a tune or a pedal commander
Discussion in '5th Gen 4Runners (2010-2024)' started by Late Life Crisis, Mar 12, 2023.
Thread Status:
Not open for further replies.
  1. Apr 12, 2023 at 3:41 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Two questions: 1) what is the cost of pedal device vs. a tune? and 2) how much extra hp/tq does the tune provide, over what rpm range?
    If the cost difference is minimal, I'd go with the tune. If the cost difference is large, and the hp/tq gains are minimal with the tune, I'd go with the pedal device.
  2. Apr 12, 2023 at 4:11 PM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    Can’t speak to other tunes, but the OTT tune HP/TQ results, done in my T4R, are posted below:
    https://www.4runners.com/threads/overland-torque-tune-ott-by-overland-tailor.27827/#post-386895
    Tuning naturally aspirated Toyotas will not yield massive peak HP and TQ gains, Toyota just doesn’t leave a ton of power and torque on the table. But meaningful gains can be made at various points in the rpm range. OTT focuses on the low end, as that improves a lot of common driveability issues. Boost the torque below 4000 rpm and the vehicle doesn’t have to shift as much. Combine that with improved shift scheduling and throttle response, and the overall package is impressive.
    Cost varies for both tunes and throttle controllers. There are $150 throttle controllers and $400 throttle controllers. Same goes for tunes, there are lower cost and higher cost tune options. OTT uses a few different software options and cost varies by application. Most all 2010-2019 T4R’s do not have transmission access, and therefore are priced lower, 2020+ T4R’s do have transmission tuning, plus increased software costs, so are priced higher. Generally OTT tunes range from $450-$650 for naturally aspirated 4Runners.
    Tunes are more expensive than throttle controllers, but provide more performance as well.
    Trail Runnah likes this.
  3. Apr 12, 2023 at 4:48 PM
    anthonydotb
    anthonydotb ig: @phantom.rnr
    Anthony
    T4R Trail Edition Premium KDSS
    None yet
    I live in California where everything is illegal (I might even be breaking some kind of law by keeping this tab open in the background), so I'm using the Sprint Booster. I love it. It doesn't make the car faster, but it gives me more power with less input. I love it and wish the ECU/throttle came mapped like this.
    Catchacold and Thatbassguy like this.
  4. Apr 12, 2023 at 4:55 PM
    anthonydotb
    Anthony
    None yet
    Say what?!?! Really?
  5. Apr 12, 2023 at 5:01 PM
    08TXRunner
    '20 SR5P
    So you got 7.5hp and 9lb/ft of torque for $450-650? Oof. That answers my question. I know there are areas under 2500 rpm that have better numbers but that's basically off-idle.
    whippersnapper02 likes this.
  6. Apr 12, 2023 at 5:14 PM
    Sure if you have thoughts and prayers.
    anthonydotb[QUOTED] likes this.
  7. Apr 12, 2023 at 5:47 PM
    I'd be way more interested in the 10% torque gain at ~2200 RPM's. That's a significant increase in usable power.
  8. Apr 12, 2023 at 5:56 PM
    08TXRunner
    '20 SR5P
    You are right. It's an interesting calculation of cost vs. benefit.
  9. Apr 12, 2023 at 6:10 PM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Not sure what you’re looking at, but at peak it’s closer to 10HP/10TQ, but the TQ gaines below 3000 rpm are better. A pedal commander gets you 0 HP and 0 TQ for $300. Again, Toyota doesn’t leave a lot on the bone as far as WOT Dyno pulls.
    The tune is more about the sum of the parts vs just adding HP/TQ. A little more torque, improved shift logic, and better pedal response make a noticablly better driving experience. Whether it’s worth the $ is up to each individual. I know I don’t want to go back to stock, YMMV…
  10. Apr 12, 2023 at 6:17 PM
    08TXRunner
    '20 SR5P
    I'm looking at exactly what you are looking at. So you're quibbling about 2.5 and 1.0?
  11. Apr 12, 2023 at 6:43 PM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I have the Ultimate9 X peddle throttle adapter, but got it because of the Bluetooth only ability and locking out input of the gas peddle for an added layer of theft prevention. I only ever had it set on Factory peddle input as I’ve been fine with the truck. But I’ve recently added weight (body armor, molle panels/shelf, and 285s in C load) and I feel it if n factory mode. Started using a mild setting a couple of days ago and it feels less impacted now. I know eventually I will get the OTT Tune.
    BortisYeltzen and Thatbassguy like this.
  12. Apr 12, 2023 at 6:59 PM
    You know, you're not wrong. I do argue/debate a lot here. It's usually well intentioned, but I know I can be a smart-ass at times. So, I apologize. I probably could have chosen a better way to say what I said earlier.
    Here's my position:
    I don't personally have any complaints about the 4Runner that a pedal commander would fix. So, when someone says that it sucks stock, I just can't let it slide, even though I know it's just an opinion.
    I should specify that it is MY OPINION that it's fine stock, and I know I'm probably in the minority.
