Anything I should know about KDSS going in?
Discussion in '5th Gen 4Runners (2010-2024)' started by Taco4R, Apr 4, 2021.
  1. Apr 22, 2021 at 8:14 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I have a 2008 Land Cruiser and a 2013 TE with it.
    Hasn’t failed, but I’d probably not get it it if I had a choice.
    Both trucks are lifted.
  2. Apr 22, 2021 at 9:24 PM
    captrussia253
    captrussia253 New Member
    Ruslan
    It happened weeks after the lift. I went wheeling and flexed the suspension and noticed the 1” lean on the passenger side when I got home.
    Also, I was following a stock GX a few days ago and the rear looked leaned and it was stock. Old couple driving it so I doubt it was tampered with.
  3. Apr 22, 2021 at 11:04 PM
    LA260
    LA260 New Member
    These kdss threads are worse than the mil vs moa threads on sh
    4RunnerFlyer likes this.
  4. Apr 23, 2021 at 4:01 AM
    So, you never did anything with the valves? If there is actually a lean, I believe it can be corrected. There is a way to readjust it.
    I don't know what any of that means. :D
  5. Apr 23, 2021 at 5:41 AM
    captrussia253
    Ruslan
    I tried that and it corrected about .5” but still had a lean so I threw in some spacers.
    But I’m still happy with how it rides. If anything once it’s paid off maybe I’ll solid axle the GX and get rid of the KDSS :)
  6. Apr 23, 2021 at 6:42 AM
    RayCon
    RayCon New Member
    2016 TEP w/KDSS
    TRD skidplate and rims, Greenlane sliders, Bilstein shocks, K&N intake, Thule, Philips LED, BFG KO2s,
    KDSS is the way to go, excellent handling. STRONG SUGGESTION:remove both KDSS guards along left frame rail, drill extra holes to encourage debris drainage, spray everything with Fluid Film, put anti-seize on all 4 12mm nuts, remove and clean these areas twice a year.
    captrussia253 and Thatbassguy like this.
  7. Apr 23, 2021 at 6:55 AM
    I'm looking forward to seeing pictures of your SAS'd GX! :D
    I'm still really enjoying it as well. I hope that if it does fail, it's years down the road. Once I'm no longer daily driving it, I might be tempted to remove the sway bars and do a long travel setup anyway.
    captrussia253[QUOTED] likes this.
  8. Apr 23, 2021 at 7:18 AM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    I have KDSS and really like it. I am not into big lifts and at the limit off-roading. I am more of an overlander and love the reduction in body roll that KDSS eliminates.
  9. Apr 23, 2021 at 10:01 AM
    captrussia253
    Ruslan
    Here’s how it sits at the moment.
  10. Apr 23, 2021 at 11:01 AM
    adventure_t4r
    adventure_t4r New Member
    Cody
    1999 SR5 & 2017 TRD Off-Road Premium
    As someone who wheels often and works on their own runners, I am extremely glad I have a normal sway bar. Handles fine on the road and makes working on suspension 10x easier in my opinion.
    captrussia253 likes this.
  11. Apr 23, 2021 at 11:41 AM
    I don't really think it adds much work. Changing suspension components is pretty much the same procedure. Improved on-road handling is actually a secondary function of KDSS. Improved off camber articulation is the primary feature.
    captrussia253 and Tuco S. like this.
  12. Apr 23, 2021 at 12:39 PM
    captrussia253
    Ruslan
    I definitely think it’s easier to install suspension with a regular sway bar up front.
    adventure_t4r[QUOTED] likes this.
  13. Apr 23, 2021 at 2:43 PM
    adventure_t4r
    Cody
    Installing a lift on KDSS takes me twice as long because I can't manipulate the control arms. And when it comes to off-roading I still would rather run no sway bars at all than KDSS.
  14. Apr 23, 2021 at 4:47 PM
    So now it's only twice as hard? :boink:
    EVERYONE would prefer no sway bars at all off road.
    But, daily driving a vehicle without sway bars doesn't sound like fun to me. A 4Runner with sporty (for a brick) handling on-road and basically a partial sway bar disconnect off-road was well worth a little extra work to me. Hopefully if it ever fails it will be after I have another primary vehicle and I'll just lose the sway bars altogether.
  15. Apr 24, 2021 at 3:55 PM
    Taco4R
    Taco4R [OP] New Member
    2022 TRD ORP Classic Silver Metallic
    Thanks for the input! It's moot now as I already ordered the truck and in Canada all TRD ORs come with KDSS, it's not an option (which is a great value) and I wanted a lot of the other stuff the OR has vs the SR5 anyway.
