Am I Missing Under Body Armor?
Discussion in '5th Gen 4Runners (2010-2024)' started by dxhum, Nov 26, 2022.
  1. Nov 27, 2022 at 6:59 PM
    dxhum
    dxhum [OP] New Member
  2. Nov 27, 2022 at 7:02 PM
    dxhum
    What does that mean?
  3. Nov 27, 2022 at 7:04 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Guess the joke fell flat. I asked earlier if you ran over imitation crab. The picture you provided looked very much like imitation crab. Many people liked my comment when I asked if you ran over said imitation crab. You never replied so I quoted myself asking once again about the imitation crab in your undercarriage with a reference to the old National Inquirerer tabloid who's motto was "Inquiring minds want to know".
    Here is said picture you provided which again appears to be imitation crab splattered on your undercarriage...
    Also for reference this is what imitation crab looks like. (Google image, I take no credit)
    Dabigono and doc4216 like this.
  4. Nov 27, 2022 at 7:08 PM
    dxhum
    OH!!! Yeah, I was wondering what that was! I was on the beach; it may be real...
  5. Nov 27, 2022 at 7:25 PM
    Joe68RS
    Joe68RS New Member
    Joe
    Louisville, KY
    2023 Lunar Rock ORP
    I just installed the stainless version this weekend. It’s a high quality piece. MillerCat recommends the stainless for max theft prevention since it’s harder to cut through. The thickness between the two isn’t much different (16gauge SS vs 12 gauge Al). I figured the added peace of mind was worth the $100 price difference.
    dxhum[QUOTED][OP] likes this.
  6. Nov 28, 2022 at 5:39 AM
    dxhum
    Yes, that is the one. But I'm laboring over aluminum or stainless.
    I read that thieves prefer seeing the stainless because it is actually easier to cut. The aluminum melts while cutting due to friction and clogs the teeth of the saw. Also you get longer life from you CAT with the aluminum as it dissipates heat better.
    What is the weight difference between the stainless and aluminum?
  7. Nov 28, 2022 at 6:23 AM
    I asked MillerCat that, and their response was 2-3 lbs if I remember correctly.
    I also got the stainless, as I don't want any oxidation issues with aluminum being attached to steel.
    dxhum[QUOTED][OP] and 2Toys like this.
  8. Nov 28, 2022 at 6:49 AM
    TRD8
    TRD8 New Member
    North Georgia
  9. Nov 28, 2022 at 7:01 AM
    Joe68RS
    Joe68RS New Member
    Joe
    Louisville, KY
    2023 Lunar Rock ORP
    Here's a link to MillerCat's comparison of the stainless vs aluminum shields. https://catshield.com/blogs/news/304-stainless-vs-aluminum
    Also, it should be noted that gauge thickness of stainless and aluminum are not directly comparable (e.g. 12 gauge SS is not the same thickness as 12 gauge Al) since sheet metals all have their own separate gauge charts. Aluminum gauge thickness's are thinner than the equivalent SS gauge. In the case of these shields the 16guage SS is roughly 1.6mm thick vs 2.0mm for the 12gauge AL. That .4mm difference isn't going to make up for the higher strength of the SS.
  10. Nov 28, 2022 at 8:26 AM
    dxhum
    I checked the specs on their site; aluminum = 2 pounds and stainless = 4 pounds.
  11. Nov 29, 2022 at 5:23 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    How many miles? You would have to really drive it hard to wear out the originals in 2 years.
    I just traded in a Tacoma with 45k and the front pads still had more than half the original thickness.
  12. Nov 29, 2022 at 5:52 AM
    universalfrost
    universalfrost New Member
    Joseph
    Belpre, Ohio
    Predator bars, blackout emblems, TRD Pro Wheels, Falken AT3W tires
    800 for a brake job is insane unless you need new rotors and then there are other issues with calipers etc... . pads and resurface rotors is nowhere near 800 and is 30-45 min per tire at max (assuming stuck bolts, etc)... .
    dxhum[OP] likes this.
