Another lift & tire question - I swear I searched....
Discussion in '5th Gen 4Runners (2010-2024)' started by ThePnsh3r, Jul 21, 2020.
  1. Aug 27, 2020 at 1:15 PM
    #91
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    What’s interesting is to see how close even stock tires are to the body at full lock. They’re close, so that’s the challenge of fitting larger ones. Jeeps and Broncos don’t have this problem.
    ThePnsh3r[QUOTED][OP] likes this.
  2. Aug 27, 2020 at 3:10 PM
    #92
    ThePnsh3r
    ThePnsh3r [OP] New Member
    2020 TRDOP
    Yeah. I am a bit worried about the tires not clearing tomorrow. My biggest concern is if it will rub against the control arm. 285 should be less than an inch wider (on each side of the rim) than the 265 so it should be ok...
    As for the Jeeps and Broncos being “better” - I have a lot more faith in Toyota’s engineering. A lot of things on a Toyota are designed with reliability and durability favored over other design qualities. Jeeps frequently suffer from death wobble, and parts often need to be replaced and wear out quicker. New gladiators have same issues plus the transfer case issues. New 4cyl turbo engine and the Mild hybrid are all having issues... Bronco, on paper, is a superior machine - but I’ll credit it more when I see it CONSISTENTLY last as long as a 4Runner does - with similar level of maintenance.
  3. Aug 27, 2020 at 3:11 PM
    #93
    ThePnsh3r
    2020 TRDOP
    Here is before and after the lift
  4. Aug 27, 2020 at 3:35 PM
    #94
    You're running Ironman UCA's right?
    Are they known to rub with stock wheels and 285's?
  5. Aug 27, 2020 at 4:08 PM
    #95
    ThePnsh3r
    2020 TRDOP
    Yes, Ironman UCAs. Not for certain whether they’ll rub. I was told no - but haven’t seen anyone confirm yet. Gonna find out tomorrow.
    nimby[QUOTED] and Oldtoyotaguy like this.
  6. Aug 27, 2020 at 4:23 PM
    #96
    Oldtoyotaguy
    I agree ThePnshr3r, that’s why I never said better, haha. But they do have a design that allows for bigger tires. Btw, the lift looks great, I hope it handles as good as it looks. You don’t necessarily have to fill the wheel, imho, and I recognize that this is a subjective issue. The reason it looks odd at the moment has more to do with the anemic car tires they put in stock 4 Runners. Put a nice good looking luggy tire on there, and it will look good even one size bigger. You’re making this too hard on yourself. Keep it simple, it will look great.
    nimby likes this.
  7. Aug 27, 2020 at 4:32 PM
    #97
    ThePnsh3r
    2020 TRDOP
    Quoted for truth :oldglory:
    Oldtoyotaguy[QUOTED] likes this.
  8. Aug 27, 2020 at 8:20 PM
    #98
    ThatToyota
    ThatToyota New Member
    Following to see the outcome :cool::cool::cool:
    Lift with stock tires got me like :eek: but I can dig it. Haha.
    ThePnsh3r[OP] likes this.
  9. Aug 28, 2020 at 1:36 PM
    #99
    ThePnsh3r
    2020 TRDOP
    Tire install and alignment complete. Here it is as it stands right now. No running at full lock at either side but it looks like it will catch on the front bumper when tire pushes deep into the wheel well. A simple liner mod and bumper cut should fix it. Back side seems to be clearing just fine. And, spare fits fine, too.
    Also - as for the tires - they’re @ 36-37psi and zero vibration or issues @ up to 80mph. I ran out of road in Mexico and had to slow back down
    I’ll do a full build post later sharing more details for others interested in the lift/tire combo.
    nimby, mx4_gonzo and ThatToyota like this.
  10. Aug 28, 2020 at 1:39 PM
    #100
    ThePnsh3r
    2020 TRDOP
    Pics of clearances
  11. Aug 28, 2020 at 1:42 PM
    #101
    ThePnsh3r
    2020 TRDOP
    Clearances under compression...
    nimby and ThatToyota like this.
  12. Aug 28, 2020 at 1:45 PM
    #102
    ThatToyota
    Looks good! Should drive pretty good with those caster numbers especially on the highway.
    nimby and ThePnsh3r[QUOTED][OP] like this.
  13. Aug 28, 2020 at 1:47 PM
    #103
    ThePnsh3r
    2020 TRDOP
    Yes. I was hoping to get right to 4 - but, ironman spec was 3.8, too. Both sides are close to each other too and (as you stated already) truck rides amazing and tracks straight and true.
