Any 2023 TRD Pro owners running Eibach lift springs?
Discussion in '5th Gen 4Runners (2010-2024)' started by UATahoe, Jan 2, 2024.
  1. Apr 19, 2024 at 6:10 PM
    #61
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    The new WD 2" front lift and 2" Icon springs in the back may do the trick
  2. Apr 19, 2024 at 6:10 PM
    #62
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    This is Eibachs test vehicle with the 23 springs. Looks nose high compare to my SO. upload_2024-4-19_21-10-26.jpg
    bigpharma9 likes this.
  3. Apr 19, 2024 at 6:12 PM
    #63
    michow87
    michow87 New Member
    Any weight in the back and it's going to be squatting. I wish they kept the previous measurements.
  4. Apr 19, 2024 at 8:41 PM
    #64
    UATahoe
    UATahoe [OP] New Member
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Yeah that’s borderline nose high already. Anything whatsoever in the back and it definitely will. This change makes absolutely no sense to me. They should have kept the original lift height or at least make it an option.
  5. Apr 20, 2024 at 3:58 AM
    #65
    RusPro17
    Don
    Pa.
    Pictures don’t lie. I have to agree makes no sense.
  6. Apr 20, 2024 at 6:52 AM
    #66
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    This had to be designed for those who will be adding weight to the front. That’s what Westcott did with their new higher lift up front. Disappointing for sure. I guess I will give the Westcott lift some more thought. Still shocked Eibach is telling people no other mods are needed to run that much lift up front.
  7. Apr 20, 2024 at 7:14 PM
    #67
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Average weight in the back shouldn't squat the rear. Eibach springs have a higher spring rate then stock.
  8. Apr 25, 2024 at 6:31 PM
    #68
    like2lean
    like2lean New Member
    Can anyone who installs the new spring kit please post your lift spec from the center of hubs to the fender for reference?
  9. Apr 26, 2024 at 6:57 AM
    #69
    RusPro17
    Don
    Pa.
    I’m surprised no one has posted yet with the new springs. When I spoke with Eibach of 2 weeks ago the guy told me they sold 6 sets so far and there were about 30 sets in stock from the first batch. Seen no one yet on Facebook post yet either.
  10. Apr 26, 2024 at 7:47 AM
    #70
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    I hope they realize they went too aggressive up front and come out with a revision to bring that front down some. Wishful hoping.
    RusPro17 likes this.
  11. Apr 27, 2024 at 6:17 AM
    #71
    HighSierraGuy
    HighSierraGuy New Member
    Stock tire size?
  12. Apr 28, 2024 at 5:44 PM
    #72
    michow87
    michow87 New Member
    agreed 100%, which is why their change in lift kit between the 2021-2022 and 2023-2024 makes no sense to me. I believe a little rake is good.
    RusPro17 and brodeyo like this.
  13. Apr 29, 2024 at 9:17 PM
    #73
    hmb-mike
    hmb-mike New Member
    Bummed to hear this, as I just picked up a 24 pro and was told the Eibach springs would be the way to go. Now I’m leaning Westcott.
    Just getting up to speed on all this, but the posts have been a big help. Any thoughts / recommendation for a basic entry road setup?
    I’m thinking WD 2” front kit, Dobinsons rear 1.75 - 2” coil springs (C59-505), Dobinsons billet UCAs and 285 K02s. Hoping for a good ride for a dd and a level stance able to clear the 285s w no bmc. Appreciate any advice or input!
  14. Apr 30, 2024 at 8:45 AM
    #74
    like2lean
    1rst gen Pro spring set with a small 3/8 top spacer, it's smaller than the 1/2 spacer Westcott uses.
    hmb-mike likes this.
  15. Apr 30, 2024 at 12:02 PM
    #75
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks good, Stock uca?
  16. Apr 30, 2024 at 2:17 PM
    #76
    like2lean
    Yup, and drives perfect with 2 deg caster, no wander at all. I was of the thinking I can always add them if it does drive any worse or wander. Why not try it and see, ya might save a pile of cash otherwise spent for nothing! I can tell NO difference in the way it drives on or off the highway, and as someone who's done hundreds of alignments, I would know.
