Any fog light recommendations for someone running H9 headlights?
Discussion in '5th Gen 4Runners (2010-2024)' started by nimby, Sep 24, 2021.
  1. Sep 29, 2021 at 7:56 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    If i hadn't already made my own, I'd consider the bars Diode made. Bolt-on and go. I didn't need to cut the grill, just did it for fun.
  2. Oct 18, 2021 at 12:45 PM
    nimby [OP] in the drink
    Just an update for anyone interested. I live up a narrow windy road with no street lamps. There's quite a bit of wildlife and was looking to get a little more performance out of my fog lights.
    I decided to try my luck with replacing the stock H16's with some H8's (halogen). $17 for the pair.
    https://smile.amazon.com/dp/B00BUIDTBI?ref=ppx_yo2_dt_b_product_details
    The H16's are 19W and the H8's are 35W. It was a very similar operation to replacing your stock low beam H11's with H9's, but easier. You just have to trim a little bit of one of the metal tabs on the H8's. The connection to the wire loom needs no modification.
    I've heard of some people replacing the H16's with H11's, but that's a jump from 19W to 55W and I wasn't comfortable with that. There was one report of someone melting their fog light housing with the H11's.......but that was hearsay. Who knows.
    I don't have any reports on how they perform just yet, but I will update once I try them out at night.
    If they don't work out or melt my fog light housing, I'll just upgrade to some LED's.
  3. Oct 24, 2021 at 11:08 AM
    H8 Halogen Fog Light update:
    I'm stoked on how these work! No heat concerns whatsoever.
    Definitely an improvement from the H16's. Not sure why you don't hear about this upgrade more often. When combined with the H9 low beams, you get much improved light output when compared to stock.
  4. Jan 13, 2024 at 4:06 PM
    RDJ
    RDJ New Member
    2016 4Runner SR5 4WD Silver
    H9 and 9011 Headlight conversions
    Sorry to resurrect this old thread, but I'm very interested in upgrading my stock fog lights with a better performing halogen bulb. I had thought of trying the Yellow H11's, but like you, I was concerned with too much current and heat. Do you still like these H8's? I'm surprised this is the first I've seen of this swap. Do you know if there are any options for Yellow H8 bulbs?
  5. Jan 14, 2024 at 8:16 AM
    The H8's have been fantastic. I use them all the time and they do a great job filling in the dark spots on windy mountain roads.
    I have not seen any yellow versions of the H8's.
    The only possibility I can think of is get the regular H8's and maybe do something like a yellow Lamin-x film over the stock fog light housing.
    RDJ likes this.
  6. Jan 15, 2024 at 10:31 AM
    RDJ
    RDJ New Member
    Great news! Thanks for the reply on this. I’ve been doing some research, and I’ve found the standard Philips H8 bulbs (which would match my upgraded bulbs - at <$7 a piece!).
    I’ve also found some yellow bulbs that have good ratings from other sites. Two bulbs together for $19.95. I’ll post the link below.
    Thanks again for posting this - you saved me some hassle, as I was looking for something similar, but was afraid the H11’s would overheat (being 55watt in a 19 watt system).
    Here’s the yellow bulbs. I think I’ll get a set, try them, and report back. Could have used them with all the recent snow!
    I’m just pasting my notes:
    Fog lights:
    nimby[OP] likes this.
  7. Jan 15, 2024 at 10:35 AM
    Awesome!
    Yes, please let me know what you think of the yellow bulbs.
  8. Jan 15, 2024 at 3:49 PM
    RDJ
    RDJ New Member
    Will do. Placed the order today, but it will be end of next week before I get a chance to install them.
  9. Jan 27, 2024 at 3:03 PM
    RDJ
    RDJ New Member
    Ok! I installed the JDM Nokia H8 2500 Hyper Yellows just a few minutes ago. Not as straightforward as I had thought; had to trim both the bottom tabs (at the 4 and 6 o’clock positions) on both sides of the tabs.
    The passenger side fog light has a wierd panel over the fog light, making it hard to access, but eventually got them in.
    They are brighter than stock (should be with double the wattage). They are also a nice yellow. Even in daylight, the difference is obvious. I will post back after driving at night with them.
    Passenger stock; Driver Nokia hyper yellow
    Both sides Nokia Hyper Yellow H8s
    Not bad for $15 for both!
    djwantke and nimby[OP] like this.
  10. Jan 27, 2024 at 5:26 PM
    RDJ
    RDJ New Member
    Here’s a picture at night. As always, the pictures don’t do the actual justice. They are a much deeper yellow in person.
    I’m thinking of doing my low beams, and maybe even high beams, in these yellows. So much easier on my eyes at night.
    djwantke likes this.
  11. Jan 27, 2024 at 5:42 PM
    Glad you got them to work. Yeah, a remember getting to one of them was a little tricky but I don't remember having to trim 2 different tabs like you. Nevertheless, you figured it out and they look great!
    djwantke and RDJ[QUOTED] like this.
  12. Jan 27, 2024 at 5:51 PM
    RDJ
    RDJ New Member
    you get all the credit for this with the tip on the H8s. They are so much brighter than the stock H16s. I would be worried about putting 55 watt H11s in the fog light position.
    djwantke and nimby[QUOTED][OP] like this.
  13. Jan 27, 2024 at 5:54 PM
    Thank you kind sir :hattip:
    RDJ[QUOTED] likes this.
  14. Jan 27, 2024 at 8:01 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey boys
    I like that deep yellow, much deeper than lamin-x.
    This is a helpful thread I gotta hit Watch.
    I crossed this bridge upgrading fogs two yrs ago. Got off Amazon as well. I bought two pair in case one craps out, but first one still going strong.
    I wanted cheaper Chinese lights because I wanted trippy tri-color. 24w ea, not bad
    https://www.amazon.ca/gp/aw/d/B08GRZ6NJJ?ref=ppx_pop_mob_b_asin_title
