6" Lifted Toyota 4Runner TRD Off-Road Light Issues
Discussion in 'Suspension' started by That_4Runner, Jan 16, 2025.
  1. Jan 16, 2025 at 4:50 PM
    That_4Runner
    That_4Runner [OP] New Member
    Davey
    5th Gen TRD Off-Road
    TRD cold air intake, Lights, Competition Sub and 6" Lift Kit
    100% if it’s at the dealer might as well.
  2. Jan 16, 2025 at 4:51 PM
    The only issue is that the cross member is still down low. So I personally don't see the point in doing bracket lifts unless you got some massive tires to get that cross member up higher.
    I'd just get under there and anything being stretched try and relieve some of the strain if possible. Just because it doesn't look broken from the outside doesn't mean the wire inside is fine.
    Thatbassguy and TrailSpecial22 like this.
  3. Jan 16, 2025 at 4:51 PM
    icebear Recovered Kia Owner
    Oh yea just make sure the headlights are aimed lower to compensate for the lift and you'll be A-OK - a lot of instructions out there and you'll just need a #2 philips to do it. (my rough-and-dirty estimate way is to keep the cutoff below the rear window of most sedans on the road when I'm behind them at a stoplight.) Don't wanna blind folks!
  4. Jan 16, 2025 at 4:56 PM
    That_4Runner
    Davey
    yes if your rock crawling. But I already knew that wasn’t gonna be an option anymore after lifting.
  5. Jan 16, 2025 at 4:59 PM
    That_4Runner
    Davey
    agreed
    icebear[QUOTED] likes this.
  6. Jan 16, 2025 at 5:00 PM
    TrailSpecial22 New Member
    PA
    But you did say youre offroading it.
  7. Jan 16, 2025 at 5:01 PM
    That_4Runner
    Davey
    Yeah that honestly will be rectified after the tires are added. Just waiting to upgrade the ones I have on there are about 3 months old.
    eventually I’ll get extended brake lines. But it’s not really showing a tension there.
  8. Jan 16, 2025 at 5:01 PM
    That_4Runner
    Davey
    Possibly when I start planning on articulating again.
  9. Jan 16, 2025 at 5:06 PM
    That_4Runner
    Davey
    What is your definition of Off-Roading?
    We used to take it rock crawling up in big bear. But my off roading it’s HOV trails where it’s likely more dips that rocks, and we are not planing on pitching the truck sideways and hooping it doesn’t flip.
    Trail Runnah and java like this.
  10. Jan 16, 2025 at 5:06 PM
    You can probably get some $$ for those tires once you get some 35's on there. ;)
  11. Jan 16, 2025 at 5:07 PM
    this is definitely a test post by AI ..
  12. Jan 16, 2025 at 5:08 PM
    That_4Runner
    Davey
    true. Looking on Facebook Market for a swap
  13. Jan 16, 2025 at 5:18 PM
    PA
    id like to see more pics of this lift front and rear. I can imagine these wires and brake line being stretched to the max
  14. Jan 16, 2025 at 5:23 PM
    Ever been inside the wheel well? You have a flexible rubber line from the frame to the spindle. Normally in most suspensin lift kits you will get a bracket that moves the mounting point of that rubber line slightly and then you have more than enough wiggle room to move the wheel hub lower with the lift. This is quite common, there are very few lift kits that require new brake lines these days.
    The same goes with the rear, you have a flex line that will likely allow for 4+" without even getting close to getting tight. Probably a short bracket for the rear to move the mount of the rubber line and then you get enough wiggle room for 4-6"
  15. Jan 16, 2025 at 5:25 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I’ve gotten so off camber at a stock ride height on a trail in a section without rocks that I was literally having to hold on to the center console as I began to start turning uphill. :eek:
    Plenty of ways to get off camber without rock crawling.
  16. Jan 16, 2025 at 5:26 PM
    Be very careful if you take this offroad. I highly doubt these Rough County kits are made for off pavement duty.