    I am looking to keep it long term but with the resale value on these I can keep my options open. I'm trading in my 2017 Tacoma for 4Runner and I am already $6000 ahead on trade due to the value of these trucks (and my low miles).
    Now, regarding the failure of the KDSS system, worst case can't you just unbolt it and install the SR5 sway bar? $9700 seems like a ridiculous repair bill.
  16. Apr 24, 2021 at 4:01 PM
    Taco4R
    So as long as you don't lift you don't have to worry about a lean with KDSS?
  17. Apr 24, 2021 at 4:50 PM
    captrussia253
    Ruslan
    Not really sure. I was following a stock GX and it was leaning. Maybe he had some weight in the back to one side haha.
  18. Apr 24, 2021 at 9:59 PM
    You could swap in parts from an SR5 ir limited (I believe the Limited has the same sway bars) or a non-KDSS off-road. Or, run without sway bars depending on how you drive.
    There's a good chance it will never be an issue.
    That's not necessarily true. But, plenty of KDSS equipped 4runners are running around lifted without any issues. I would recommend a moderate lift, though, to be safe.
  19. Apr 24, 2021 at 10:06 PM
    #49
    Taco4R
    But I guess what I mean is stock configuration doesn't have any lean issues?
  20. Apr 24, 2021 at 10:14 PM
    #50
    None that I am aware of. It seems unlikely, as long as some care is taken to maintain the system. Any known issues I've read about were on modified vehicles or caused over time by corrosion.
  21. Apr 25, 2021 at 8:48 AM
    #51
    captrussia253
    Ruslan
    My buddy with a GX and the exact same lift as me never had a lean issue. Some have it but most don’t.
    Now if you’re telling me I can swap regular sway bars and not have the KDSS I might try that. Remove KDSS and sell it, install front sway bar and not run one in the rear for that flex :muscleflexing:
  22. Apr 25, 2021 at 8:58 AM
    #52
    I'm not 100% sure on that, but I don't see why not.
    I suppose you could sell the parts to someone who has an issue with theirs
  23. Apr 25, 2021 at 9:18 AM
    #53
    captrussia253
    Ruslan
    Ya with how expensive the system is I’d have no problem getting rid of it. Or just try out the sway bar method and if it rides worse I can throw the KDSS back in.
  24. Apr 25, 2021 at 9:49 AM
    #54
    Aside from increased body roll, ride quality should remain similar. Why do you want to get rid of it, though?
  25. Apr 25, 2021 at 11:42 AM
    #55
    captrussia253
    Ruslan
    Not going to get rid of it unless I start having issues. I just want to make sure I can swap regular sway bars and it looks like I can. I just read that a small number of GX460s came without KDSS but they’re rare.
  26. Apr 25, 2021 at 2:58 PM
    #56
    captrussia253
    Ruslan
    Heads up everyone if you have the oem rock rails and KDSS you won’t be able to remove the KDSS cover without taking out the rock rail. I ended up using a dremel and cutting a small piece off the cover bracket. I applied new paint and was able to remove the cover. Thing was covered in mud, dirt, rocks, etc. Good thing I listen and removed it to clean. I’ll be doing this every few months.
    Also, I was able to install the lights into the factory side step bracket holes haha
  27. Apr 25, 2021 at 3:10 PM
    #57
    freak4life
    freak4life New Member
    Rich
    Cañon City Co
    2018 off-road
    No shame, no one should ever give someone else grief unless they can walk on water. But that is just me saying my 2cents worth.
    4runningMan likes this.
  28. Aug 7, 2022 at 12:44 PM
    #58
    upnorth
    upnorth New Member
    Bill
    I have a 2016 with KDSS. The front ram is now leaking and the fix is $4,700. I would pass on getting it again
    kmeeg likes this.
  29. Aug 7, 2022 at 1:17 PM
    #59
    $4700 for front ram + labor or dealership replacing both front and rear as a preventive measure? Any service on the main valves when this job is done?
    Thanks in advance..
  30. Aug 7, 2022 at 1:35 PM
    #60
    upnorth
    upnorth New Member
    Bill
    That was just cost to replace front ram. There is a possible delete odd the whole system for $2,000 which I am contemplating along with new shocks. The rams are rubber and over time they Crack and leak especially in our super cold weather in Canada. Maybe longer lasting elsewhere? Hope this is helpful!
    kmeeg likes this.
