Any 2023 TRD Pro owners running Eibach lift springs?
Discussion in '5th Gen 4Runners (2010-2024)' started by UATahoe, Jan 2, 2024.
  1. Nov 22, 2024 at 9:23 AM
    #331
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    No problem. So after having the Eibach lift on it. I’m reading from the hub 22.75 front and 23.75 rear. It has settled but I’m good with it. The ride is smooth and alignment numbers are good. And no rubbing on the mudflaps with my 285’s.
  2. Nov 23, 2024 at 8:29 PM
    #332
    Carlitos_pro
    Carlitos_pro New Member
    2023 4runner pro
    None yet!
    Any pics ? Or updates? Anyone with the 2.5” set on their TRD Pro? 1.4” looks great trying to find 2.5” on a pro oe suspension
  3. Nov 26, 2024 at 1:02 PM
    #333
    brodeyo
    brodeyo New Member
    So as you all may know from my previous posts, I stuck with the WD...mostly because I felt the Eibach 1.4's were an unknown with my wheel and tire setup (285 and TRD Pro Wheels..some issues on the webs) on the '24, but also because I had WD already installed. WD has been pretty decent. Really no complaints. I typically drive by myself. However, I recently noticed that with someone ~125lbs and above in the passenger seat of the vehicle, I do rub at hard right turns with braking. In other words, when I'm coming in too hot into my driveway:). Just thought I'd pass along.
    Don - you notice anything yet with those 1.4's?
  4. Nov 26, 2024 at 2:48 PM
    #334
    RusPro17
    Don
    Pa.
    Hey John, I have not had any issues with rubbing when I have 4 people in my vehicle. Used mine most of the time when we were with friends down at the shore for a couple of days I did the driving all the time. Also even tho it has settled a little more and we were at the winery’s last weekend the 4 of us no rubbing. Very happy with my set up. Considering the aggressive offset I’m running.
    brodeyo[QUOTED] likes this.
  5. Nov 26, 2024 at 3:13 PM
    #335
    UATahoe
    UATahoe [OP] New Member
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Black Friday deal running at Eibach now so I picked up my springs today.
    RusPro17 likes this.
  6. Dec 16, 2024 at 8:28 AM
    #336
    confuzshuz
    confuzshuz New Member
    Front Springs: Eibach 1.4 inch (E30-82-069-03-20)
    Rear Springs: Eibach load leveling system for 200lbs of added weight (AK31-82-071-02-02) set at 1 1/8 inch (28mm) on the spring perch
    self installed cuz I was too cheap to pay, but my body is aching cuz I used certain muscles that I’ve never used before. Now, I just need to get an alignment
    hossler1788 and RusPro17 like this.
  7. Dec 16, 2024 at 9:52 AM
    #337
    like2lean
    like2lean New Member
    Looks good, what are your hub measurements?
  8. Dec 16, 2024 at 10:17 AM
    #338
    confuzshuz
    I currently have a crap load of heavy tools in the back cuz I had to install at my friend’s place. I’m too sore to take it out at the moment. The “before” measurements were taken when new with stock roof rack, no tent, no sliders.
    Front: before - 20 3/8 inches/after 21 7/8 inches (with tolls in the back)
    Rear: before - 22 inches/after 23 inches (with tools).
    Additional gear:
    Tent - appx 80lbs
    Rack - appx 80lbs
    Sliders - appx 130lbs total
  9. Dec 16, 2024 at 1:15 PM
    #339
    confuzshuz
    Updated measurements with the rear empty, but nearly a full tank of gas:
    Driver side: 23.5 inches
    Passenger side: 23.25 inches
  10. Jan 6, 2025 at 1:38 PM
    #340
    confuzshuz
    So, after a 3 day off-road excursion, I’ve come to the realization that I miss the plushness of the stock set up. I know these shocks can be rebuilt, but anyone know if they can be tuned or re-valved?
  11. Jan 6, 2025 at 4:49 PM
    #341
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I bet it has something to do with your rear load leveling setup.
    The eibach front springs have the same spring rate.
  12. Jan 6, 2025 at 5:07 PM
    #342
    confuzshuz
    Both sets of springs are stiffer. Stock front is supposedly 550lbs, eibach are 620lbs. Stock rear 180lbs, my load leveling is 250lbs
  13. Jan 7, 2025 at 10:07 AM
    #343
    confuzshuz
    Wanted to share this video which was part of our 3 day shenanigans. Upon doing a closeup, I see that my suspension is doing its job. Mine is the car with the roof top tent.
  14. Feb 21, 2025 at 11:08 AM
    #344
    brodeyo
    brodeyo New Member
    I'm considering going back to stock tire size and lift (from the Wescott) when it's time for new tires. I forgot how plush that was. The only negative for me was the massive nose dive and lack of ground clearance.
