Alignment specs
Discussion in '5th Gen 4Runners (2010-2024)' started by hossler1788, Jul 25, 2022.
  1. Jun 26, 2024 at 7:01 PM
    j1829816
    j1829816 New Member
    Look at mine, i just bought it and its all in spec but the steering wheel is crooked and drifts to the right, iive done 3 alignments to it in 48 hrs and noone can figure out why, igs all dtock and no accidents 2021 4runner 4wd
  2. Jun 27, 2024 at 8:45 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Hows the tread on your tires?
    You could try doing a tire rotation if you haven't already.
  3. Jun 27, 2024 at 8:52 AM
    j1829816
    j1829816 New Member
    They rotated the tires since front tires were uneven, they balanced it and aligned it, and now the steering is crooked to the right and drifts to the right not pull just drifts, that thrust angle changed and toe too, they said suspension and frame looked good but idk why its having alignment issues, and i only have until tmrrw to return it
  4. Jun 27, 2024 at 9:06 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    With unusually worn tires it's not worth aligning anymore until tires are replaced. To be honest, I would walk away from this vehicle. You don't need the hassle. Could have been in a minor unreported accident and is unalignable, don't make this your problem. Take it back, get out of it.
    anewcaragain likes this.
  5. Jul 2, 2024 at 12:49 AM
    ramnj
    ramnj New Member
    NJ
    '24 4Runner TRD ORP
    None
    Are you still running this same alignment? Going to get mine set the same as yours. My 4Runner is set up very similar and I’m having tire rub at rear of front inside fender. I’ve taken it to a couple of alignment shops and they don’t know how to correctly align it. They set it up to stock specs.
  6. Jul 2, 2024 at 6:53 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Do you have something wrong with the rear other than rubbing?
  7. Jul 2, 2024 at 7:16 AM
    ramnj
    ramnj New Member
    NJ
    '24 4Runner TRD ORP
    None
    sorry. Meant to say rubbing on the rear of the front fender while turning.
  8. Jul 2, 2024 at 7:19 AM
    backpacker
    2023 TRD ORP
    OK, I hope you find a place that can get it done.
  9. Jul 4, 2024 at 12:36 PM
    Sandman317
    Sandman317 New Member
    2022 AG ORP
    Whats your wheel/tire and suspension set up?
    I am still running this alignment. I was running a SWS Dakar wheel 17x9 -25 w/ a 265/70 Wildpeak and only very minor rub at full lock on the mud flap.
    This past weekend I did put on a little more aggressive set up. Now have a SCS 17x9 -38 w/ 285/70 Wildpeaks. I had to remove the mud flap, trim a little more on the front fender, and will eventually do a cab mount chop when I have time. I also have a Dobinson IMS set up to install. That will provide a little more lift and will then get aligned again.
  10. Jul 4, 2024 at 4:02 PM
    ramnj
    ramnj New Member
    NJ
    '24 4Runner TRD ORP
    None
    Thanks for responding.
    My setup is Bilstein 5100 set at 1.75”, Bilstein Plus 1” rear coils, JBA UCA, RRW7-S wheels with ‘0’ offset and Wildpeak 285/70 R17.
    I found out that the problem was the shop did not follow the alignment setup that JBA states should be used in their manual.
    I have an appointment tomorrow morning to re-do the alignment. Hopefully that will solve my rubbing problem.
    Sandman317[QUOTED] likes this.
  11. Jul 6, 2024 at 9:26 AM
    ramnj
    ramnj New Member
    NJ
    '24 4Runner TRD ORP
    None
    Alignment got dialed in by a small shop located near me. Only thing the tech did different than all the other shops was follow JBA's recommended settings and then fine tune. No rubbing at all.
    TxTRD, mac1279 and Sandman317 like this.
  12. Aug 29, 2024 at 12:01 PM
    Jobin918
    Jobin918 New Member
    Have been searching for a setup like this. I want to run 17x9 Lock’s with a 0 offset or they come in -12 offset, wrapped in 265/70 or 275/70. I’m hearing conflicting answers about rubbing and not rubbing. Still on stock suspension so looking for the best setup for the time being. Any suggestions?
  13. Sep 28, 2024 at 12:52 PM
    Robinwt1
    Robinwt1 New Member
    Tony
    2014 4runner 2005 4runner 95 pickup
    Yes lol
    Just picked up the 4runner from the lot from alignment. It is at 1° positive camber (spec is .8to -.8) on the drivers wheel. Anyone think the 2 tenths is worth worrying about. They are saying that the cam is stuck. Also I hate how they always try to blame things on something like the lift kit.
  14. Sep 28, 2024 at 2:35 PM
    Did they tell you if the stuck cam is on the left side? If so, that bolt/cam might need to be cut out and replaced before they can get the camber any better.
    You got some nice caster numbers. Do you have aftermarket UCAs? I’m on stock UCAs and at 2.5 inches of lift, caster was the only thing they couldn’t get perfect on mine.
  15. Sep 30, 2024 at 5:38 AM
    Robinwt1
    Robinwt1 New Member
    Tony
    Yes lol
    Not sure, with the hurricane they were only able to process payments and let me pick it up so I am still trying to find out. Also, yes on the aftermarket UCAs, We went with the Rough Country 3" lift with the UCAs. Don't come at me about RC I have used their stuff for years, and yes they are not the best but for my wife who only ever does some beach driving and light trails(gravel roads) its fine.
  16. Sep 30, 2024 at 12:48 PM
    Robinwt1
    Robinwt1 New Member
    Tony
    Yes lol
    they said its the drivers side
