Anyone have issues with 4Runnerlifestyle.com?
Discussion in 'General 4Runner Talk' started by Ikooters, Apr 6, 2023.
  1. Mar 7, 2024 at 1:55 AM
    #91
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Just look at their YouTube content. Douchey af
    Thacrow and Han4Run like this.
  2. Mar 7, 2024 at 7:08 AM
    #92
    3JOH22A Toyota Gigolo
    Ordered the Meso dome light P/N UDLT4R-DB from 4Runner Lifestyle. Got a tracking number the day after ordering and the correct part arrived after 8 business days. I have ordered a few other things from their sister site Tacoma Lifestyle, all went smoothly. They sometimes have stock on hand of Meso parts when Meso's site doesn't.
  3. Mar 7, 2024 at 11:56 PM
    #93
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Oh what Tacoma Lifestyle exists!?
    Interesting contrasting experience opinion, good to hear. Luckily my experiences with many purchases also went just fine, and they’ve always answered my emails. But, I am, the kinda guy who would go off publicly if it did not go well for me so I feel for folks.
  4. Mar 8, 2024 at 12:03 AM
    #94
    That’s too bad, those pr*cks. Man that could happen to anyone - you start installing then realize for instance one piece is missing or whatever.
    *I just installed amber off-road led pods, some may have seen these and me posting way too much about my damn build
    but fun fact: one of the four square style lights has a clearly different array and number of leds in it, but same lens LOL. But I fully installed before noticing so fuck it
    @Thacrow probably can’t help you regarding blackout kit replacement, but I actually have a new set of rear, and front blackout kits in my garage cuz I bought a spare in case one stupid letter falls off..
  5. Mar 8, 2024 at 8:04 AM
    #95
    Trees91
    Trees91 New Member
    Forrest
    South Dakota
    2023 MGM SR5p
    I guess I'll throw in my 2 cents...
    I've never ordered anything big from them, just a black out emblem kit and interior door handle covers. They shipped within a reasonable amount of time.
    I messaged them through text about a week ago about diode dynamics interior lights and they got back to me the next morning.
    Positive experiences on my end.
  6. Mar 9, 2024 at 3:21 AM
    #96
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    SEPA
    2023 PRO
    I ordered a few things and all arrived in a reasonable amount of time. I am waiting for the meso cargo lights to come back in stock
  7. Apr 3, 2024 at 2:41 PM
    #97
    4runnerlifestyle
    4runnerlifestyle New Member
    Hello everyone, my name is Sebastian, and I'm an executive here at 4runner Lifestyle. I just wanted to hop on and express my appreciation for all of you as customers. We strive to ensure that everyone has a pleasant experience when shopping with us. That being said, after reading through this thread, I noticed that some of you have had bad experiences. Please reach out to us; we are dedicated to fixing anything!
    seakuv and kevinRR like this.
  8. Apr 5, 2024 at 11:59 AM
    #98
    TRDSD
    2019 TRD Off Road Premium
    I order from them fairly often and have never had an issue. They do sometimes get backlogged on shipping due to their frequent sales, but it's never been excessively long to get stuff. More than anything, I think many have the Amazon expectation of instant delivery as soon as you order. If you follow 4runnerlifestyle IG, you'll see them post the loads of boxes going out each day - especially after the sales. Not making excuses, but they are human, a much smaller company and don't have Jeff Bezos' automated warehouse logistics and shipping.
    4runnerlifestyle likes this.
  9. Apr 5, 2024 at 12:35 PM
    #99
    Yobruhitsme
    Denver
    Ineos Grenadier
    a reseller / drop-ship operation has zero moat.. any meaningful friction will result in lost business
    Steely123 likes this.
  10. Apr 26, 2024 at 5:23 AM
    #100
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I ordered the CaliRaised molle panels for the inside rear last Monday. The shipped on Tuesday, and according to Fedex they will be delivered tomorrow (Saturday).
    I'm a happy camper.
  11. Sep 17, 2024 at 4:07 PM
    #101
    64mech
    64mech New Member
    North Alabama
    2024 TRD PRO
    I’m torn on how I feel about them. 1st order shipped quick, no issues. 2nd order of the cali raised interior panels placed on aug 30, still hasn’t shipped, estimated sept 21-28, emailed twice no reply. 3 order placed sept 2 for upper shelf, received sept 7th. Guess I’ll wait and see what happens. …
  12. Sep 18, 2024 at 9:59 AM
    #102
    Would you like to see the weird-ass content on Toyota Japan's YouTube channel? :devil:
