Apex overland recovery points: review and install
Discussion in '5th Gen 4Runners (2010-2024)' started by scottalot, Mar 23, 2019.
  1. Jan 29, 2021 at 2:31 PM
    Starr
    Jonathan
    SouthEast Maui
    Very nice recovery points and great service received from APEX. I added one of the KDSS compliant model to my right front.
  2. Jan 29, 2021 at 2:51 PM
    Starr
    Jonathan
    SouthEast Maui
    Never used a soft shackle, looks like a good but expensive option to keep in the gear box. Don't think I'd want to leave it dangling around here. Something would eat it for sure.
    Decent quality 3/4" shackles have gotten inexpensive and they are rated over 20 tons. I like to keep one attached on all my trucks, and two stashed with my tow strap. In the weather it's a lot easier & cleaner to attach the strap with a shackle already on it to the one dangling from the recovery point. You can add plastic isolators on the one dangling to help kill rattles, and always add small cable tie to safety the pin, which can vibrate loose.
    A&P likes this.
  3. Jan 29, 2021 at 3:16 PM
    scottalot
    scottalot [OP] Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I didn’t jack the vehicle at all. Crawled under there and did everything by hand. Took about 30-45 minutes tops if I recall
    Havanabama[QUOTED] likes this.
  4. Jan 31, 2021 at 4:20 AM
    Havanabama
    Havanabama New Member
    2021 White TRD Pro
    Cool thanks. Question. Did you disconnect both sides of the sway bar brackets before installing the points? And how far did they lower?
  5. Feb 2, 2021 at 2:06 PM
    Havanabama
    2021 White TRD Pro
    Did you remove your skid plate?
  6. Feb 2, 2021 at 2:19 PM
    scottalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Nope
  7. Feb 2, 2021 at 3:46 PM
    Havanabama
    2021 White TRD Pro
    Anybody have the torque specs for the bolts.
  8. Feb 2, 2021 at 4:10 PM
    Havanabama
    2021 White TRD Pro
    Found them. 72, 40, 18 ft. Lbs.
  9. Feb 3, 2021 at 7:59 AM
    Havanabama
    2021 White TRD Pro
    That was easy. Thanks for the great advice.
    ESCT4R, Han4Run, diverdon and 2 others like this.
  10. Feb 3, 2021 at 8:25 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Looks good. Do want.
    Must ask: you in 'Bama?
  11. Feb 3, 2021 at 10:33 AM
    Havanabama
    2021 White TRD Pro
    I used to be a Parrot Head and Jimmy Buffet alter ego was Frank Bama. We use to have a Bama party. Get drunk and get/give Bama names. I organized a regatta to Havana Cuba from Tampa, thus Havanabama.
    koukimonster likes this.
  12. Feb 26, 2021 at 12:37 PM
    Chamby
    Chamby New Member
    2020 TRD Off Road Premium
    Nfab nerf bars, Bilstein 5100 (.85 front), 255/70/17 Wrangler UltraTerrain (Discount Tire), LR CaliRaised Molle Panel, Apex Overland front recovery points
    Mine just came today. Can’t wait to install them this weekend. Pretty cheap insurance if I ever have the need for a front recovery.
  13. Feb 26, 2021 at 1:27 PM
    NotaTRD
    NotaTRD It’s my wife’s 4R, she just lets me drive it
    CA
    2017 SW SR5
    Feel free to ask
    These recovery points have been a good alternative while saving up for a winch bumper. Thankfully haven’t gotten stuck to the point of having to use them. They aren’t compatible with the SSO bumper I ordered, so looks like I’ll have to remove mine once I receive my bumper.
  14. Feb 26, 2021 at 1:31 PM
    Chamby
    Chamby New Member
    Kinda my plan as well ...
  15. Feb 27, 2021 at 7:31 AM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    The set I ordered just arrived. I’m curious how they will work with my sway bar relocation kit.
  16. Feb 27, 2021 at 8:42 AM
  17. Feb 27, 2021 at 5:38 PM
    Chamby
    Chamby New Member
    Installed the passenger side first and it took some time. Had to move the sway bar bushing out of the way to get the hardware in place, but managed to get it all back in place. Reused the OEM sway bar bolts because I couldn’t get the replacements bolts to take vs the stock tapered bolts. Likely user error. The drivers side was a snap.
    note: I didn’t take the skid plate off, and getting to the sway bar bolts would have been much easier, especially since I couldn’t get the clearance for a torque wrench. Just gave them all I got. Did torque the 19mm bolt down to spec.
    My impression is that these will be more than adequate for a recovery.
    Crossfit4Runner likes this.
  18. Mar 2, 2021 at 4:40 AM
    diverdon
    diverdon New Member
    Don
    Florida
    21 t4r sr5 premium
    Looks great
  19. Mar 8, 2021 at 9:34 AM
    #49
    Crossfit4Runner
    Saint Louis
    To many to list
    Finally got mine installed today. Mine was made more interesting because of my sway bar relocation kit. I couldn’t use the bolts that came with the kit because the head was to big for the spacer on my relocation kit. I had read that other people just used the stock ones so I wasn’t all that fussed.
