 2024 at 7:46 PM
    #58
    Yotaholic
    Olympia, WA
    I think I bought my ko2s in October last year. When did they discontinue it?
  29. Jul 28, 2024 at 9:18 PM
    #59
    DR_4Runner
    Arizona High Desert
    It possible that Discount Tire just stopped carrying them. That's where I was shopping for them online. Could just be the size I was looking at...?
  30. Jul 28, 2024 at 9:26 PM
    #60
    Yotaholic
    Olympia, WA
    Its available here