  17. May 1, 2024 at 10:52 AM
    #77
    hmb-mike
    hmb-mike New Member
    I’ll keep you posted as I’m expecting to head down this path.
    Anyone have any feedback on the dobinsons springs / UCAs?
    Ive read good things on other posts but not necessarily matched w WD 2.0
    brodeyo likes this.
  18. May 1, 2024 at 10:53 AM
    #78
    hmb-mike
    hmb-mike New Member
    Looks good!!
  19. May 1, 2024 at 5:39 PM
    #79
    michow87
    michow87 New Member
    heard good things about Dobinsons in regards to reliability and not requiring as much maintenance because it's an OE style sealed ball joint.
  20. May 3, 2024 at 10:43 PM
    #80
    hmb-mike
    hmb-mike New Member
    michow87 and brodeyo like this.
  21. May 4, 2024 at 4:19 AM
    #81
    michow87
    michow87 New Member
    He also put 275/70r17. he could fit 285/70r17 easily in there.
    brodeyo likes this.
  22. May 4, 2024 at 6:16 AM
    #82
    RusPro17
    Don
    Pa.
    These new Eibach springs have been out long enough. But no one is posting yet with the both front and rears springs. Not even seeing any on Facebook. The pic I posted from Eibach is definitely too high in the front compared to my westcott.
    brodeyo likes this.
  23. May 4, 2024 at 6:24 AM
    #83
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Yeah it’s just too high in the front for me. I don’t need that much lift and it just looks off to me honestly. I also bet he ends up having alignment issues and drive issues until he gives in and gets UCAs.
    brodeyo and RusPro17 like this.
  24. May 8, 2024 at 5:22 AM
    #84
    Krup235
    Krup235 New Member
    Here you go, installed yesterday at Apex Overland. On the alignment rack the vehicle set perfectly level. I did change UCAs like all of you, didn’t see by it being smart to not. Stock tires so looks like missed leg day a lot. First/before next set after. IMG_1762.jpg IMG_1764.jpg IMG_1763.jpg IMG_1767.jpg IMG_1769.jpg IMG_1768.jpg
  25. May 8, 2024 at 5:35 AM
    #85
    michow87
    michow87 New Member
    Thanks for the pics. Maybe it’s me, but the front looks a little too high relative to the back. The back would benefit from another 1” of lift IMO
  26. May 8, 2024 at 5:57 AM
    #86
    Krup235
    Krup235 New Member
    Have not done measurements will post when I have.
  27. May 8, 2024 at 5:57 AM
    #87
    like2lean
    Yeah I agree, about 1/2" less in the front, it may settle a bit though, mine did. Hub measurements please.
  28. May 8, 2024 at 6:02 AM
    #88
    Krup235
    Krup235 New Member
    There are 100 factors that affect the pics. When I first saw it thought same thing. I drove the chase car 90 miles home and can tell you from an enthusiast and OCD patient, I liked the way it looked in the wild. Someone has to be the first to put new things on or how else will we judge. I am not one to say it’s great just because I spent money. There will also be settling. I do need to load it up and see if I get a reverse rake. If it happens full lift goes in. For $500 I was willing to take a chance. Not disappointed!
  29. May 8, 2024 at 6:04 AM
    #89
    michow87
    michow87 New Member
    I think that worst case, you can replace your rear springs. Per the website, it’s a total 3.5” front and 1” rear vs a stock non-TRDpro model.
    I’ve been considering doing the front eibach springs w/ 2” icon rears.
    how does the new ride feel?
    brodeyo likes this.
  30. May 8, 2024 at 6:07 AM
    #90
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Definitely appreciate the pictures and honest feedback. I think it confirms a couple things for me. It’s not the lift style for me personally because I like to have some rake to my vehicles and UCAs definitely are needed. Very confusing why Eibach would actively pitch this as not needing them.
    brodeyo likes this.
