Anyone have issues with 4Runnerlifestyle.com?
Discussion in 'General 4Runner Talk' started by Ikooters, Apr 6, 2023.
  1. Feb 13, 2024 at 1:08 PM
    #61
    weezol
    weezol New Member
    I'm not saying this to be a smart ass or a dick, but I don't know how a business (big or small) would be able to sell product and not be able to exchange or refund items they sold.
    If I had a store and sold you a TV, and upon getting home you found that the TV didn't work, it would be on me to either give you your money back or exchange the TV. I don't keep the money you gave me and say "sorry I'll call Sony/LG/whatever and let you know if I hear back."
    If a business can't deliver a product, they don't get to just keep the customer's money.
    Other than my last purchase from them that I wrote about in my post above, they delivered everything I ordered without issue. The shipping was slow, but that didn't bother me. They lost me when they sold me a light that didn't work, and then didn't let me exchange it or send it back for a refund.
    Han4Run and RusPro17 like this.
  2. Feb 13, 2024 at 1:16 PM
    #62
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Don’t feel bad I’m having an issue to try exchange my 3rd brake to yotaexpedition. Asking me for a video and pics installed. It’s an intermittent problem. When I connect the plug the oem snaps right in. But the aftermarket don't seem to snap in as good causing connection issue.
    weezol[QUOTED] and Han4Run like this.
  3. Feb 13, 2024 at 4:09 PM
    #63
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I've always said I've had no issues before with 4RunnerLifestyle I have a lot of their sht, I even rock one of their brand decals above my engine skid on that plastic.
    But I currently am getting f'd around in my diode dynamics order. Passed customs, arrived at facility, arrived at local post office, then said DELIVERED on multiple sources. Except it was not. No front door photo evidence, and now it's disappeared. Slowly painfully dealing with support.
    kolter45 likes this.
  4. Feb 13, 2024 at 4:11 PM
    #64
    I found my own quote.
    I take it back! Lol
  5. Feb 13, 2024 at 6:39 PM
    #65
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    Dispute it with your credit card company and let them deal with these fools. Once they get enough chargebacks it will hit them in the books and then see how they react to us consumers. Enough is enough with these bullshit companies who can't provide the product but instead give us lip service!!
  6. Feb 13, 2024 at 8:05 PM
    #66
    4RunTM
    4RunTM New Member
    TM
    CA
    22' SR5P
    PREACH IT!!!
    gomiami, Han4Run and RLTW[QUOTED] like this.
  7. Feb 14, 2024 at 4:08 AM
    #67
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    @weezol.... am not siding with the reseller.
    Based on these reviews would most certainly avoid them.
    I know multiple returns can kill an online business.
    djwantke and Han4Run like this.
  8. Feb 14, 2024 at 1:43 PM
    #68
    *UPDATE
    Lit a fire under their a*s
    Just got this email confirmation, they're re-shipping the diode dynamics order over again. God knows what happened to the first order, it said it made it all the way to my city post office lol.
    Funny though I did receive my other items in the order; first the KC Wire Hiders (came from KC direct), and last night I recieved my Rago Fabrication Ditch Light Extension Brackets!!
    Han4Run likes this.
  9. Feb 14, 2024 at 1:45 PM
    #69
    So I've never had a prob with 4RunnerLifestyle, until this latest hiccup, and hell I live up in Canada - so probably a higher likelihood for mistakes.
    They have resolved the shipping issue, so I'd say it's safe to order from them. Imho
  10. Feb 14, 2024 at 2:18 PM
    #70
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    I hope you receive your product that never arrived. They will give you all the lip service you want to hear until you go away. They will create a bogus shipping label that will sit for weeks on end without movement and say your item has shipped. Hopefully this isn't the case for you but more often than not it usually is. Many have learned from using this company and will NEVER use them again!!
    4RunTM likes this.
  11. Feb 14, 2024 at 3:06 PM
    #71
    Maybe you didn't read what I've written properly, but I've ordered hundreds of dollars worth and many orders from 4Runner lifestyle.com to Canada this is the first hiccup and within this hiccup two out of the three items on the order arrived in good time. So I don't fully agree with you
  12. Feb 14, 2024 at 3:56 PM
    #72
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    I did read it and can comprehend a simple post. If you want to support a business that screws people over on a consistent basis then go for it as it's your money. Best of luck with current and future orders as I will never support a business who runs a shady operation and gives lip service when confronted.
  13. Feb 14, 2024 at 4:05 PM
    #73
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    So I ordered my Sherpa from them. I probably won't ever use them again. I verified the rack was in stock prior to ordering which it was. I placed my order and 4 business days went by. I sent an email asking when my order was shipping and got the usual BS of they have to many orders blah blah blah. I was told it would ship out next day. 2 more days went by and I inquired again. They gave me the same bs and said they would get it out as soon as possible. I asked to please cancel my order and magically my rack shipped later that day.
    They just seem to not have any sense of urgency. Super nice folks but business sucks
    RLTW likes this.
  14. Feb 14, 2024 at 4:20 PM
    #74
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Honestly, I’ve had no problems with them because I ordered knowing they’re just the middle man & I’ve worked in mail order & its fucking nutz. I always recommend ordering locally - GL!! :thumbsup:
    3JOH22A and djwantke like this.