    ESCT4R likes this.
  20. Mar 12, 2021 at 7:23 AM
    #50
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Question: Could these recovery points affect approach angle?
    I'm ready to order a pair but then I was thinking, could these jam into a rock or log somehow and get stuck? If they stick out just a tiny bit, kind of like the stock hoops, then yeah I suppose it's possible however extremely unlikely. But it looks like they stick out a good bit in some pics.. and considering the way they hang, I was just wondering...
  21. Mar 12, 2021 at 1:32 PM
    #51
    Chamby
    Chamby New Member
    I don’t think it’s nearly enough to impede progress over an obstacle
    I really don’t think they will be the reason you get hung up. I love knowing I now have trustworthy recovery points. I see so many people posting their shackles on the tow hooks, and I wouldn’t trust those to a serious snatch strap recovery.
  22. Dec 8, 2021 at 9:33 PM
    #52
    J5tein
    J5tein New Member
    2021 White 4Runner TRD Off Road Premium
    None yet :)
    Recovery points came in and I love them. Seem well built and high recommendations for them. Install was smooth over all. Took alittle more time than normal. My driver side recovery point is not flush with the frame due to what seems like a weld point sticking out alittle on the frame. Anyone else have this issue? Other than that both sides seem pretty secure. I guess the true test will be if I get stuck or someone else does!?
    Trail Runnah likes this.
  23. Dec 9, 2021 at 3:00 PM
    #53
    I installed mine a few months ago. If I recall correctly, they fit pretty flush. I had to put in all the bolts loose, and tighten them in a certain sequence in order to get it to fit flush though. And while I'm sure these are pretty strong and secure, my mind has a hard time wrapping itself around the fact that all the bolt holes are larger than the actual bolts.
    J5tein[QUOTED] likes this.
  24. Dec 28, 2021 at 12:30 PM
    #54
    ToddD
    ToddD New Member
    ATL
    2021 PRO LR
    Mine did the same thing. I did not like that so I figured I would loosen and try to figure out why. It’s the smallest bolt at the top of the bracket that screws the existing metal bracket (bolt closest to front grille). The metal tubing that is connected to the bracket is preventing it from sliding all the way up. Push the bracket towards the outside of the truck and push the recovery mount up and it should sit flush. You also have to hold it in place while bolting it or it will still slide back down.
  25. Sep 23, 2022 at 1:34 PM
    #55
    j2runner
    j2runner New Member
    is loctite necessary for this installation? just got my set in the mail and am looking forward to installing! (albeit a little intimidated!)
  26. Sep 23, 2022 at 3:11 PM
    #56
    Install really isn't bad. For me, the hardest part of it was getting out the antiroll bar bracket bolts, because these bolt on under the brackets. After eight New England winters, they were in there pretty good and I was using hand tools.
    If you have the same experience, try to work them back and forth, that will loosen them a little bit. These are not a bolt you want to manhandle and snap.
    Also see some of the posts above, you have to line them up a certain way and tighten the bolts in a certain sequence in order to get it to sit flush. You might have to play around with a little bit, but you'll get it.
    As far as loctite, it definitely wouldn't hurt. I didn't do it, but that reminds me maybe I should check the bolts to make sure their still snug.
  27. Sep 23, 2022 at 4:14 PM
    #57
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    I'm curious about someone having done the KDSS install as well. I'm not sure if you need to drop the sway bar brackets but there is likely other considerations for install.
  28. Sep 23, 2022 at 4:26 PM
    #58
    ToddD
    ToddD New Member
    ATL
    2021 PRO LR
    I used silver anti seize. I wouldn’t use loctite just because but that’s just me. Wait till you get under there and start cranking the bolts with a ratchet and you will see. The threaded holes are painted so if you don’t intend on cleaning the threads first, the paint acts as a loctite somewhat. I checked mine recently while I was under there changing the fog lights and they haven’t budged. I installed around a year or so ago if I remember correctly. See my previous post about the one side sitting flush if you run into that issue. Good Luck.
  29. Sep 27, 2022 at 8:51 PM
    #59
    j2runner
    j2runner New Member
    I started the install tonight but quickly realized it would take longer than expected, so I reversed course.
    Question about the mount around the sway bar bushing - how tight should the two bolts be? Is it possible to overtighten? I don't have a torque wrench and got it pretty tight with a 6-7" ratchet. Should I be worried about over-tightening?
    I'm planning to get a digital torque wrench and reattempt when I have a larger block of time
  30. Sep 28, 2022 at 4:33 AM
    #60
    Good point, I completely forgot to mention I had to run a tap through those holes in order to get the bolts to thread in. Luckily I had it on hand from my slider install. I also used silver antiseize, I use that stuff on damn near EVERYTHING haha.