  14. Aug 28, 2020 at 1:49 PM
    #104
    ThatToyota
    You had plenty of tire clearance on the UCAs, too. Nice.
    nimby likes this.
  15. Aug 28, 2020 at 1:53 PM
    #105
    ThePnsh3r
    2020 TRDOP
    Thanks. I am super happy with how everything turned out and am really impressed with everything from Ironman. From the communication with sales, and then tech support, and then the actual product design and quality... Nose dive is gone, body lean in corners is reduced, ride feels more solid and stable but definitely not harsh. Super satisfied with all.
  16. Aug 28, 2020 at 1:58 PM
    #106
    ThatToyota
    Thanks for posting this and with pics. So much bad info out there.
    Did you measure before and after fender heights? I know tire size plays a role, but with a little math we can figure out the suspension lift height.
  17. Aug 28, 2020 at 2:09 PM
    #107
    Tire size doesn't matter if you center of hub to fender.
  18. Aug 28, 2020 at 2:10 PM
    #108
    ThatToyota
    Yeah, I usually do driveway to fender so I didn't think of that.
  19. Aug 28, 2020 at 2:13 PM
    #109
    ThePnsh3r
    2020 TRDOP
    I have not measured since tire install and alignment. I will later and let you know. But before tires lift took me from ~34.5 to ~37” ground to bumper front, and rose ~2” in the back. So lift netted about 3.5” front and 2.5” rear. I expect it to settle right at 3” front and maybe 2.25” rear. Final measurements to follow
    ThatToyota[QUOTED] likes this.
  20. Aug 28, 2020 at 2:14 PM
    #110
    ThePnsh3r
    2020 TRDOP
    Tire size does matter. Larger diameter tire will also be taller. Center of the tire will move up accordingly, your measurement fender to ground (or frame to ground) will also increase.
    you can see here how tire being taller moves the “center” -(axle) up, too. So, if a tire is 1” taller overall, you are effectively gaining .5” lift.
    What does NOT change - is your measurement from axle to the fender.
  21. Aug 28, 2020 at 2:15 PM
    #111
    Not if going center of hub to fender. This is why everyone always asks for hub to fender measurements when looking at lift height.
    Most are looking for lift #s of suspension not total lift with tires. Of course if I throw 40in tires on there I will have more overall lift that someone going with 33s.
  22. Aug 28, 2020 at 2:18 PM
    #112
    ThatToyota
    Coilover lift I did on 2020 Taco only settled 0.25 inches in the front after a few weeks. Your experience may vary. Either way, looks like you're in pretty good shape.
  23. Aug 28, 2020 at 2:21 PM
    #113
    ThePnsh3r
    2020 TRDOP
    Agreed on all points.
    ThatToyota likes this.
  24. Aug 28, 2020 at 2:32 PM
    #114
    ThatToyota
    @ThePnsh3r Forgot to ask, Ironman has different spring rate options based on load, right? Which ones did you go with?
  25. Aug 28, 2020 at 2:39 PM
    #115
    ThePnsh3r
    2020 TRDOP
    39” ground to fender front,
    ~23.5” hub center to fender
    40.5” ground to fender rear
    ~25” hub center to fender
    - stock load springs
    ngunbileg and ThatToyota like this.
  26. Aug 28, 2020 at 2:48 PM
    #116
    ThatToyota
    Just a friendly heads up...Your first measurement looks like 2.5 inches instead of 3.5 inches... I just noticed that.
    Your current measurements don't seem to directly compare to the first ones, but I appreciate it nonetheless.
  27. Aug 28, 2020 at 2:51 PM
    #117
    ThePnsh3r
    2020 TRDOP
    You’re correct. Math fail lol - thinking of it now, I may have mistyped the 37 instead of 38.
    But looking at just the ground to fender measurements - with tires, it is more like a 3” lift. Or about 2.5” suspension alone. That’s right on as the others have experienced, too (on the lift). Front is adjustable, and numbers that I ended up with is from requested 2” set in the front to match the rear lift in order to maintain factory rake.
  28. Aug 28, 2020 at 2:55 PM
    #118
    ThatToyota
    Honest mistake lol
  29. Aug 28, 2020 at 11:52 PM
    #119
    ThatToyota
    Wow, I was surprised to see the comfort stock load springs (front) #TOYO65A are 720 lb springs...I believe stock Toyota springs are 550 lb.
  30. Aug 30, 2020 at 8:23 AM
    #120
    mx4_gonzo
    mx4_gonzo New Member
    this makes me wanna go with 285s so bad....but I really don’t want to do any BMC