  15. Feb 14, 2024 at 4:51 PM
    #75
    No ya this is the first I'm hearing of that, but 100% I believe it. It sounds like I'm a good case, and one of the lucky ppl. I hear ya
  16. Feb 15, 2024 at 2:22 AM
    #76
    weezol
    weezol New Member
    I didn't mean to imply that you were siding with them; my post sounded a lot more pissy than I actually am, so my apologies if it came off that way.
    I was just trying to state that regardless if you're a small or big business, you have to still meet you're end of every deal. I'm all for helping small businesses to the point where I'll even pay a little higher price, but I still expect to get what I ordered.
    And yeah I agree that too many returns can be bad for an online business.
  17. Feb 15, 2024 at 2:27 AM
    #77
    weezol
    weezol New Member
    I got my new lights from the manufacture yesterday. So from my first email to the manufacture to me getting a replacement was 5 days (including a weekend in those 5). I still have not heard back from 4runnerlifestyle since they told me they followed up with the manufacture, and I contacted them a week before I just emailed the light company myself.
    djwantke[QUOTED], RLTW and Han4Run like this.
  18. Feb 21, 2024 at 1:29 PM
    #78
    majorpain
    majorpain New Member
    23ORP
    They use your money to make money
    Drop Shipping
    Never will use them again
    raimieb and djwantke like this.
  19. Feb 21, 2024 at 2:18 PM
    #79
    kolter45 and raimieb like this.
  20. Feb 21, 2024 at 3:01 PM
    #80
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Why not just buy directly from the manufacturer? Super easy and direct shipping.
  21. Feb 21, 2024 at 3:15 PM
    #81
    living up in Canada doesn't help me on that matter
    suppose I could order direct as well in theory I'm still paying duties either way
  22. Feb 21, 2024 at 3:22 PM
    #82
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Yeah. I’m sorry about that friend. That is a bummer. Dobs billet is great for corrosion resistance.
  23. Feb 21, 2024 at 4:04 PM
    #83
    Thanks bud, unfortunate country to live in indeed (I am a dual USA citizen tho). One of the top 5 worst parts of living in Canada is McDonald's stopped carrying honey mustard years ago. Truly unbelievable, and deeply angers me...who keeps hot mustard and sh*tty BBQ sauce stocked, but drops honey mustard
    McSpazatron and kolter45 like this.
  24. Feb 21, 2024 at 8:46 PM
    #84
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I bought Dr. KDSS and RCI skid plates directly and got it within a week. Order direct, cut the middle man.
  25. Feb 21, 2024 at 8:54 PM
    #85
    Good call, yeah buddy
    Be careful ordering multiple DR. KDSS products to Canada, Dom and I worked out a shipper selection method to bring down exorbitant duties - man’s a good dude
    raimieb and Yotaholic[QUOTED] like this.
  26. Mar 6, 2024 at 3:33 PM
    #86
    Ratmosphere
    Ratmosphere New Member
    Is it common for these guys just to not answer for days? They sent me a different part than I ordered and I want a refund lol.
  27. Mar 6, 2024 at 8:08 PM
    #87
    CO4Runner
    CO4Runner New Member
    2023 4Runner TRD ORP
    I ordered a few things when I first picked up my ‘23 ORP last summer. Luckily, despite me being a noob, the items I ordered were all delivered in a timely fashion. Some were big ticket items like a Prinsu rack and a pair of Baja Squadrons to replace my fog lights and Sports for ditch lights. Bought a few smaller things in the weeks after that and never had any issue. In late October, I ordered Cali Raised Molle side panels and top shelf. Their website claimed it was in stock, so I assumed should be no more than 10 days before they arrive. Well, after many emails, I finally received the Molle Panels in early February. During that time, I ordered some smaller items and had issues. Meso Customs interior door handles, one came cracked. Had to wait about 3 weeks for Meso to send them directly to me. Another order was for climate and radio knobs overlays to black out the controls. Box came with one item missing. I had to explain multiple times, send photos, and literally chase them down. I remember emailing that I have spent thousands of dollars with their company, why would I try to beat them out of $40 for replace my climate control knobs. One positive came from all of this though. While waiting 3+ months for the Molle Panels, I did a mock order on Cali Raised website and they claimed they were in stock and can be delivered inside a week or so. They were also charging about $60 less than 4Runner Lifestyle. I contacted 4R Lifestyle and they matched and gave me a credit. I used that tonight and will probably never return back. And for the record, items can be found cheaper elsewhere. They charge $500+ for Max Trax MKII for a set. I found them on multiple sites for $300. I picked up 4 boards almost for what they charge for a pair.
  28. Mar 6, 2024 at 10:19 PM
    #88
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    that happened to me. kinda twice. Once i got my money back the other time they never replied, never got my money back.
  29. Mar 6, 2024 at 11:05 PM
    #89
    You just gave up eh? Sorry to hear they did that tho
    What's really great is (as I predicted, and has happened to me many a time with purchases), they lost my order for some diode dynamics and sent another but now the first original shipment is out for delivery haha
    Free dome light and rear cargo light :hattip:
  30. Mar 7, 2024 at 1:07 AM
    #90
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah gave up. it was a black out kit for the rear hatch. One of the letters was wrong. I emailed them. heard nothing back. said fuck it I'll get a black out kit from somewhere else and never did. Reminds me, i need to find a black out kit for the hatch....
    I couldnt return it because most of the letters were on/used. Had to use a heat gun to get them off
    djwantke[QUOTED] likes this.