  15. Feb 21, 2025 at 11:20 AM
    #345
    confuzshuz
    I know exactly how you feel. The only solution is an aftermarket suspension with adjustable compression and rebound. Maybe one day, but not today. When it comes time for replacement, I’ll probably do the high end fox shocks and UCAs with a 3” front and 2” rear lift.
  16. Feb 21, 2025 at 11:21 AM
    #346
    brodeyo
    brodeyo New Member
    Yea, I think a guy on here did exactly that.
  17. Feb 21, 2025 at 6:56 PM
    #347
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    Per Fox, these are serviceable and rebuildable.
    They incorporate Internal Bypass technology and would allow the opportunity to open them up and have them revalved. However, since they are Internal Bypass, it would require someone who is familiar with Internal Bypass to successfully revalve them. It’s not just a matter of throwing shims at it and expecting a change in ride. There are tuners out there who won’t touch internal bypasses due to the complexity of tuning them, a lot of variables to consider.
  18. Feb 22, 2025 at 7:37 AM
    #348
    Jorgem2
    Jorgem2 New Member
    2024 4runner TRD PRO
    We are very happy with the stock PRO suspension ride, however I plan on installing a winch and small bumper and 285’s and the Eibach 1.4 springs
    Does anyone have these springs with a winch that can tell me if the winch softens the ride back to near stock?
    Also can I leave the rear with the stock springs to level it?
    I don’t plan on carrying much weight
  19. Feb 22, 2025 at 11:00 AM
    #349
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    I think unfortunately you will find that this is all dependent on the driver and each driver has a different feel. Some will love the Eibach setup, some will not. Some will like the Westcott some
    won’t like it. I know the installer I talked to said that the Westcott is very stiff and rides that way. And said the Eibach setup keeps a great ride. Also has a lot to do with the type of tires installed and their load rating. If I go with 285’s I am going to go with AT3’s in SL. Only 47lbs and should keep a soft road feel.
  20. Feb 22, 2025 at 12:24 PM
    #350
    brodeyo
    brodeyo New Member
    I think Westcott is fine on road . Off road is where the difference between stock shows. It’s not terrible, but noticeable. I wish I could drive a stock truck, then a wescott, then an Eibach all in a row to see the difference.
    UATahoe[QUOTED][OP] likes this.
  21. Feb 22, 2025 at 1:14 PM
    #351
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    Agree completely. That would be the ideal way. And even then it’s going to be dependent on the person in the seat. Comfortable is different to everybody.
    brodeyo likes this.
  22. Feb 22, 2025 at 1:25 PM
    #352
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    I should add that my Eibach kit is still just sitting in a bedroom because I do worry I may lose my ride quality. I absolutely love the way this thing rides. I do understand the nose dive issues. But man, the cruising ride comfort is just great to me.
    at a certain point I am going to have to just rip the bandaid off and install the supercharger and lift.
  23. Feb 22, 2025 at 1:28 PM
    #353
    brodeyo
    brodeyo New Member
    Do the swap yourself. It's a pain, but not terrible. If you don't like it, you can switch back. I've backed off the supercharger.
  24. Feb 22, 2025 at 1:36 PM
    #354
    UATahoe
    Joseph
    Huntsville, AL
    2024 TRD Pro
    I’m excited about the supercharger. It too has been sitting in a bedroom for almost a year now. lol. Wanted to get some miles on the motor first and sort of through the new break in. Trying to find an experienced shop to install has been tough that’s closest but I have found one a few hours away. Hopefully this summer I will get it installed.
  25. Feb 23, 2025 at 1:43 AM
    #355
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    If you’re in AZ I can meet up by a dirt road and volunteer my truck as it is stock other than tires
  26. Feb 23, 2025 at 4:38 AM
    #356
    RusPro17
    Don
    Pa.
    I’m so glad I switched from the westcott to the Eibach springs. My Pro has been perfect since the switch. And it’s been a few thousands of miles and still like the ride better. IMG_5638.jpg
    TRD PANTHER, kolter45 and Bentwrench like this.
  27. Mar 4, 2025 at 4:29 AM
    #357
    Wyomingite
    Wyomingite New Member
    Would really like to get the Eibach setup, just having a hard time deciding between the 1.4 and 2.5 front springs. Anybody running the 2.5 kit?
  28. Mar 4, 2025 at 11:34 AM
    #358
    brodeyo
    brodeyo New Member
    There are a few 2.5s in here. Seems the ones I’ve seen have a slight reverse rake to them.
  29. Mar 4, 2025 at 4:05 PM
    #359
    brodeyo
    brodeyo New Member
    Anyone running a bumper and winch with the 1.4s?
