Any 2023 TRD Pro owners running Eibach lift springs?
Discussion in '5th Gen 4Runners (2010-2024)' started by UATahoe, Jan 2, 2024.
  1. Jul 19, 2024 at 9:56 AM
    #181
    brodeyo
    brodeyo New Member
    I’ll also add, if you go Offroad… was happy with performance. Seem to have good artulation. Absolutely no issues. I was on a stretchy part of Mineral Creek that was quite off camber.. made it though just fine. A jeep rolled there this past week.
    RiverDog likes this.
  2. Jul 19, 2024 at 10:16 AM
    #182
    UATahoe
    UATahoe [OP] New Member
    Joseph
    Huntsville, AL
    2024 TRD Pro
    really appreciate the feedback! My plan would be to go with 285 Toyo SL load tires. They are extremely lite for a 285. Only 46-47 pounds. Believe that should help with the ride as well. I am going to give the Westcott lift a shot I think. See how it goes. Other cars are corvettes and a Camaro so I am thinking the stiffer ride probably won’t be so bad for me. Hopefully. Lol
    RusPro17 and brodeyo[QUOTED] like this.
  3. Jul 19, 2024 at 10:18 AM
    #183
    brodeyo
    brodeyo New Member
    As long as you never cut , you can always go back;) my ride is still way nicer than our gx460 stock with kdss
  4. Jul 19, 2024 at 10:27 AM
    #184
    brodeyo
    brodeyo New Member
    I have toyo at3. No complaints.
    RusPro17 likes this.
  5. Jul 19, 2024 at 1:22 PM
    #185
    RiverDog
    RiverDog New Member
    I just got home from riding in a 2024 TRD Pro with the Westcott lift and Toyo AT3 in 285 SL. This is what I am going to install in 2 weeks. I was very impressed with the ride for the money. I feel it firmed it up just a little and helped a little with the dive, but did not change the overall feel too much. I was able to also put about 250# in the back and it did not drop that much and that was a concern I had. I figure if I decide it is not for me, I can all pull the Westcott lift. I was going back and forth on different spring combos, as I don't want nose high or squat in the rear and I don't want too stiff of a ride. I just have not found any locals running different spring combos with the Fox Suspension.
    I did ride in another 4Runner with the Westcott Lift but the tires were E rated. I did not like the ride as it was too stiff.
    For those of you running the Toyo AT3 285 SL, what pressures are you running on the street? My hope is I can air down to 17 off road, but I am using the factory TRD Pro wheels.
  6. Jul 19, 2024 at 2:55 PM
    #186
    like2lean
    like2lean New Member
    Love Mineral Creek, headed up there in a couple weeks. What kind of awning is that, you like it?
  7. Jul 19, 2024 at 3:09 PM
    #187
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Curious, what load range are your tires? From all I have read, that seems to make a huge difference in ride firmness.
  8. Jul 19, 2024 at 3:15 PM
    #188
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Mickeythompsons Baja boss SL. Only 4lbs heavier than the 265’s. They ride really good and no road noise. I had the 265’s and sold them to my friend to get my 285’s.
  9. Jul 19, 2024 at 3:21 PM
    #189
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Nice. Not bad at all. Keeping the weight down on the tires hopefully helps keep the truck from losing a lot of its power. I may look in to those as well.
  10. Jul 19, 2024 at 3:29 PM
    #190
    RusPro17
    Don
    Pa.
    Thanks! I definitely did not feel any power loss with my 285’s. I loved them my 265’s in the snow got to test them out. So I figured the 285’s will do just fine. Better than the Nitto ridge grapplers.
  11. Jul 19, 2024 at 3:50 PM
    #191
    RiverDog
    RiverDog New Member
    @RusPro17 What tint do you go with on the front sides? Did you also tint the back? Looks very nice.
  12. Jul 19, 2024 at 4:07 PM
    #192
    RusPro17
    Don
    Pa.
    Thank you! Only did the front doors which I think is 35% to match the factory. It’s pretty close matching the rear doors and back window.
  13. Jul 19, 2024 at 4:32 PM
    #193
    RiverDog
    RiverDog New Member
    Thank you.
    RusPro17[QUOTED] likes this.
  14. Jul 21, 2024 at 5:31 AM
    #194
    brodeyo
    brodeyo New Member
    It’s an ARB. It seems most of brands are very similar for this style . I like their customer service so I try to go with them as much as I can.
  15. Jul 23, 2024 at 1:11 PM
    #195
    CoastPro4
    CoastPro4 New Member
    21 Pro LR
    I will be definitely will be keeping an eye on this thread as this is the path moving forward for my Pro…well, I think it was at least lol. I’m on the fence now as the more I research the more I feel like I do not want to mess with the original geometry and nature of the “position sensitive” design of our Internal Bypass Fox shocks. I really do love the oem valving and spring rate as I feel it’s very responsive and compliant at running moderate trails at some speed. Ugh…not sure what I’m gonna settle on.