  17. Jan 16, 2025 at 5:29 PM
    Yup. A buddy went 6 inch on his 2nd gen Taco for wheeling but the drop bracket limits ground clearance and it actually bent back at one point.
    kmeeg[QUOTED] and TrailSpecial22 like this.
  18. Jan 16, 2025 at 5:39 PM
    That_4Runner
    Davey
    let’s hope it’s not the case here. Cause I’d have to find someone to weld the sub frame back in.
  19. Jan 16, 2025 at 5:41 PM
    #49
    That_4Runner
    Davey
    Yeah they sent brackets to lower the brake lines and the speed sensor line. The kit came with extended knuckles too.
  20. Jan 16, 2025 at 5:41 PM
    #50
    That_4Runner
    Davey
    yes agreed. I’ve had this truck the same on tip top mountain in big bear.
  21. Jan 16, 2025 at 6:13 PM
    #51
    PA
    scottiezilla likes this.
  22. Jan 16, 2025 at 6:13 PM
    #52
    That_4Runner
    Davey
    lol
  23. Jan 16, 2025 at 7:40 PM
    #53
    Put some 22” wheels on that thing and ship it to Hawaii. :)
    1SilverRunner and HuskerRunner like this.
  24. Jan 16, 2025 at 8:32 PM
    #54
    java
    java fauxrunner
    2023 ORP ice cap
    Nice!!
  25. Jan 16, 2025 at 9:22 PM
    #55
    BoiseG
    BoiseG New Member
    2024 Off-Road Premium
  26. Jan 17, 2025 at 6:44 AM
    #56
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Yeah 33's aren't gonna do any justice here. 35s or bust.
    Shit I mean he already has the viper cut so a quick BMC is all it needs to fit them.
    After OP finds the stretched wire/ brake line of course.
  27. Jan 17, 2025 at 9:38 AM
    #57
    I think the combination of the 6in lift and the roof top tent might become an issue when you least expect it. Not sure about how you drive, but when I’m off road, sometimes I end up in situations that maybe I wasn’t exactly planning for, including ending up angles that are a bit more than what I bargained for. With the roof top tent, and any cargo inside the vehicle, your center of gravity is going to be extremely high, not to mention the inertia of a heavy roof might end up pulling you over earlier than you expect if the vehicle has any side to side pitching forces.
    The current wheels/tires are not just a cosmetic issue. From a stability and usability standpoint, getting some wheel spacers or wheels with a fair bit of poke might actually be advisable to increase stability. Heavier/wider tires will also help with that…. I would plan for this even if you decide to get rid of the RTT. Might as well go as big as possible on the tires at this point.
    Big tires should not be that difficult to fit compared to what’s already been done. The frame has already been cut up, so chopping the body mount shouldn’t be an issue. You might not need to hammer any bodywork to clear the front tires because it seems they will not compress as far into the wheel well as it did stock, since the bracket lift seems to reposition the entire suspension range down as a whole, not increase the range. The only issue with large enough tires is that you’ll probably want to regear to save the transmission.
    As far as the dash lights, I would check over the abs wiring and anything attached to the new spindles. You never know if the casting is rough and maybe cut or abraded a wire. Also, check to make sure the tone ring for the abs is installed correctly and undamaged. Those new uprights are a variable here, so check that everything fits well onto it. They are probably not as good as OE dimensionally (or with surface finish) which may affect the function of the abs/tone-ring.
    1SilverRunner and TrailSpecial22 like this.
  28. Jan 17, 2025 at 9:52 AM
    #58
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You need to definitely extended your rear brake lines.
    deltabravo and 1SilverRunner like this.
  29. Jan 19, 2025 at 5:40 PM
    #59
    That_4Runner
    Davey
    Eventually yes but not needed they gave me drop brackets.
  30. Jan 19, 2025 at 5:40 PM
    #60
    deltabravo
    deltabravo WUBBA LUBBA DUB DUB!!!!1!
    East Coast USA
    Anything more than 3.5 is overkill.
