5th Gen Trans Cooler
Discussion in '5th Gen 4Runners (2010-2024)' started by Crankpin, Oct 19, 2019.
  1. Dec 10, 2020 at 12:15 PM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Derale
  2. Dec 10, 2020 at 12:18 PM
    Doglover2003
    '18 ORP w/KDSS
    This is the one I bought. Upgraded the rubber holes to 3/8"
    Toy4X4 likes this.
  3. Jan 4, 2021 at 7:01 PM
    Runnin4mo
    Runnin4mo New Member
    Which version of cooler is that? I'm needing a good one for towing up the hills in the summer. Tranny temp is hitting a bit over 220F so a 30F drop would be fantastic.
    Scratch that, just seen the 8000 series listed in that ad.
    Thanks!
    Doglover2003[QUOTED] likes this.
  4. Mar 26, 2021 at 8:41 AM
    Runnin4mo
    Finally ordering this up.
    How much extra Tranny Fluid did you have to add to compensate for this big radiator?
  5. Mar 27, 2021 at 9:23 AM
    Doglover2003
    '18 ORP w/KDSS
    I added 1/2-3/4 bottle of Toyota ATF WS to the cooler and lines. It didn't take much.
  6. Mar 27, 2021 at 1:37 PM
    Runnin4mo
    Does that mean you pumped the ATF into the lines before you attached them to the system? I didn't think of that... I was just going to pump it into the tranny. I changed the tranny fluid and filter about 6 months ago so I may have almost a full bottle laying around. Thanks!
  7. Mar 28, 2021 at 6:17 PM
    Doglover2003
    '18 ORP w/KDSS
    No problem. Yeah straight to the lines and topped off the cooler. Too easy
  8. Mar 29, 2021 at 1:45 PM
    JR7
    JR7 New Member
    2021 TRD ORP
    Doglover, by any chance do yo recall which line from the transmission is the outflow and which belongs to the return line? There are two lines leaving and entering the transmission one is above the other. My guess is that the top is the return? But I want to be sure to get the flow correct when plumbing these in series.
    I did one of these on my 04 Taco and we got the wife a 4Runner last Friday. I know how well they work, and can't imagine not having the additional cooling on this one.
  9. Apr 3, 2021 at 2:09 PM
    Doglover2003
    '18 ORP w/KDSS
    See my post # 32 above^^^ it will should which lines goes to which.
  10. Apr 5, 2021 at 8:23 AM
    JR7
    JR7 New Member
    2021 TRD ORP
    :facepalm: Missed the smaller pics. Thanks.
  11. Apr 23, 2025 at 6:57 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  12. Apr 23, 2025 at 8:30 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    Is there a good detaile write up on how to install one?
  13. Apr 23, 2025 at 10:08 AM
    1SilverRunner
    Tejas
    Here you go bro
  14. Apr 23, 2025 at 10:37 AM
    sympley76
    That's awesome. Thank you.