  16. Jul 23, 2024 at 3:40 PM
    #196
    Krup235
    Krup235 New Member
    UPDATE:
    After a while and still seeing a very slight reverse rake I went ahead and got the 2” icon rear springs. All is right with the world!
  17. Jul 23, 2024 at 5:00 PM
    #197
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Pros sit pretty level, since they are raised 1" in the front over standard 4runner. So that makes sense 2" in the rear to match the 2" front lift. But with 2" of lift. Extended brake lines and bump stops might be necessary.
  18. Jul 23, 2024 at 5:24 PM
    #198
    CoastPro4
    21 Pro LR
    This is what I’ve gathered as well and have been reading up on…essentially 2”-3” rear lift falls in the range of requiring a pan-hard correction kit to keep your rear solid axle cycling correctly…as well as extended bumps and break lines. Lots of things to consider if done correctly. Love to see what everyone decides to do.
  19. Jul 23, 2024 at 5:34 PM
    #199
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    The Pro’s actually still have a good bit of rake on them actually. Believe mine still has right an inch of rake even with the front lift.
    CoastPro4 likes this.
  20. Jul 23, 2024 at 5:35 PM
    #200
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    How is the ride with that setup? Compared to the original factory ride. Anything additional needed? Post up some pictures when you get the chance! Would love to see how it turned out.
  21. Jul 25, 2024 at 10:22 AM
    #201
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Those of you already lifted, was it absolutely necessary to remove the front mudflsps?
  22. Jul 25, 2024 at 10:55 AM
    #202
    RusPro17
    Don
    Pa.
    I removed mine with the westcott lift. I have a new set of Rockbloz to add did not put them on yet. Was in talking it over with my mechanic Joseph thinking I’m adding the Eibach 21-22 springs. He does not think I should do the 23-24 springs. He knows how anal I’am LOL.
  23. Jul 25, 2024 at 11:00 AM
    #203
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    It’s strange to see that some run the Westcott but still keep the front mudflaps. And then some remove. Westcott says you have no choice. They would get ripped off at full lock. I am guessing with the Eibach it would still be the same problem?
  24. Jul 25, 2024 at 11:04 AM
    #204
    RusPro17
    Don
    Pa.
    This is why most stay with the Pro wheel because it’s only 7 inches and cause of the off set and why westcott says 285’s will clear. I spoke to one of the techs there and he said when you run the SCS wheels which are -10 off set and 8.5 inch wheel it’s a hit or Miss with rubbing. Yes you get a better aggressive look with the stance but more chance of tire rub. So for my situation is more difficult then just staying with the Pro wheel. But I feel after having the Eibach springs on my 20 Pro and SCS wheels my tires will clear and not rub and also ran 285’s.
  25. Jul 25, 2024 at 11:08 AM
    #205
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    So I specifically asked Westcott about rubbing on the mudflaps with a 24 Pro and staying with the Pro wheels. Said it didn’t matter. Front flaps would have to come off. Who knows. Maybe they would clear fine. I think I may be back towards leaning eibach front with icon springs in the rear. 285 Toyo AT3’s
  26. Jul 25, 2024 at 3:19 PM
    #206
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    What's your wheel offset?
    Are front mudflaps necessary? Look a couple post ahead. I posted pictures of mine with flaps.
  27. Jul 25, 2024 at 4:35 PM
    #207
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    I honestly just like the look with the flaps on. I would be keeping my stock TRD Pro rims. It’s strange because it’s almost a 50/50 split on those rims and the Westcott lift. Lol. Half keep the front flaps and half don’t. Was just surprised when Westcott themselves said they absolutely have to come off. After seeing some videos online I honestly don’t even think I would miss them if they had to go. Will probably pull the trigger and then just live with the outcome.
  28. Jul 26, 2024 at 6:33 AM
    #208
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    It's hit or miss really. You might be able to keep them, you may just have to trim them.
  29. Jul 26, 2024 at 1:19 PM
    #209
    brodeyo
    brodeyo New Member
    Depends on wheels. You don’t need to remove if you keep the trd pro wheels. I have lots of space.
  30. Aug 5, 2024 at 4:59 PM
    #210
    Nukemaster
    Nukemaster New Member
    Steve
    2024 4Runner TRD Pro
    Update: After adding Apex recovery points, the front dropped a bit more than I liked with the 21-22 Eibach Pro springs on my 24'. Installed the 23-24 springs and the ride is nice and firm. Measurements now from center of wheel to wheel well lip is 23" front; 23 5/8" rear.
