An invisible, solid and versatile mounting solution. The 5G 4Runner Dashtop Multi Mount (DMM)
Discussion in '5th Gen 4Runners (2010-2024)' started by Lost Bolt, Dec 28, 2023.
  1. Jan 6, 2024 at 11:37 AM
    TacoGeeloor
    TacoGeeloor New Member
    Chad
    I can speak to the quality of TacoGarage DMMs. I have one in my 2020 Tacoma and absolutely love it! I’ve been waiting the arrival of something for my wife’s 2023 4Runner and now it’s here! Onto convince my wife this is the phone mount for her!
  2. Jan 6, 2024 at 11:53 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    It might have been sent out already, if not, it’s: 20853
    Thanks!
  3. Jan 6, 2024 at 5:39 PM
    mmike87
    mmike87 New Member
    An EVEN better idea is to not make assumptions on how people are using THEIR vehicle, and just worry about yourself. There are many legit devices and use cases for a mount like this if you're doing more than going to the mall.
  4. Jan 12, 2024 at 7:50 AM
    Reddawg1100
    Reddawg1100 New Member
    2014 Limited MGM
    This is precisely what I've been looking for—order placed for the mount + mighty magnet kit.
  5. Jan 16, 2024 at 1:30 PM
    coryanderson
    Cory
    Is there a projected ship date? I received the USPS tracking number on 1/6 but that was just the label. Thanks!
  6. Jan 16, 2024 at 8:12 PM
    Lost Bolt
    Lost Bolt [OP] New Member
    These are on hand I'll check on that tomorrow morning.
    coryanderson[QUOTED] likes this.
  7. Jan 17, 2024 at 8:31 AM
    coryanderson
    Cory
    Thanks! It should be here today, apparently.
  8. Jan 17, 2024 at 9:12 AM
    Lost Bolt
    We have seen it before where the packages don’t get scanned until they’re about to be delivered. It happens more during the holidays but it’s not too common this time of the year…
  9. Jan 18, 2024 at 9:06 AM
    coryanderson
    Cory
    It came last night and I figured, what the hell, and installed it. It was dark and I was "parenting" for half of it. Took about 30 minutes. I didn't snap everything back into place because I have a new stereo receiver coming tonight and I want to pop that in, then run my VHF and MicTuning wires through the dash to clean everything up. This product is sort of a perfect storm for me. I have been doing a bunch of work cleaning up my wires under the hood and figuring out my cab setup was an issue I had yet to figure out and this product certainly helps with a couple of things. I intend to use it to hold my VHF/UHF radio head and perhaps use the other side for a Lowrance or Garmin Tread GPS unit.
    A couple of notes regarding installation:
    • Pry the HVAC controls from the passenger side is easier
    • I used a spring-loaded punch to create my indents. It was almost the perfect size, a little small, but I think it centered the divots pretty well
    • While holding my youngest, I was drilling some holes and I stupidly punctured my hand.
    • I initially used a 3/16" bit because that was the size of the bolts, but realized I should have used a 1/4" bit as recommended. The holes were just slightly off-center and needed to be slightly bigger to get the bolts into the proper slot
    I'll upload some more photos once I get everything installed and cleaned up. Pretty stoked with how the dash should turn out. Everything is finding a proper spot. My goal was to have the passenger side and driver side have access to everything. Here is my thread regarding my "build":
    https://www.4runners.com/threads/5th-gen-build-a-baja-resilient-daily-driver.36058/
    P.S. - posting multiple photos on this site kinda sucks, am I missing an easier way?
  10. Jan 18, 2024 at 4:06 PM
    The picture of the bloody hand as an install step was a nice addition. Lol
  11. Jan 20, 2024 at 12:47 PM
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    in for later
    I saw this thread last month and completely forgot about till now.
  12. Jan 20, 2024 at 3:54 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I saw this a bit ago, said no, but couldn’t stop considering it. Order placed. Thanks for the group buy discount.
    Lost Bolt[OP] likes this.
  13. Jan 21, 2024 at 5:26 AM
    Mister Eds 4R
    Mister Eds 4R New Member
    E.G.
    2021 TRD ORP
    I also am interested but curious if anyone has figured a way to route a cable for the CarPlay? This is my wife's ride and she has to use CarPlay so finding a mounting solution where she can easily hook up is key. I like this type but also looking at the lower side mount style.
