80% Off Road Rear Bumper Bash Bar
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Mar 12, 2024.
  1. Mar 15, 2024 at 3:31 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I could be wrong here. But going from the photos it looks like that kit hangs pretty low and will decrease your departure angle. I’d stick with the 80% OR version to maintain maximum clearance
  2. Mar 15, 2024 at 6:31 AM
    HazOpRed
    HazOpRed 22' TRDOR
    Lol no, it'll be going in the same spot as the 80% one would
  3. Mar 15, 2024 at 6:51 AM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    Is there a company similar to this that you don't need to do a bumper chop? One that does a wrap around protecting the existing bumper?
  4. Mar 15, 2024 at 11:52 AM
    1SilverRunner
    Tejas
    ...Are you sure you linked the right product? The one you linked does hang much lower.
    It's mounted below the hatch instead of the integrated into the bumper to the right of the hatch.
    Nothing wrong with that as I'm sure as a tire swingout it will work fine. But it's much more likely to hangup on obstacles.
    I've seen a few guys ruin their Rigd swingout... Which the product you linked looks to be basically a DIY version of.
    Hitch mounted swingout:
    80% Off road bumper integrated swingout:
    Harringbr99 likes this.
  5. Mar 15, 2024 at 11:56 AM
    1SilverRunner
    Tejas
    Not that I know of. There are some custom fabs out there but anything that hangs below your bumper will further decrease clearance.
  6. Mar 15, 2024 at 12:14 PM
    1SilverRunner
    Tejas
    Most hitch mounted swingouts are not very low profile and hurt your departure angle. If you're planning to actually wheel I'd avoid them.
    I've seen a couple people bend these up pretty bad on the trail. Even online you can find similar scenarios.
    Here's one from TFLOffRoad's channel:
    The arm of the swingout caught a tree root and stopped the vehicle. It not only caused the vehicle to get stuck, but it did significant damage to the swingout as well.
    Harringbr99 and Bodie the Dog like this.
  7. Mar 15, 2024 at 4:22 PM
    1SilverRunner
    Tejas
    @Harringbr99 I like your setup so much I’m picking up a silver “limited” bumper from a salvage yard.
    I think the lines of the limited bumper lend themselves to this mod well.
    Stoney Ranger and Harringbr99 like this.
  8. Mar 15, 2024 at 8:50 PM
    HazOpRed
    HazOpRed 22' TRDOR
    No, no, no, no. Imagine 80%'s kit. Now make it out of the one I linked. That is what I am doing, I just didn't want to source the metal and not have to cut as much as possible. We need less people buying overpriced products and more bespoke ideas. I will have an entire rear bumper setup for less than $1k when I am done, as opposed to the insane prices they normally go for
  9. Mar 16, 2024 at 5:37 AM
    1SilverRunner
    Tejas
    Ah. Are you going to be buying DOM tubing as well? And do you have a tube bender that will work for it? The kit you have is for a swing out only. Are you hoping there’s enough material there to build a full rear bumper out of?
    I don’t think the 80% kit is overpriced to be fair. Kind of a bargain deal when most of these setups are upwards of $1800 and weigh hundreds of pounds. Most also require cutting your rear crossmember out entirely.
    Not trying to be argumentative here. But if you’re going to be designing, measuring, cutting and welding in the kit why not just buy the raw materials you need and build. I don’t see that kit helping you much for the bumper.
    Personally, I don’t have a tube bender or tube notcher. But I do have a welder. So the 80% kit is ideal for a guy like me. I’m okay with paying to use someone else’s design, R and D, and specialized equipment that I will likely never need again and don’t have space to store. So I would not agree that the 80% kit is a “overpriced product.”
    But hey, I love being wrong. It means I have an opportunity to learn. So build your own and post it up. I’d love to see the finished product.
    :cheers:
    SlvrSlug likes this.
  10. Mar 16, 2024 at 4:32 PM
    HazOpRed
    HazOpRed 22' TRDOR
    That's cap, you're being combative. Or at the very least, discouraging creativity. I don't appreciate your thoughts or concerns, as if I hadn't given a second thought to how this would be done. Creativity is to be fostered. You will be proven wrong, just let me cook
    And Ratha clearly states you need to buy the bigger pieces. It was to save the end user's shipping cost. He's a certified real one. Instead of just taking a screenshot, at least put the effort in to understand the product. He even sells the 3d models so one could mock up the design (*hint). Imagine if I had the 80% models. I could almost slap them together (*foreshadowing). Forgive me for not explaining every detail, but I don't expect this to be very difficult.
    And DOM is completely unnecessary in this application. Use HREW, CREW or just regular square tubing if you are concerned about not being able to bend a tube. Or you know, go to a machine shop. The obsession with DOM is unwarranted.
