a tune or a pedal commander
Discussion in '5th Gen 4Runners (2010-2024)' started by Late Life Crisis, Mar 12, 2023.
Thread Status:
Not open for further replies.
  1. Apr 13, 2023 at 8:44 AM
    #61
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You come in to the thread, and talk shit on the tunes. Telling members they are a waste. When you literally have no fucking clue. and this isn't the first thread you did that in.
    08TXRunner likes this.
  2. Apr 13, 2023 at 8:45 AM
    #62
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    What are we proving wrong?
  3. Apr 13, 2023 at 8:51 AM
    #63
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    And how the fuck do you know that, your ever try the tunes? Is your 4runner regeared atleast?
  4. Apr 13, 2023 at 8:58 AM
    #64
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Jynarik I'm just joking around, but was implying if you think @Thatbassguy is the most stubborn guy on here, you haven't engaged with @Nano909. All you guys are much more knowledgeable than I, with many many more Messages. Bassguy and Nano are actually pretty OG, have spent a lot of money, and do know what they're talking bout from experience, I believe
    glwood54, Nano909 and Jynarik like this.
  5. Apr 13, 2023 at 8:58 AM
    #65
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    a regear is mechanical. A tune is not. Why don’t you believe that a tune doesn’t do anything?
  6. Apr 13, 2023 at 8:59 AM
    #66
    LOL
  7. Apr 13, 2023 at 9:00 AM
    #67
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Answer the questions, have you tired a tune on your 4runner? Which brand? Is your 4runner regeared?
  8. Apr 13, 2023 at 9:03 AM
    #68
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Lol ok buddy. You never tired a tune nor is your 4runner regeared.
    And I also drive a car that makes actual power as well.
  9. Apr 13, 2023 at 9:04 AM
    #69
    here we go
    Thepremier141 likes this.
  10. Apr 13, 2023 at 9:06 AM
    #70
    I do agree that a regear is very beneficial, especially since I think the gearing is a bit high from stock.
    But, I'd say that a 10% increase in torque at low RPM's sounds pretty awesome, too.
    All of these things have their purpose.
    Nano909[QUOTED] likes this.
  11. Apr 13, 2023 at 9:08 AM
    #71
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Yep thats me just posting shit to post it.
    I'd still love to know if you ever tired a tune? Which brand? Is your 4runner regeared?
  12. Apr 13, 2023 at 9:25 AM
    #72
    That's fine.
    But, I know a number of people who have tuned Tacomas, and they generally seem beyond satisfied. It's not just about the power increase, I believe some actually improve the shift logic, which was a huge deal when the 3rd gen Tacos came out.
    I haven't experienced a tuned 4Runner, but a few hundred bucks for a real increase in power (however modest) seems like a way better deal than some "cold air" intakes, and other things people spend money on.
    At the end of the day, I don't think anything is really a waste of money, unless the buyer isn't satisfied.
    ConroeMike, WTW15 and Trail Runnah like this.
  13. Apr 13, 2023 at 9:25 AM
    #73
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Options you have NO real world knowledge of.
    There's three threads from company's offering tunes. There is no negative reviews. Whys that? There's also multiple members who are regeared AND running tunes. Once again no negitive reviews.
  14. Apr 13, 2023 at 9:34 AM
    #74
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Do you even own a 4runner?
    kmeeg likes this.
  15. Apr 13, 2023 at 9:37 AM
    #75
    :popcorn:
  16. Apr 13, 2023 at 9:42 AM
    #76
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You have 600+ post on a 4runner forum and you have no 4runner.... that says something about you right there.
    You enjoy the rest of your day...dipshit
  17. Apr 13, 2023 at 9:42 AM
    #77
    Ohh please.. that pathetic bugger has wasted lot of threads and you are going to ask questions a waste this thread also?
  18. Apr 13, 2023 at 9:44 AM
    #78
    As much as I've had fun beefing with Nano909, even I remember him posting he has a Taco and a 5th gen. Can ya'll even afford that
    Nano909 likes this.
  19. Apr 13, 2023 at 9:46 AM
    #79
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    So now we have Pedal Commander vs. Tune vs. Regear.
    I’ll say this, if you really want to improve your vehicle as you add weight and larger tires, the tune and regear are way more beneficial vs a throttle controller. A regear is $2000-5000 depending on what you’re doing and how you’re doing it (who’s doing it, adding lockers, etc..) a naturally aspirated tune is $600-$650 at the top end. What people forget, or don’t understand, is that shift scheduling is programmed to match gears, so adding gears and not correcting your shift scheduling is only a “partial” fix. Also, depending on the gears you choose, you will run into global speed limiters and not be able to go over 80-85 mph. Therefore, the ultimate fix is an “AND” situation, not an “or”. Tune and regear.
    Now having said that, the current tuning software doesn’t have all the capabilities needed to do adjust for gears and shift scheduling on all T4R’s, so the ultimate solution isn’t available to everyone. However, this functionality will be added soon I hear.
    Some will ask why not combine throttle controller, tune, and gears? That can be done also, but not typically recommended. Why? Throttle position/voltage is a variable used in shift scheduling. If you are constantly changing your throttle controller settings, it will confuse your shift scheduling and your vehicle will shift/behave erratically.
    No tuner in their right mind should be bragging about adding 10-20 HP/TQ. What the dyno data on Naturally Aspirated Toyotas shows is that you can address the driveability issues (laggy throttle, erratic shifting, etc…) AND keep equal or better HP/TQ vs the stock calibration. In my testing, there are tunes that address driveability but can’t make equal or better HP/TQ vs the stock calibration. If a tune you are looking at doesn’t have dyno data validating it is equal or better than stock, be warned.
    Unless you add forced induction, you’re not going to add significant power to these trucks. CAI’s and exhaust also do nothing for the naturally aspirated engines in our testing, yet people dump $300+ on a CAI and $700+ on exhaust for noise. But yeah, $600 for a tune that actually makes a little power and addresses other issues is too much…
    :smashpc:
    Thatbassguy and hossler1788 like this.
  20. Apr 13, 2023 at 9:48 AM
    #80
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    This thread is not that long, so please show a direct quote of my "uneducated opinion." If you weren't so combative, you'd see that my questions about the tune aligned with your opinion - I was questioning the cost vs. the hp/tq gain. And doing it respectfully to those in the thread. Then you came in and for no reason, in post #48, acting like a jerk. Up to that point the discussion was going just fine with everyone debating the pros/cons. So once again you've derailed another thread with your BS.
    So again, show a direct quote of my "uneducated opinion."
  21. Apr 13, 2023 at 9:53 AM
    #81
    08TXRunner
    '20 SR5P
    I just read through the whole thread and there's nothing remotely resembling what you are talking about. So I'll say it again real slow - take 30 seconds and directly quote any of my posts that support your comments. Let's see them.
Thread Status:
