5th Gen's spotted next to you
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Feb 25, 2024.
  1. Feb 1, 2025 at 2:42 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    nice equipped 3rd gen next to my 5th gen
  2. Feb 2, 2025 at 4:07 AM
    Whaler94
    Whaler94 New Member
    Michigan, United States
    2023 ORP white
    Nice 24' Trailhunter parked next to my 23' ORP! I am sure glad I grabbed it up when I had the chance in Sept of 2023. At the time I was thinking buying a Tacoma, but my wife said she liked the 4R better - and the rest is history. At that time, Toyota had not announced whether there would be a 2024 5th gen. I have seen a few ORP's on the used car lots selling for more than what I paid for mine new! Talk about crazy! New tariff war starting up - prices are sure to follow.
    littlemixi likes this.
  3. Feb 2, 2025 at 12:42 PM
    littlemixi
    littlemixi New Member
    Lady Lime
    The Palmetto State
    2022 Lime Rush 4Runner TRD Pro
    Grill LEDs, Tyger Star Armor sliders, morimoto 3rd brake light, Meso Customs hatch lights
    Twins (except mine has half as many miles)! That time I finally rolled up behind the only other one in town!
    2022 4Runner TRD Pros in Lime Rush
    roooo, TrailSpecial22 and Lucky9924 like this.
  4. Feb 2, 2025 at 1:27 PM
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    I feel a "mine's bigger!" discussion coming on.
  5. Feb 2, 2025 at 2:07 PM
    Jayz4162
    Jayz4162 New Member
    Wisconsin
    2018 4Runner TRD PRO
    Bilstien 5100 shocks - OME springs - SPC upper/lower control arms -285/70R17 Mickey Thomson Baja boss A/T tires - power stop Z36 brakes - professional undercoating & detail with ceramic coating - tints - full LED interior lighting bulb replacement - Bora 1.25-Inch Wheel Spacers - professional body mount chop to accommodate bigger tires and the wheel spacers. Sherpa crestone sport roof rack. - Pelsee 12 pro max dash cam. AlphaRex Universal Toyota Dual Color LED Projector Fog Lights.
    IMG_2713.jpg IMG_2710.jpg I Saw a ton of 4Runners down in the Tuscaloosa Alabama area. Mines the white Trd pro
    Lucky9924, littlemixi and LCJ77 like this.
  6. Feb 2, 2025 at 3:27 PM
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
  7. Feb 2, 2025 at 7:58 PM
    BlueMeanie
    BlueMeanie New Member
    Sean
    Omaha, NE
    2023 Nautical Blue 4Runner TRD Off Road
    None so far
    There is always a 5th Gen friend at my house! My wife has a 2013 SR5 Premium. She got hers 9-10 months before I got mine. Though, I’ve wanted a 4Runner before I even met her near-24 years ago!
  8. Mar 5, 2025 at 1:06 PM
    a vewy widdle wadder
  9. Mar 5, 2025 at 1:52 PM
    Photon_Chaser 51,023 and counting…
    Sierra Nevada Mountains and the Central Coast
    Two Pros, Stock vs a few mods…
  10. Mar 5, 2025 at 1:57 PM
    just spotted a Vancouver Tacoma so friggin nice I had to share here.
    roooo and Lucky9924 like this.
  11. Mar 5, 2025 at 2:10 PM
    vthoky New Member
    I didn't get to take the pic, but the situation was funny.
    Was out with Dad last weekend, pulling in at the Mexican restaurant. I was about to make fun of a fella parking his Tesla right next to an identical one, when I realized the parking space open to me was right beside... another TRD ORP. :D
    Lucky9924, Saker and TrailSpecial22 like this.
  12. Mar 5, 2025 at 7:42 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I rock a gobi. You got suppin' a say? :benchpress:
  13. Mar 5, 2025 at 7:47 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    I didn't catch a picture but passed a TRD OR or ORP in town today that had a pretty sweet setup. Couldn't tell if he was on 35's or just had a higher lift but it appeared taller than mine. Was another white stormtrooper with roof basket attached to factory rails, black overlays, custom plates, maybe predator steps?, black film on bottom of doors, raptor lights, and some kind of black striping on outside edges of front bumper cover that I've never seen before.
  14. Mar 5, 2025 at 8:01 PM
    344Takeoff
    344Takeoff New Member
    Ormond Beach
    2022 MIDNIGHT BLACK SR5 4WD
    Haaaaa and I thought I had a sticker problem…
  15. Mar 5, 2025 at 10:12 PM
    No sir! I don’t want no problems :p
  16. Mar 6, 2025 at 10:42 AM
    bobby4runner
    bobby4runner New Member
    Los Angeles
    2022 TRD Pro MBM
    Taken during service at dealership
  17. Mar 6, 2025 at 4:39 PM
  18. Mar 7, 2025 at 7:46 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Came out into the parking lot and my truck had found a buddy.
  19. Mar 7, 2025 at 5:53 PM
    #49
    344Takeoff
    Ormond Beach
    Spotted in Chick Fil A parking lot in Daytona Beach while grabbing lunch today…I was parked directly beside the first one and the second was at 11 o’clock…it was like the Spider-Man meme…
    roooo likes this.
  20. Mar 7, 2025 at 7:54 PM
    #50
    At a light
  21. Mar 8, 2025 at 10:33 AM
    #51
    garoto
    garoto New Member
    These new land cruisers look fantastic.
    bobby4runner[QUOTED] likes this.
  22. Mar 10, 2025 at 7:57 AM
    #52
    Imdav2u
    23 TRD PRO
    Grafton Illinois, part of our day drinking trip.