    I think the PC (and other similar devices) are worth every penny if it improves your driving experience! I would never discourage anyone from buying one, as I rarely have heard a complaint about them. And, I won't deny that I might even enjoy it. It's just that there are about a million other things that I'd rather spend the money on.
  13. Apr 12, 2023 at 7:15 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Late Life Crisis
    I tried to read most of the comments, I have and like the Pedal Commander, and it cost $300 CAD - wouldn't necessarily call it cheap. What's important to ask is how much are you willing to spend? A tune or a regear is much more than a PC!
    SlvrSlug and Thatbassguy like this.
  14. Apr 12, 2023 at 7:38 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    I am not sure this is accurate. I think the Tacoma and 4Runner tunes simply flash the ECU (KDmax and OTT tune) and can easy be reverted to OEM. Overland Engineer has a great YouTube video on it that if Im not mistaken he details reverting his rig to the stock ECU tune at the end of the video. Can anyone with a tune confirm this is accurate?
    https://www.youtube.com/watch?v=naLT7X5iUJM
  15. Apr 12, 2023 at 7:42 PM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    I have no idea if you’ve driven a tune or not. But I can tell you my personal experience, the increased torque in this 1000 rpm (2000-3000 rpm) range greatly changes how this vehicle behaves in many driving situations. It is the difference between holding a gear and downshifting in many situations.
    Next time you go for a drive see where you spend most of your time in the rpm range.
    Whether you want a tune or not is your choice. I’m just sharing my experience. In the context of this thread, you can have what the tune offers or a Pedal Commander that just scales throttle. The tune can do what the Pedal Commander does, the Pedal Commander cannot do what the tune does. Your $, your choice.
  16. Apr 12, 2023 at 7:44 PM
    CandyManDan
    CandyManDan New Member
    Working on it
    So.... what oil should I use? :D
  17. Apr 12, 2023 at 7:47 PM
    Olive, cold pressed
    CandyManDan[QUOTED] likes this.
  18. Apr 12, 2023 at 7:53 PM
    CandyManDan
    Working on it
    Pam is HAF, but now I need to know... Ginger or Mary Anne?
  19. Apr 12, 2023 at 8:01 PM
    #49
    CandyManDan
    Working on it
    Yep... sweet country innocence beats Hollywood tramp every time!
    Sorry for the thread jack... just having some fun.
    Cheers guys... I'm pretty sure sitting at a bar and having a cold brew everyone would simply come back with, "I love my 4Runner".
  20. Apr 12, 2023 at 8:03 PM
    #50
    This is extremely appealing to me! I generally don't exceed 2500 RPM's unless I'm in a hurry, or need to make a move. I actually think there's a decent amount of torque there, but the gearing is a little too high. I think these things should come with 4.10's.
    Trail Runnah and Nano909 like this.
  21. Apr 12, 2023 at 8:04 PM
    #51
    CandyManDan
    Working on it
    ha... I guess I gave that away.
    Oak and Eden bourbon on the rocks.
    Nano909[QUOTED] likes this.
  22. Apr 12, 2023 at 8:11 PM
    #52
    CandyManDan
    Working on it
  23. Apr 12, 2023 at 8:11 PM
    #53
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    This isn’t for him. It’s for everyone reading this.
    Only issue for you is we don’t have transmission tuning access for the 2019. So you can’t experience the full experience those of us on 2020+ get with the engine and transmission tune. You can experience the engine tune, which bumps the TQ in that range, and the benefits that come with it, along with throttle improvements. It’s solid, but unfortunately not the full experience. It is priced accordingly though, around $400 for an ECU only tune.
    VF tuner states they are gaining transmission access on the older T4R’s so only a matter of time before the full experience is available to all. It’s weird, as some 2010 T4R’s have full Transmission access, so it’s spotty.
  24. Apr 13, 2023 at 7:05 AM
    #54
    08TXRunner
    '20 SR5P
    Nice try - go back and read the thread. You asked the OP if his 3/2 lift was a body lift or a suspension lift. I asked you to point to a 3/2 body lift kit to point out the ridiculousness of your question, then you started in with your usual insults. That earned you a little vacation, didn't it?
  25. Apr 13, 2023 at 7:38 AM
    #55
  26. Apr 13, 2023 at 7:53 AM
    #56
    Off idle TQ is what you want. That's what helps drivability, since lower RPM is where the engine spends most of its time.
    The problem with the 4.0 is not the peak numbers, it's that they occur so high in the RPM range.
    08TXRunner[QUOTED] likes this.
  27. Apr 13, 2023 at 8:16 AM
    #57
    08TXRunner
    '20 SR5P
    Actually no, I don't do that. The thread apparently got deleted because you mucked it up, just like you've done to this one.
  28. Apr 13, 2023 at 8:27 AM
    #58
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Again, a thread went to shit over dumbass comments from people who probably have no clue on the actual topic...
    glwood54 and Trail Runnah like this.
  29. Apr 13, 2023 at 8:35 AM
    #59
    I seen this and was just waiting patiently for Nano to show up and prove you wrong
    08TXRunner and Nano909 like this.
  30. Apr 13, 2023 at 8:36 AM
    #60
    Hahah touche my man
    Nano909 likes this.
Thread Status:
