Air Compressor/Inflator for the 4Runner
Discussion in '5th Gen 4Runners (2010-2024)' started by BeavertonCommuter, Oct 15, 2021.
  1. Dec 3, 2021 at 4:17 PM
    #61
    I'm using this Smitttbilt deflator:
    Smittybilt 2823 Rapid Tire Deflator (R.A.D.) https://www.amazon.com/dp/B06WP6R917
    It works well, but it's more work than the automatic type mentioned above. The one benefit I see is that I can put the tires at whatever pressure I like for the situation.
    This style is very popular, as you just set them up and then screw them on to deflate.
    Staun Automatic Tire Deflators (Standard Duty 6-30 PSI) https://www.amazon.com/dp/B00QBPBLWY?_encoding=UTF8
    The downside being that you're stuck with whatever PSI you set them at. One smart Idea I read was to set 2 up for a typical easy trail pressure (maybe 25-ish PSI with stock size tires), and set 2 up for a lower pressure for more difficult terrain and maximum flotation.
  2. Dec 3, 2021 at 4:30 PM
    #62
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    nonuniform likes this.
  3. Dec 3, 2021 at 6:16 PM
    #63
    T4R13
    T4R13 New Member
    Clarksburg wv
    19 sr5p
    I use the teraflex deflator, identical to the arb
  4. Dec 3, 2021 at 9:34 PM
    #64
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    This *is* a good idea. Gonna use it. Thanks.
  5. Dec 3, 2021 at 9:40 PM
    #65
    You're welcome!
    Do you have a set of those style deflators? Just curious which brand and how you like them?
  6. Dec 4, 2021 at 9:56 AM
    #66
    nonuniform
    nonuniform New Member
    2021 TRD OR
    Thank you for the deflator suggestions! I really appreciate the variety of solutions that you all are using. Now I'll go navel gaze on this for a bit, until after xmas when I can buy myself toys again!
  7. Dec 4, 2021 at 6:04 PM
    #67
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Stan's? Staun's?
    Well-machined.
    Work great on the bench and in the driveway. Haven't tested them out in a dusty, dirty environment yet.
    Jason
  8. Dec 7, 2021 at 10:24 AM
    #68
    Wcslv
    Wcslv New Member
    19 TRD PRO
  9. Dec 10, 2021 at 12:55 PM
    #69
    iceberg
    iceberg my other toy
    Dale
    Kiowa, CO
    2016 Silver 4Runner SR
  10. Dec 10, 2021 at 12:56 PM
    #70
    iceberg
    Dale
    Kiowa, CO
  11. Jun 4, 2023 at 8:03 PM
    #71
    backpacker
    backpacker New Member
    2023 TRD ORP
    Has anyone experienced issues with reduced valve stem life due to frequent use of the ARB-style deflators? I wonder how many valve core removal/replacement cycles the valve stem threads cam take.
  12. Jun 5, 2023 at 11:06 AM
    #72
    I think thread wear is a non issue. The valve cores have O-rings. I think the O-ring would be the point of failure. FWIW I keep a couple of spare valve cores with my spare fuses.
  13. Jun 5, 2023 at 11:10 AM
    #73
    I had an ARB twin with an intermittent internal short. Sometimes it would work, sometimes not. ARB is not the be-all end-all.
  14. Jun 5, 2023 at 11:11 AM
    #74
    backpacker
    2023 TRD ORP
    I'm less concerned about going through a bunch of cores as I am about wrecking the threads on the valve stem side. Then I'd be stuck with not only the cost of a TPMS valve, but also mount and balance. It's probably too much of hypothetical question, since I don't expect a tire to go much beyond three years, but cross-threading a core just once could be unfortunate.
  15. Jun 5, 2023 at 11:15 AM
    #75
    Yes, cross threading would be bad. I was answering your comment about removal/replacement cycles.
