Any 2023 TRD Pro owners running Eibach lift springs?
Discussion in '5th Gen 4Runners (2010-2024)' started by UATahoe, Jan 2, 2024.
  1. Apr 4, 2024 at 8:57 AM
    Shilo5000
    Shilo5000 New Member
    Lucas
    OC
    ‘22 TRD PRO
    Well, like my wife always says, I’m often wrong but never in doubt! That does seem aggressive… maybe they don’t want to compete with WD for the moderate lift/leveling. Most of the posts on here with either of them are very satisfied customers.
  2. Apr 4, 2024 at 9:04 AM
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    WD came out with another lift that gives a 2" front lift over the stock 1" TRD pro lift for a true 3" total front. They recommend 2" springs in the back. Eibach essentially gives a total 3.5" front and 1.0" rear. I'd rather not have my 4Runner squat. Wish the 21-22 year springs worked with my 24
    Shilo5000 likes this.
  3. Apr 4, 2024 at 10:22 AM
    michow87
    michow87 New Member
    Is this with the standard WD lift? Or their 2" in the front lift? Looks awesome, btw
  4. Apr 8, 2024 at 2:36 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Anyone need a brand new front set of 2021-2023 trd pro eibach springs. I Bought a set but I have 2019/2020 style struts. $100+shipping
  5. Apr 8, 2024 at 2:41 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    E30-82-069-03-20
  6. Apr 9, 2024 at 5:23 AM
    Krup235
    Krup235 New Member
    Just ordered the new kit for Pro will have them on beginning of May because of vacation. Will give you pics then. Apex Overland is doing the install, they have done my taco and FJ. Highly recommended for those in NC.
    brodeyo likes this.
  7. Apr 9, 2024 at 5:41 AM
    Krup235
    Krup235 New Member
    Yes the new 2.5/1.0. Will let you know!
    brodeyo likes this.
  8. Apr 9, 2024 at 7:25 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Seen a pic on Facebook looks good. I’m surprised. Had the Eibach on my 20 Pro. Have the westcott now on my 23 Pro.
  9. Apr 9, 2024 at 8:01 AM
    UATahoe
    UATahoe [OP] New Member
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Got a link to the picture? Would like to see it myself. Everyone I have talked to says that upper control arms will be a must with that kit now.
  10. Apr 9, 2024 at 9:43 AM
    RusPro17
    Don
    Pa.
    Let me see if I can copy the post and put it on. I don’t think he changed the UCA’s and the caster specs were not too bad. He did remove the mudflaps.
  11. Apr 9, 2024 at 9:47 AM
    RusPro17
    Don
    Pa.
    upload_2024-4-9_12-47-7.pngHe said mudflaps and some trimmings in the front. He also said stock UCA’s aligned pretty good.
  12. Apr 9, 2024 at 9:47 AM
    RusPro17
    Don
    Pa.
  13. Apr 9, 2024 at 9:52 AM
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    At this point I think I am just going to roll with it stick and move forward with getting supercharger installed. The ride is great to me right now and I don’t want to chance makimg it worse.
  14. Apr 9, 2024 at 10:01 AM
    RusPro17
    Don
    Pa.
    The way my 23 Pro is riding and handling with my 285’s I’m staying with my westcott lift.
  15. Apr 9, 2024 at 10:02 AM
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    So you guys are happy with the WD lift? The installer I am using said their kit is good but you definitely notice a more stiff ride after.
    RusPro17 likes this.
  16. Apr 9, 2024 at 10:12 AM
    RusPro17
    Don
    Pa.
    The stiffer ride if you call it makes it better. I like it takes away that nose dive and I can drive it harder in the back road and feels tight.
    brodeyo likes this.
  17. Apr 9, 2024 at 10:15 AM
    RusPro17
    Don
    Pa.