    4Runner owners are known for having wallets, if anything, that's for sure
  11. Mar 22, 2024 at 5:57 AM
    1SilverRunner
    Tejas
    So I reached out to 80% Off road and told them I plan on using the "limited" trim rear bumper. They told me they make a version of the kit specifically for that bumper as it's a little wider. Then they sent over this photo.
    Now I'm excited! This looks fantastic!
    I'm planning to keep the stock hitch underneath the bash bar. Other than that detail this is the end goal of how it should look.
    I was originally thinking this would be a slight compromise of looks traded for additional clearance and armor. But honestly, this looks great!
    HazOpRed, Harringbr99 and 2021venture like this.
  12. Mar 22, 2024 at 6:46 AM
    That looks like a real clean install.
    1SilverRunner[OP] likes this.
  13. Mar 28, 2024 at 7:39 AM
    1SilverRunner
    Tejas
    Got my limited bumper from Ebay but it took a little damage during shipping. Lame! I am getting it repainted by a local shop for $350. Having him spray the chrome section flat black as well.
    The kit from 80% should get here in 6 weeks or so. I'll update this thread when I get it in.
  14. May 29, 2024 at 7:09 AM
    1SilverRunner
    Tejas
    80% Off Road rear bumper bash bar is installed and painted!
    Really happy with the result. Got it done just before Texas Toyota Takeover at Merus in eight days! Goal met!
    Here's some photos from the install.
  15. May 29, 2024 at 7:29 AM
    You know.. at first I was annoyed by OP because this is not in fact 80 percent off as some deal were getting... but now I'm ticked off at the company because it's literally in their name!!
    My feeble little smooth brain is a sucker when I see any inclination of a number and a percent off...
  16. May 29, 2024 at 7:44 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    I really like the look of this thing. Not adding hundreds of lb is a bonus.
    For me it would just be an excuse to buy a welder :) he he he
  17. May 29, 2024 at 10:02 AM
    1SilverRunner
    Tejas
    Thanks! It's only 50 pounds of tubing so not bad compared to other high clearance/ armor options.
  18. May 29, 2024 at 11:37 AM
    TRDSD
    2019 TRD Off Road Premium
    This was posted in another thread, but is more appropriate in this one. Here's my 80% Off Road bash bar with side hoops (plus high clearance hitch relocation) and tire carrier install from last month. Since 80% is local to me, I had Nick do the full weld up and install. Came out great and my rear departure angle/clearance is drastically improved.
  19. May 29, 2024 at 12:23 PM
    #49
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    What was the total price OTD?
    I noticed you have the ICS Fab third brake light housing. I'm about to install mine, hopefully this weekend. How do you like it?
  20. May 29, 2024 at 1:57 PM
    #50
    I like that a lot, also interested in cost out the door as i am local.
  21. May 29, 2024 at 3:31 PM
    #51
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    Not going to lie, after seeing this I'm pretty convinced this will be what I do to the rear end eventually. I will find an SR5 rear bumper first though so I won't have the valence holes.
  22. May 29, 2024 at 4:49 PM
    #52
    TRDSD
    Why buy a whole new bumper cap? I covered it with a $15 roll of 3M auto trim strip all the way across. Nick @80% laughed when he saw it again a few days later. Thought it was factory.
    Harringbr99 and captrussia253 like this.
  23. May 29, 2024 at 5:53 PM
    #53
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    I am seriously now considering this, and I wasn’t even looking to replace my rear bumper (yet). That looks great.
  24. May 30, 2024 at 12:36 PM
    #54
    TRDSD
    Nick @ 80% hooked me up, so I don’t want to quote anyone a price that’s not accurate. Reach out to him via the messaging app on their website and have him give you a quote. Suffice to say it was far less for a complete setup (bumper + carrier) fully installed than any other options I considered - and I really looked around. I can’t recommend Nick and John enough. They’re a 2-man shop, but they really know their shit and build quality, bulletproof stuff. Great guys, too. Buy and support local if you can.
    On the ICS brake 3rd brake light, I like it. Only complaint is the crappy paint on the faceplate (it scratches just looking at it), but mine was one of the very first batch and they have since changed the coating. Took a while to wire up and into my switch panel up front, but works well. Mine has a BD S2 Pro Amber for a chase light and a S2 Pro White Work/Scene light. Great for camping and nighttime tailgaters. LOL
    coryanderson[QUOTED] likes this.
  25. Jun 3, 2024 at 11:28 AM
    #55
    Harringbr99
    Harringbr99 New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    @1SilverRunner - Where did you get the Limited - Plastic Bumper Cover?
  26. Jun 3, 2024 at 11:39 AM
    #56
    1SilverRunner
    Tejas
    Salvage yard via Ebay lol
    Edit: I liked your so much I decided to chop up a limited bumper. The lines of the limited bumper go well with this kit.
    Also I knew if I messed up too terribly I could just chop the bars off the frame, grind flat, paint black and put the regular bumper back on ;)
    #56
    Harringbr99[QUOTED] likes this.