  14. Jan 21, 2024 at 7:48 AM
    coryanderson
    Cory
    Yea. When you have the dash apart you can easily run a wire down. I ran a wire down for my VHF radio.
    raimieb and Reddawg1100 like this.
  15. Jan 21, 2024 at 8:13 AM
    Lost Bolt
    It’s easy. Once you have the dash out you can cut a little slot on the same plastic that you install the DMM at and run the cable behind the dash, the usb port from the bottom can be moved from the a lot that it is at into the back of the dash, then replaced by a different switch or a blank. The wire then remains hidden.
  16. Jan 21, 2024 at 8:17 AM
    Lost Bolt
    I promised 5 full refunds to those who did this kind of post. You’re the first! I just need to know your order number
    Spare Parts likes this.
  17. Jan 21, 2024 at 11:50 AM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    I got to admit, it was easier than I thought to install this mount on my 2020 TRD Pro. Being realistic, it took me about three hours from start to finish but, like everything I do, there was a hiccup. The hardest part was removing the lower dash face or the part with the AC controls. The key was using plastic prying tools and patience, but it came out just like the Taco Grage video shows. Really, the rest was cake. Just one thing to not do.
    Don't drop the 10mm screws into the dash.
    Dropping a fastener into the dash cost me about an hour of searching with a flashlight and a mirror. I didn't want to leave it and just replace the fastener for fear of it causing a squeak or fraying a wire. Once spotted it was fished out with a magnet.
    Also, I disconnected the AC wires so I could remove the lower panel but did not disconnect the head unit. I really didn't need to. Reassembly was super easy as everything fit back together perfectly without issue. The mount seems super secure and everything from Taco Garage fit perfectly. I also added a short section of heat shrink tubing the bottom of the ball mounts just for aesthetic reasons.
    Just follow the Taco Garage video and you really cannot go wrong.
    I never really liked that ProClip mount.
    P.S. My order number is #20789.
  18. Jan 21, 2024 at 12:28 PM
    Mister Eds 4R
    E.G.
    2021 TRD ORP
    Awesome! That’s exactly what I’m hoping. She has a Rokfrom case so I’m thinking the magnet will work great with that.
  19. Jan 21, 2024 at 12:46 PM
    #49
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I was hoping to get my DMM mounted today (so I would be one the 5 chosen ones) but with temps in the single digits it'll have to wait. :annoyed:
    McSpazatron likes this.
  20. Jan 21, 2024 at 12:55 PM
    #50
    coryanderson
    Cory
    thanks!
    order #: 20853
  21. Jan 22, 2024 at 7:55 AM
    #51
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    After disassembling the dash, I used a drill bit to mark the holes.
    I drilled pilot holes to get a better center.
    I then finished drilling the holes to 1/4" and attached the top and bottom plates.
    Finished product. Looks way cleaner than the shelf type dash mounts. Ignore the double sided tape. That will disappear when my hands warm up.
    Install took 45 mins. Pretty straight forward. No issues. Dash pops right out, even at 25 degrees. My hands are freezing.
    Order # 20872..... Thank you. I love this mount.
  22. Jan 22, 2024 at 1:17 PM
    #52
    Spare Parts
    Southern Maine
    22 LR ORP
    How do I get these black i nylon, I forgot to make note on my order?
  23. Jan 22, 2024 at 2:43 PM
    #53
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Curious if there are any pics of the slim mount holding a phone. I don't want to use a magnet.
  24. Jan 22, 2024 at 3:56 PM
    #54
    Spare Parts
    Southern Maine
    22 LR ORP
    I have a slim on the way, I’ll post up once I get it
    djwantke and laxman09[QUOTED] like this.
  25. Jan 22, 2024 at 4:27 PM
    #55
    laxman09
    Thanks. I have an iOttie mount I like, I just don't know if it would attach to the ball mount or the reducer arm.
  26. Jan 22, 2024 at 6:12 PM
    #56
    Lost Bolt
    I’ve instructed everyone here to ship these with the vinyl included on all 4runner mounts.
    Spare Parts[QUOTED] likes this.
  27. Jan 22, 2024 at 6:19 PM
    #57
    Lost Bolt
    Refunds sent!
  28. Jan 22, 2024 at 7:48 PM
    #58
    coryanderson
    Cory
    Got mine. Thanks!
  29. Jan 22, 2024 at 8:18 PM
    #59
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Thank you very much.
    Lost Bolt[QUOTED][OP] likes this.
  30. Jan 23, 2024 at 5:21 AM
    #60
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    what formats are those? Great fitment!