    I have not loaded it a lot. Except for going on a trip with luggage. Also did tow a trailer with both mowers on to take and have service. And with the trailer on I had no sag at all. Still sat the same way.
    michow87 and brodeyo like this.
  18. Apr 9, 2024 at 10:23 AM
    RusPro17
    Don
    Pa.
    Yeah that’s a tough call. You should reach out to westcott designs and tell them what you have and see what they say. They have done so many installs with this lift.
  19. Apr 9, 2024 at 10:33 AM
    #49
    RusPro17
    Don
    Pa.
    I have Tyger side steps which are still heavy. That’s about it. I should have taken a pic when the trailer was hooked up so you could see it. But that won’t be happening until mower needs to be serviced again.
  20. Apr 9, 2024 at 10:41 AM
    #50
    RusPro17
    Don
    Pa.
    No problem. This is just some info if you go westcott. I measure from the floor to my fender. My tires have the same air pressure and my floor is level. Front is 37 and half and rear is 39. I’m inch and half higher in the rear.
  21. Apr 9, 2024 at 11:01 AM
    #51
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    For the guys with the wd lift. How big is the top hat spacer that comes with the kit? And is the rear a spacer as well?
    I'm kinda thinking of just using. 25" or .5" top hat spacers in the front and dobinson c59-323 springs in the rear. I don't really want or need a lift I just want to level it out and stiffen the rear for the added weight of my gear in the back
  22. Apr 10, 2024 at 7:53 AM
    #52
    Krup235
    Krup235 New Member
    Got a reply from Eibach asking about UCA, reply was no modification necessary.
    brodeyo likes this.
  23. Apr 10, 2024 at 8:43 AM
    #53
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Very interested to see how this goes. The wholesale side of Eibach is telling their installers that UCA’s are absolutely required. Keep us posted in this thread with any installs or pictures.
  24. Apr 10, 2024 at 8:44 AM
    #54
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    So that says it’s a 2020 4Runner. This new Eibach kit wouldn’t be applicable. Is that a 2020 pictured?
  25. Apr 10, 2024 at 8:53 AM
    #55
    RusPro17
    Don
    Pa.
    I did not notice it. He posted this on Facebook Toyota 4Runner Pro and said he put the new springs on. Not sure now. Sorry.
  26. Apr 10, 2024 at 9:08 AM
    #56
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Oh no worries. Was just curious.
  27. Apr 10, 2024 at 9:13 AM
    #57
    RusPro17
    Don
    Pa.
    Yeah I looked back at his post and I thought he added the new springs but I do believe it’s the older springs. I’m curious also to see what they will look like.
  28. Apr 10, 2024 at 9:13 AM
    #58
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Eibach also say you do not need uca with the stage1 pro truck(non pro) that lifts is 2.75" front 1" rear.
    Fyi, but you'll definitely benefit with aftermarket uca. You'll be able to be over 3° castor, which keeps your 4runner from wandering on the highway. Also will help with suspension travel.
    And jba uca are the way to go.
    Superdave1.0 likes this.
  29. Apr 11, 2024 at 8:32 AM
    #59
    RusPro17
    Don
    Pa.
    I was going to start a private conversation with you but your privacy setting will not allow. A lot of times it better to do private conversations instead of clogging up the post. Don.
  30. Apr 19, 2024 at 4:22 PM
    #60
    Steggy
    Steggy New Member
    Stephen
    2023 Solar Octane 4Runner
    So I’m looking to put the Eibach E30-82-071-05-22 springs on my 2023 Trd Pro to handle the weight of new bumpers, winch, and other items, but after reading this thread it sounds like these springs bring the lift up to 3.5”?! So what are all the mods needed to accommodate this amount of lift? Are these necessary, recommend, or not needed?
    UCA’s?
    Trackbar correction kit?
    Bump stops?
    Anything else?
    Is there another option for the 23 Pro to beef up the springs for added weight?
    This is my 1st 4Runner and I’m love getting into all of this. Thanks!
