Accidentally used 0W-16 instead of 0W-20… Do I need to change oil over again?
Discussion in '5th Gen 4Runners (2010-2024)' started by torred, Apr 7, 2024.
  1. Apr 8, 2024 at 6:10 AM
    Your 1GR-FE engine was originally designed for 5W30. A revised cooling jacket design in 2010 allowed it to use 0W20 with acceptable reliability. 0W-16 is two viscosity grades lower than what the engine was originally designed for. It is likely to cause accelerated engine wear.
    Evo03 and Old Tanker like this.
  2. Apr 8, 2024 at 6:33 AM
    Regular Corolla and Crown use 0W8: https://assets.sia.toyota.com/publications/en/om-s/OM02684U/pdf/OM02684U.pdf
    The harder-working engines in the GR models are spec'd for 0W20, though Toyota wants you to use the exotic Toyota GR oil imported from Spain (rebranded Shell Helix): https://parts.lakelandtoyota.com/p/__/GTMO-C5-0W20-5L-SN/15904917/08880WA010.html
    I don't know if Shell Helix is any better or worse than the Pennzoil Platinum readily available at Walmart in North America.
    Yotaholic[QUOTED] likes this.
  3. Apr 8, 2024 at 7:46 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Depends on what you're thickening. Chowder, yeah. Delicate Bordeaux demi-glace, no f-ing way.
  4. Apr 8, 2024 at 8:33 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I had a 2018 Camry Hybrid that required 0W-16
    I think most newer Toyota hybrid’s require it to get the best MPGs.
  5. Apr 8, 2024 at 9:13 AM
    Drain the 0-16, Leave the filter in place as is.
    Refill with 0-20
    Why risk your engine for a few dollars and mark one for experience!
    Old Tanker and Rocko9999 like this.
  6. Apr 8, 2024 at 12:14 PM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    We have a 2019 Camry XSE that uses 0W-16. The manual does say that you can use 0W-20 for an oil change if you can't find the 0W-16 but not to do it twice in a row.
  7. Apr 8, 2024 at 2:38 PM
    agreed. Change it before you hit another 3000
  8. Apr 8, 2024 at 3:02 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I would run it if you live in a colder climate, and then change it out when it gets warmer.
