Battery replacement recommendations???
Discussion in '5th Gen 4Runners (2010-2024)' started by BiggestAUfan, Dec 23, 2022.
  1. Aug 8, 2023 at 10:50 AM
    brownersd
    Sean
    Humble, Texas
  2. Aug 8, 2023 at 11:26 AM
    TCW1184
    TCW1184 New Member
    23’ 4R TRD Pro
    Seems like OEMs dont say definitively if AGMs will work for systems that originally came with a lead acid. Has Toyota weighed in on compatibility?
  3. Aug 8, 2023 at 11:43 AM
    I shared this very recently in another thread where I think I will go with regular lead-acid battery from Walmart when its time. In my case I don't thing AGMs would work for me since my 4R doesn't provide enough to charge AGM. Only at cold start I see about 13.8V of charge. In normal driving its only around 13.3V.
    Cold start -
    Normal Driving -
    Idle after a normal drive -
    Engine off -
    ** I'm not interested installing voltage boost diode as in my books 13.3v vs 14.5v after install is a huge difference.
    (Screencap from youtube. Not my pic)
  4. Aug 8, 2023 at 11:52 AM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    I have used the standard one on multiple vehicles, and have never had a problem. I did opt for the one with more CCA's than the factory battery. I live here in the desert, and they have handled the heat very well. Also, hard to beat their return policy!
    brownersd and kmeeg[QUOTED] like this.
  5. Aug 8, 2023 at 12:03 PM
    I think I would stay with regular lead-acid battery as the above post #33, until I see AGM that have stated that it can charge with 13.2v ish . Not comfortable to take risk.
  6. Aug 8, 2023 at 12:14 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I would have thought AGM are mainly used by vehicles with Stop and Start at traffic lights.
    Low voltage vehicles.
  7. Aug 8, 2023 at 12:47 PM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    It takes the Tundra battery tray, which is bigger to hold the battery. It’s essentially just a piece of plastic. I did this just to squeeze in the bigger group 27 battery.
  8. Aug 8, 2023 at 1:14 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Costco Interstate.
    2021venture likes this.
  9. Aug 8, 2023 at 4:38 PM
    UncleShorty
    UncleShorty New Member
    There are only one or two auto battery manufacturers in the US. They just put different stickers on them on the way out the door.
    I live in TX so the heat is death on batteries. I've bought the high end batts. I've bought the low end batts. They all last right at 3 years, then pffft...
    I also found the the high end warranties are so pro-rated they are essentially worthless.
    So, In my experience in a hot climate, buy the cheapest battery you can get. It' will save you money, time and aggrevation...
    Rocko9999 likes this.
