Baja Boss AT
Discussion in '5th Gen 4Runners (2010-2024)' started by AdmiralNoodle, Jun 15, 2021.
  1. May 3, 2024 at 2:12 PM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    I run 285s on stock ORP wheels (+15) and even before I switched out the OEM UCAs I didn't have any clearance issues. I only changed mine out later on because of a lift and I needed more caster.
    With the 255s being narrower than 285 I can't imagine you would have issues there. I think you would run into issues with the body mount and the fender liners first. :cheers:
    coryanderson[QUOTED] likes this.
  2. May 3, 2024 at 3:03 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Thanks for the pics. I'll need tires soon and these are my short list. Your Pro is the first that I have seen with snowflake wheels. Looks good.
  3. May 14, 2024 at 8:42 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Bought the 255 85 17s. They should arrive tomorrow. Bought some methods and new TPMSs coming Saturday.
    Also purchased JBA heavy duty UCAs, Dobinsons MRA extended travel shocks and their 352 springs.
    Hopefully have it all together either late next week or after Memorial Day weekend.
    This means a regear is on deck.
  4. May 18, 2024 at 11:46 PM
    coryanderson
    Cory
    Got the tires. Needs a BMC.
  5. May 19, 2024 at 12:00 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Sounds just like my wife
    They can be such a buzz kill!
  6. Dec 14, 2024 at 6:14 AM
    Henry J
    Sacramento Ca
    Popping up an old on, sorry
    I’ve had my 255/85 for a bit. Ow and love em. Prepping for the next year though and thinking about going to a thinner wheel to air down on some of the rough trails we have planned. I’ve got some RRW’s that are 8.5” wide. I was told on these to not go below 30, but got them late in the season and only took on dirt roads.
    question for you, what wheels are you running and how far did you air down this last year?
  7. Dec 14, 2024 at 7:52 AM
    coryanderson
    Cory
    I have the Method 703 Bead Grip wheels. I haven't aired down yet. I haven't needed too, but I aired down to around 13-15 on my stock rims a couple of times and everything I've heard from installers and people using these bead grip wheels is they are VERY impressive at doing their job.
  8. Dec 15, 2024 at 10:29 AM
    Henry J
    Sacramento Ca
    Thank you!
  9. Dec 15, 2024 at 10:37 AM
    coryanderson
    Cory
    Since this thread got bumped; I figured I would share this news too:
    I put the same exact tire (size and all) on my 2015 Chevy Dually.
    I went from KO2s on both trucks (different sizes) to Baja Bosses on both.
    I’ll be testing the winter capabilities in the truck camper in 2-3 weeks. Either SLC or Tahoe.
    TBD.
    Anyone want to go camping?
